[MPICH2-dev] MPICH2 1.0.6rc1 thread support
James S Perrin
james.s.perrin at manchester.ac.uk
Fri Aug 17 12:02:41 CDT 2007
We want to use ssm as we sometimes have two specific processes per
machine that working as a team.
Actaully I think we have been using assuming serialized support at
compile time (we're not doing runtime checking of threads_provided, long
story don't ask) and it seems to have been working, we hadn't explicitly
enabled threading in mpich2 so I gues we've been "lucky" :) Our
Master/Slaves app has a threaded Master process that performs serialized
MPI calls in two threads.
Regards
James
Rajeev Thakur wrote:
> Actually serialized and multiple thread levels are supported for sock and
> nemesis. I have updated the README. For other channels such as ssm, which
> have no thread support, we currently allow single and funneled. Do you need
> to use serialized with ssm?
> Rajeev
>> -----Original Message-----
>> From: owner-mpich2-dev at mcs.anl.gov
>> [mailto:owner-mpich2-dev at mcs.anl.gov] On Behalf Of James S Perrin
>> Sent: Friday, August 17, 2007 9:55 AM
>> To: mpich2-dev at mcs.anl.gov
>> Subject: [MPICH2-dev] MPICH2 1.0.6rc1 thread support
>> Hi,
>> The README states that and serialized and multiple
>> thread levels are
>> only support by the sock channel, but I can configure the ssm
>> channel to
>> use serialized i.e.:
>> --with-device=ch3:ssm --enable-threads=serialized
>> where
>> --with-device=ch3:ssm --enable-threads=multiple
>> reports a configure error as expected. Is configure correct
>> or the README?
>> BTW some sort of feature matrix for the various devices and channels
>> would be very helpful.
>> Regards
>> James
>> James S. Perrin, | email:
>> james.perrin at manchester.ac.uk
>> Research Computing Services, | web: www.mc.manchester.ac.uk
>> Kilburn Building, The University, | tel: +44 161 275 6945
>> Manchester, England. M13 9PL. | fax: +44 161 275 0637
>> "The test of intellect is the refusal to belabour the obvious"
>> - Alfred Bester
James S. Perrin, | email: james.perrin at manchester.ac.uk
- Alfred Bester
More information about the mpich2-dev
