[mpich2-dev] Bug in ch3 MPIDI_Accumulate()?
David Gingold
david.gingold at sicortex.com
Wed Apr 2 15:22:32 CDT 2008
I ran into this problem in code that I cribbed from the ch3
implementation. I've not verified that it happens in ch3, but it
seems, by inspection, that it probably does:
In MPIDI_Accumulate() (ch3u_rma_ops.c), in the case where target_rank
== rank and the origin and target datatypes are not both pre-defined,
the code does this:
MPID_Datatype_get_ptr(target_datatype, dtp);
vec_len = dtp->n_contig_blocks * target_count + 1;
The trouble is that we'll hit this case where the origin type is
derived and the target type is pre-defined. And MPID_Datatype_get_ptr
() isn't workable for pre-defined datatypes. So dtp->* will evaluate
to zero. That causes grief when we reference dtp->eltype a few lines
down.
I think the simple fix is to add separate cases in here for when
target_datatype is predefined. But I also spotted the code in
MPIR_Datatype_builtin_fillin(), which, if called, would seem to make
MPID_Datatype_get_ptr() become valid for built-in datatypes. Is
there a reason why MPIR_Datatype_builtin_fillin() isn't simply called
inside MPI_Init() somwehere?
-dg
David Gingold
Principal Software Engineer
SiCortex
Three Clock Tower Place, Suite 210
Maynard MA 01754
(978) 897-0214 x224
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080402/b968d9eb/attachment.htm>
More information about the mpich2-dev
