[mpich2-dev] tests which assume that the implementation supports truncated messages
    David Gingold
    david.gingold at sicortex.com
    Tue Apr  1 15:44:23 CDT 2008
MPICH2 folks --
Some of the tests that come with MPICH2 assume that the MPI
implementation supports truncated messages (i.e. point-to-point
operations with more data sent than received).  It looks like the
tests are using this as a way to determine whether errors can be
returned in the receive status.
Our MPI implementation doesn't support truncation.  It's not required
by the standard, and dispensing with it simplified our code and
improved performance.
Would it make sense to change these tests to be more portable?  Could
they be made to trigger a different sort of error, perhaps one
checked in the HAVE_ERROR_CHECKING portions of the top-level receive
code?
-dg
David Gingold
Principal Software Engineer
SiCortex
Three Clock Tower Place, Suite 210
Maynard MA 01754
(978) 897-0214 x224
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080401/3af67e1a/attachment.htm>
More information about the mpich2-dev
