[mpich2-dev] Coverage annotations and mpid_rma.c
William Gropp wgropp at uiuc.edu
Mon Apr 28 12:30:40 CDT 2008
I was looking at some of the files that have substantial uncovered
sections, and one such file is ch3/src/mpid_rma.c .  All of the
uncovered code in that file is of the form
if (! initialized) { initialize(); }
This raises a number of questions:
1) Should there be a coverage annotation for this case (e.g.,
BEGIN_OPTIONALINIT ... END_OPTIONALINIT)?
2) In almost all cases, these initializes cannot happen in correct
code (e.g., some other routine must have been called first, such as
MPI_Win_create).  Should these be marked as BEGIN ERROR HANDLING ..
END ERROR HANDLING instead?  If so, should it be in the #if error
handling defintions?
3) This entire file is used to provide for and make available a
function table for the RMA functions (except MPID_Win_test).  This
adds an extra function call to all RMA operations, including latency-
sensitive operations such as lock or put.  Would it make sense to
promote something like this interface into the top-level routines
(e.g., MPI_Win_lock), perhaps with a macro that would basically say
"either convert to a specific routine or convert to a reference to a
standardized function table"?  That would then eliminate this file
from ch3 entirely.
Bill
William Gropp
Paul and Cynthia Saylor Professor of Computer Science
University of Illinois Urbana-Champaign
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080428/2a38fbd7/attachment.htm>
More information about the mpich2-dev mailing list
