[MPICH2-dev] MPICH2 cross compilation help
    Brad Penoff
    penoff at cs.ubc.ca
    Fri Feb 23 22:47:23 CST 2007
hey all,
Just a quick update.  Long story short, I got MPICH2 ch3:sock to cross
compile to alpha but in the process I think I found a handful of
bugs/strangeness.  Read on if you're interested.
--disable-sharedlibs
The original error reported in this email thread has nothing to do with
cross compiling.  I saw it break in the same way when using a "normal"
native gcc.  It seems that using --disable-sharedlibs breaks the build.
For example the following configure succeeds but the make afterwards fails
exactly as originally reported:
./configure --disable-f77 --disable-f90 --disable-sharedlibs --disable-cxx
So that aside, and back to my cross compilation scenario, I did the same
series of environment variable settings and did the exact same configure
minus the --disable-sharedlibs part.  The configure succeeded and the
build made it further, but failed eventually.  I'll walk from this error
onward saying how I overcame it and what I suspect may be buggy code,
but it's in narrative form (one leads to the next).
mpid_type_create_pairtype.c
Specifically, line 210 of mpid_type_create_pairtype.c complains of an
undefined variable HAVE_MAX_FP_ALIGNMENT.  This error is below my name on
this email.  Should 209 be
#elif defined(HAVE_MAX_FP_ALIGNMENT)
rather than
#else
Making this change allows me to compile this file.
ad_wait.c
I did this mpid_type_create_pairtype.c edit and my cross compilation made
it further but failed in romio inside ad_wait.c for seemingly several
reasons:
1) line 62 for `tmp1' undeclared.  This would mean that
ROMIO_HAVE_AIO_SUSPEND_TWO_ARGS and ROMIO_HAVE_WORKING_AIO were set but
ROMIO_HAVE_STRUCT_AIOCB_WITH_AIO_HANDLE was not.
2) Once I changed line 44 to the following so tmp1 was declared:
#if defined(ROMIO_HAVE_STRUCT_AIOCB_WITH_AIO_HANDLE) || defined(ROMIO_HAVE_AIO_SUSPEND_TWO_ARGS)
... then it complained about these:
ad_wait.c:59: warning: passing arg 1 of `aio_suspend' makes pointer from
integer without a cast
ad_wait.c:59: warning: passing arg 2 of `aio_suspend' makes integer from
pointer without a cast
ad_wait.c:59: error: too few arguments to function `aio_suspend'
ad_wait.c:64: error: structure has no member named `aio_handle'
ad_wait.c:66: error: structure has no member named `aio_handle'
This led me to believe that ROMIO_HAVE_AIO_SUSPEND_TWO_ARGS was set when
it shouldn't have been.  This makes #1 somewhat irrelevant (only that
block uses tmp1).  Once the code makes it into the ROMIO_HAVE_WORKING_AIO
block, I think we want it to *not* compile the
ROMIO_HAVE_AIO_SUSPEND_TWO_ARGS code.  I therefore changed line 55 from
#ifdef ROMIO_HAVE_AIO_SUSPEND_TWO_ARGS
to
#if 0
It made it past THAT and a little bit further.  This solved my problem for
now, but might not be general enough to solve others'.  I guess the
general point is that ROMIO_HAVE_AIO_SUSPEND_TWO_ARGS was set and
aio_suspend in my setting needed more than 2 args.  Any ideas why?
ad_nfs_wait.c
The next issue was in ad_nfs_wait.c ; these were nearly identical to those
in ad_wait.c except different line numbers (the code appeared copied). So,
to repeat, I changed line 15 to
and line 25 to
#if 0
.  Actually for both files, if you have the #if 0, you don't need to
change the #ifdef ROMIO_HAVE_STRUCT_AIOCB_WITH_AIO_HANDLE line.
After these minor changes, I was able to cross compile MPICH2 1.0.5p3
ch3:sock for alpha.  I actually haven't tried to run it yet (I'm sure
you'll hear from me if not ;-), just I thought I'd bring these 4 issues to
your attention.
brad
<snip snip>
/var/tmp/brad/crosstool/gcc-3.4.3-glibc-2.3.5/alpha-unknown-linux-gnu/bin/alpha-unknown-linux-gnu-gcc
-DHAVE_CONFIG_H -I. -I. -I. -I../../../include
-I/var/tmp/brad/m5/tmp/tmp2/mpich2-1.0.5p3/src/include
-I/var/tmp/brad/m5/tmp/tmp2/mpich2-1.0.5p3/src/mpid/ch3/include
-I/var/tmp/brad/m5/tmp/tmp2/mpich2-1.0.5p3/src/mpid/common/datatype
-I/var/tmp/brad/m5/tmp/tmp2/mpich2-1.0.5p3/src/mpid/ch3/channels/sock/include
-I/var/tmp/brad/m5/tmp/tmp2/mpich2-1.0.5p3/src/mpid/common/sock
-I/var/tmp/brad/m5/tmp/tmp2/mpich2-1.0.5p3/src/mpid/common/sock/poll
-I/var/tmp/brad/m5/tmp/tmp2/mpich2-1.0.5p3/src/mpid/common/sock/poll -c
mpid_type_get_contents.c
mpid_type_create_pairtype.c: In function `MPID_Type_create_pairtype':
mpid_type_create_pairtype.c:210: error: `HAVE_MAX_FP_ALIGNMENT' undeclared
(first use in this function)
mpid_type_create_pairtype.c:210: error: (Each undeclared identifier is
reported only once
mpid_type_create_pairtype.c:210: error: for each function it appears in.)
