[MPICH2-dev] How to Build MPICH2 source-code on WindowsXP with VS2005
毕旋
Slader_Rec at sjtu.edu.cn
Tue Apr 24 05:33:00 CDT 2007
During these tow months, I¡¯m trying to build mpich2-1.0.3 source-code on
WindowsXP(x86) with VS2005, but met a lot of troubles.
I followed the tutorial windev.pdf, but still errors and problems:
1. makewindist.bat ¨Cwith-checkout
output: cvs -d :ext:Jason at harley.mcs.anl.gov:/home/MPI/cvsMaster export -r
HEAD mpich2allWithMPE
Secure connection to harley.mcs.anl.gov refused.
cvs [export aborted]: end of file from server (consult above messages if
any)
2. winconfigure.wsf --remove-fortran ¨Ccleancode
output: (no errors,but)
perl maint\extracterrmsgs -skip=src\util/multichannel/mpi.c src\mpi
src\nameserv src\util src\binding src\include src\mpid
Could not open src\mpid
Because of errors in extracting error messages, the file
src\mpi\errhan\defmsg.h was not updated.
3. Then, I open mpich2.sln with VS2005, and compile this solution, but
failed with a lot of errors. Such as:
¡\microsoft visual studio 8\vc\platformsdk\include\wspiapi.h(44) : error
C2894: templates cannot be declared to have 'C' linkage;
LINK : fatal error LNK1104: cannot open file¡°smpd_utild.lib¡±;
BSCMAKE: warning BK4502 ;
BSCMAKE: error BK1513 ;
and so on
Can you tell me how can I build the mpich2.sln?
Thanks very much!
Best wishes,
Jason
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20070424/8b8cb8dc/attachment.htm>
More information about the mpich2-dev
