[MPICH2-dev] RE: problem with multithreaded version of sock mpich2-1.06 under Windows
Ryzhykh, Alexey
alexey.ryzhykh at intel.com
Mon Sep 24 08:51:18 CDT 2007
I would like to add that we fixed one problem related to thread
synchronization. (added missed call of MPID_Thread_mutex_lock)
See attached diff file for mpich2-1.0.6/src/mpid/common/sock/iocp/sock.c
But it does not solve all problems.
Alexey
Sent: Monday, September 24, 2007 5:42 PM
To: 'mpich2-dev at mcs.anl.gov'; 'Rajeev Thakur'
Cc: Voronov, German; Supalov, Alexander; Truschin, Vladimir; Yulov,
Dmitry
Subject: problem with multithreaded version of sock mpich2-1.06 under
Windows
Hi everybody,
We faced the problems with using multithreaded version of mpich2-1.06
built with ch3: sock channel under Windows IA32.
May be the same problems exists on other Intel platforms under Windows -
Intel 64 and IA64. I was able to build working Win mpich2-1.06 only for
IA32.
The simple MT tests like mpich2/threaded_sr works fine but under stress
testing we see the problems.
I used the special version of IMB that support running several threads
for our stress testing.
And I got intermittent failures running 8 processes on 4 nodes with 8
threads.
Sometimes the test finishes successfully, sometimes it hangs and
sometimes the following error appears:
job aborted:
rank: node: exit code[: error message]
0: svsmpiw03: 1
1: svsmpiw03: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
MPI_Recv(186).............................: MPI_Recv(buf=03BC0040,
count=262144
MPI_BYTE, src=2, tag=MPI_ANY_TAG, comm=0x84000007, status=01B4FE78)
failed
MPIDI_CH3i_Progress_wait(215).............: an error occurred while
handling an
event returned by MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(420):
MPIDU_Sock_wait(2602).....................: The specified network name
is no lo
ger available. (errno 64)
2: svsmpiw04: 1: Fatal error in MPI_Waitall: Other MPI error, error
stack:
MPI_Waitall(258)..........................: MPI_Waitall(count=2,
req_array=01B4
E68, status_array=01B4FE78) failed
handling an
MPIDU_Sock_wait(2464).....................: Unable to re-post an aborted
readv
peration
MPIDU_Sock_post_readv(1655)...............: An existing connection was
forcibly
closed by the remote host. (errno 10054)
3: svsmpiw04: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
count=262144
MPI_BYTE, src=2, tag=MPI_ANY_TAG, comm=0x84000005, status=01B4FE78)
failed
handling an
is no lo
Could you please help to solve the problem?
I can provide you with this MT IMB in separate email. I can't reproduce
the problem on small test cases.
With best regards,
Alexey Ryzhykh,
Intel, Sarov
Closed Joint Stock Company Intel A/O
Registered legal address: 125252, Moscow, Russian Federation,
Chapayevsky Per, 14.
This e-mail and any attachments may contain confidential material for
the sole use of the intended recipient(s). Any review or distribution
by others is strictly prohibited. If you are not the intended
recipient, please contact the sender and delete all copies.
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20070924/698fb738/attachment.htm>
Desc: sock.c.diff
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20070924/698fb738/attachment.obj>
More information about the mpich2-dev
