[MPICH2-dev] supporting MPI_THREAD_SERIALIZED
David Gingold
david.gingold at sicortex.com
Mon Dec 31 15:27:58 CST 2007
MPICH2 folks:
Our MPI presently supports the MPI_THREAD_FUNNELED level. But I
think it should be easy for us to support MPI_THREAD_SERIALIZED,
which would add a bit of flexibility for multi-threaded
applications. The glibc functions that our MPI calls are thread-
safe, so that's not an issue. And I can't see why the innards of our
implementation would care about the differences between FUNNELED and
SERIALIZED.
So what is it that I need to do to support SERIALIZED?
To start, I know that I need to configure the build with "--enable-
threads=serialized". That turns on mechanisms in mpiimplthread.h,
including pulling in mpid_thread.h. But mpid_thread.h has a bigger
API than I would expect. I can see that we need to provide
MPID_Thread_self() and MPID_Thread_same() so that MPI_Is_thread_main
() can work. But why do we need to define the other functions that
show up in mpid_thread.h.in? Or can I define these as no-ops?
-dg
David Gingold
Principal Software Engineer
SiCortex
Three Clock Tower Place, Suite 210
Maynard MA 01754
(978) 897-0214 x224
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20071231/b33a8ba4/attachment.htm>
More information about the mpich2-dev
