[MPICH2-dev] Caused collective abort:
Amit H Kumar AHKumar at odu.edu
Tue Nov 27 10:55:54 CST 2007
Hi MPICH2,
I am having synchronization problem. Which is causing collective abort.
What I am trying to accomplish.
As shown below, basic idea is to have every process send some data to
lowered number process in an overlapped fashion. And I can only continue
with the computation after I have received the required data.   Data can be
large at times, for simplicity I am only showing a single valued buff in
the code.
I am using MPI_Irecv and MPI_Isend  as show below.
My Question is:
When using Non-blocking communication,  each sender initiates a "Send
start" and continues with computation and waits on a Non-Blocking receive
with MPI_Waitall as show below: Is it okay to have the sender Wait on both
of its MPI_Isend and MPI_Irecv initiated at different points in the code ?
I believe I am doing something wrong here,  because everything works okay
for a smaller problem size.
Any help or feedback will be of great help.
Thank you,
Amit
/////////////////CODE
for(i=NUMBER; i>0; i--)
  printf("\nDoing Initialization ...\n");
 if(i==NUMBER){
      /*  DO COMPUTATION */
  } else{
        /*  Receive Data from the higher numberd process-rank , with
Process rank Zero receivng from Rank=Size-1 */
        err = MPI_Irecv(&buff,sizeof(double),
MPI_DOUBLE,((rank+1)%size),0,MPI_COMM_WORLD, &mrequest[1] );
        MPI_Waitall(2,mrequest,mstatus);
      /* After Receiving Continue with Computation*/
  }/*Else  End*/
  /*Communication Block*/
  if(i>1){
      /*  SEND DATA TO lowered number process-rank*/
        err = MPI_Isend(&buff,sizeof(double),
MPI_DOUBLE,((rank+(size-1))%size),0, MPI_COMM_WORLD, &mrequest[0]);
  }/*if(i>1)*/
 }/*End of Main For loop*/
More information about the mpich2-dev mailing list
