[MPICH2-dev] New Release of MPICH2 (1.0.6)
Pavan Balaji
balaji at mcs.anl.gov
Sun Sep 16 11:03:59 CDT 2007
Dear all,
A new version of MPICH2, 1.0.6, has been released for both Unix and
Windows platforms. You can download it from
http://www.mcs.anl.gov/mpi/mpich2. We recommend you upgrade to this
version if you are running an older version of MPICH2 or MPICH-1. New
features in this release include:
- Updates to the ch3:nemesis channel including preliminary support for
thread safety.
- Preliminary support for dynamic loading of ch3 channels (sock, ssm, shm).
- Singleton init capability with the MPD process manager.
- Fixes in MPD related to MPI-2 connect-accept.
- Improved support for MPI-2 generalized requests that allows true
nonblocking I/O in ROMIO.
- Performance improvements for derived datatypes (including packing and
communication) through in-built loop-unrolling and buffer alignment.
- Performance improvements for MPI_Gather when non-power-of-two
processes are used, and when a non-zero ranked root is performing the gather.
- MPE changes:
* Enabled thread-safe MPI logging through global mutex.
* Enhanced Jumpshot to be more thread friendly + added simple
statistics in the Legend windows.
* Added backtrace support to MPE on Solaris and glibc based systems,
e.g. Linux. This improves the output error message from the
Collective/Datatype checking library.
* Fixed the CLOG2 format so it can be used in serial (non-MPI) logging.
- MPI_Comm_create fixes for intercommunicators.
- Enabled -O2 and equivalent compiler optimizations for supported
compilers by default.
- Many other bug fixes and code cleanup.
Details are in the CHANGES file in the distribution. A full list of change
comments from the CVS commits is available at
www.mcs.anl.gov/mpi/mpich2/mpich2_1_0_6changes.htm .
Also, we will soon be switching from CVS to SVN for source control.
Anonymous read access to the SVN repository will be available. Details to
follow.
The MPICH2 Team
If you have any feedback about this release or would like to report an
issue with MPICH2, please send us an email at mpich2-maint at mcs.anl.gov.
Pavan Balaji
http://www.mcs.anl.gov/~balaji
More information about the mpich2-dev
