[MPICH2-dev] spawn and MPI_Finalize
Rajeev Thakur thakur at mcs.anl.gov
Thu Nov 22 13:35:03 CST 2007
Are you using the latest version, 1.0.6p1? At least the issue of the slaves
waiting for the parent to call finalize should be fixed in there.
Rajeev
> -----Original Message-----
> From: owner-mpich2-dev at mcs.anl.gov
> [mailto:owner-mpich2-dev at mcs.anl.gov] On Behalf Of
> Rozzen.VINCONT at external.thalesgroup.com
> Sent: Thursday, November 22, 2007 1:31 PM
> To: mpich2-dev at mcs.anl.gov
> Subject: [MPICH2-dev] Date: Thu, 22 Nov 2007 09:51:08 +0100
> Hi,
> I have some issues using MPI_Finalize.
> Issue 1:
> A master process spawns 2 slave processes. Slave processes
> perform a job and then stop.
> My problem is one of the slave process is stuck in its
> MPI_Finalize call until Master reaches its own MPI_Finalize.
> Why a slave is stuck in its MPI_Finalize call ? why the other is not ?
> Note: by the way, with 10 slaves spawned from a single
> MPI_spawn_multiple call, only 1 out of 10 is stuck.
> Issue 2:
> A master process spawns every second a slave process (Master
> does not know if Slave is stopped or not before doing a spawn again).
> Conf. 1: Slave is stuck in its MPI_Finalize call.
> In this configuration, Master is able to perform 324 spawn
> calls and then Master stops with no obvious reason.
> Conf. 2: MPI_Finalize is removed from the slave source code.
> Slave stops correctly but Master reports a communication shutdown.
> In this configuration, Master is able to perform about 550
> spawn calls and then Master stops with no obvious reason.
> Do you have any explanations for these spawn limits ?
> Thanks for your help.
> Regards.
More information about the mpich2-dev mailing list
