[MPICH2 Req #4033] RE: [mpich2-dev] Bug in ch3 MPIDI_Accumulate()?
William Gropp gropp at mcs.anl.gov
Mon Apr 21 09:02:29 CDT 2008
This is a reminder that we need to review the coverage tests.  For
example, the local copy for put also does not appear to be tested.  See
http://www.mcs.anl.gov/research/projects/mpich2/todo/coverage/
ch3:sock/src/mpid/ch3/src/ch3u_rma_ops.c.htm
Bill
On Apr 4, 2008, at 3:27 PM, Rajeev Thakur wrote:
> David,
>            You are right. There is a bug. It didn't get caught so
> far because the test suite doesn't have a test for an accumulate
> with derived datatype at origin, basic datatype at target, and
> origin = target.
> Rajeev
> From: owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-
> dev at mcs.anl.gov] On Behalf Of David Gingold
> Sent: Wednesday, April 02, 2008 3:23 PM
> To: mpich2-dev at mcs.anl.gov
> Subject: [mpich2-dev] Bug in ch3 MPIDI_Accumulate()?
> I ran into this problem in code that I cribbed from the ch3
> implementation. I've not verified that it happens in ch3, but it
> seems, by inspection, that it probably does:
> In MPIDI_Accumulate() (ch3u_rma_ops.c), in the case where
> target_rank == rank and the origin and target datatypes are not
> both pre-defined, the code does this:
> MPID_Datatype_get_ptr(target_datatype, dtp);
> vec_len = dtp->n_contig_blocks * target_count + 1;
> The trouble is that we'll hit this case where the origin type is
> derived and the target type is pre-defined. And
> MPID_Datatype_get_ptr() isn't workable for pre-defined datatypes.
> So dtp->* will evaluate to zero. That causes grief when we
> reference dtp->eltype a few lines down.
> I think the simple fix is to add separate cases in here for when
> target_datatype is predefined. But I also spotted the code in
> MPIR_Datatype_builtin_fillin(), which, if called, would seem to
> make MPID_Datatype_get_ptr() become valid for built-in datatypes.
> Is there a reason why MPIR_Datatype_builtin_fillin() isn't simply
> called inside MPI_Init() somwehere?
> -dg
> David Gingold
> Principal Software Engineer
> SiCortex
> Three Clock Tower Place, Suite 210
> Maynard MA 01754
> (978) 897-0214 x224
William Gropp
Paul and Cynthia Saylor Professor of Computer Science
University of Illinois Urbana-Champaign
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080421/d0a67087/attachment.htm>
More information about the mpich2-dev mailing list