make[4]: *** [mpid_type_create_pairtype.o] Error 1
make[4]: Leaving directory
`/var/tmp/brad/m5/tmp/tmp2/mpich2-1.0.5p3/src/mpid/common/datatype'
make[3]: *** [all-redirect] Error 2
make[3]: Leaving directory
`/var/tmp/brad/m5/tmp/tmp2/mpich2-1.0.5p3/src/mpid/common'
make[2]: *** [all-redirect] Error 2
make[2]: Leaving directory
`/var/tmp/brad/m5/tmp/tmp2/mpich2-1.0.5p3/src/mpid'
make[1]: *** [all-redirect] Error 2
make[1]: Leaving directory `/var/tmp/brad/m5/tmp/tmp2/mpich2-1.0.5p3/src'
make: *** [all-redirect] Error 2
On Fri, 23 Feb 2007, Brad Penoff wrote:
> Greetings,
> I'm trying to use a series of cross tools to build alpha binaries on an i686
> machine.  We have access to some simulation tools that run real kernels and
> binaries, but they must be in alpha.  I don't have access to a real alpha
> machine so it is my only choice to cross compile.  I know that the cross
> tools work as I can already boot the Linux kernel, run python, use ssh, and
> even run my own simple applications.  In fact, I was able to run the
> maint/getcross.c file to produce a getcross.out text file to feed into
> --with-cross.
> The main problem is that I can't get MPICH2 to build.  This is my first time
> cross compiling something other than the Linux kernel and simple apps, but I
> haven't been able to find much documentation on cross compiling MPICH2; I
> figured I'd ask this list for some advice.
> The steps I did was try to point all standard tools to use the cross tools.
> I did this as follows (in bash):
> export
> CC=/var/tmp/brad/crosstool/gcc-3.4.3-glibc-2.3.5/alpha-unknown-linux-gnu/bin/alpha-unknown-linux-gnu-gcc
> export
> AR=/var/tmp/brad/crosstool/gcc-3.4.3-glibc-2.3.5/alpha-unknown-linux-gnu/bin/alpha-unknown-linux-gnu-ar
> export
> RANLIB=/var/tmp/brad/crosstool/gcc-3.4.3-glibc-2.3.5/alpha-unknown-linux-gnu/bin/alpha-unknown-linux-gnu-ranlib
> export
> AS=/var/tmp/brad/crosstool/gcc-3.4.3-glibc-2.3.5/alpha-unknown-linux-gnu/bin/alpha-unknown-linux-gnu-as
> export
> LD=/var/tmp/brad/crosstool/gcc-3.4.3-glibc-2.3.5/alpha-unknown-linux-gnu/bin/alpha-unknown-linux-gnu-ld
> export
> NM=/var/tmp/brad/crosstool/gcc-3.4.3-glibc-2.3.5/alpha-unknown-linux-gnu/bin/alpha-unknown-linux-gnu-nm
> Once this was done, I ran MPICH2 1.0.5p3's configure successfully in the
> following way:
> --prefix=/var/tmp/brad/m5/mpich2/ch3_sock --build=i686-pc-linux-gnu
> --host=alpha-unknown-linux-gnu --disable-cxx
> The arch names are following the format of strings generated by
> "config.guess"
> The configure completes but the make fails miserably thereafter.  I've
> included the relevant portion of the output below.  Why is it that sometimes
> the cross compiler (CC) is used but other times it simply tries to use
> "true"?  The generated Makefile has C_LINK_SHL equal to "true" so either I'm
> doing something wrong with my configure command or something funny is going
> on... any advice with my cross compiling nightmare?
> Thanks ahead of time,
> brad
> <snip snip>
> make[7]: Entering directory
> `/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src/mpid/common/sock/poll'
> -DHAVE_CONFIG_H -I.
> -I/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src/mpid/common/sock/poll
> -I../../../../include -I/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src/include
> -I/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src/mpid/ch3/include
> -I/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src/mpid/common/datatype
> -I/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src/mpid/ch3/channels/sock/include
> -I/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src/mpid/common/sock/poll -c sock.c
> cr ../../../../../lib/libmpich.a sock.o
> date > .libstamp0
> make[8]: Entering directory
> true -DHAVE_CONFIG_H -I.
> -I/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src/mpid/common/sock/poll -c sock.c -o
> _ssock.o
> mv: cannot stat `_ssock.o': No such file or directory
> make[8]: *** [sock.lo] Error 1
> make[8]: Leaving directory
> make[7]: *** [all-redirect] Error 2
> make[7]: Leaving directory
> make[6]: *** [all-redirect] Error 1
> make[6]: Leaving directory
> `/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src/mpid/common/sock'
> make[5]: *** [all-redirect] Error 2
> make[5]: Leaving directory
> `/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src/mpid/ch3/channels/sock'
> make[4]: *** [all-redirect] Error 1
> `/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src/mpid/ch3/channels'
> make[3]: Leaving directory `/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src/mpid/ch3'
> make[2]: *** [all-redirect] Error 1
> make[2]: Leaving directory `/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src/mpid'
> make[1]: Leaving directory `/var/tmp/brad/m5/tmp/mpich2-1.0.5p3/src'
More information about the mpich2-dev
