[MPICH2-dev] Problems using MPE in MPI-2
Gustavo Camargo Longhin
gustavolonghin at aim.com
Thu Sep 14 11:08:51 CDT 2006
Hope I get the right list to send this.
I have a code which works fine with mpich implementations of both MPI-1 and
MPI-2.
I work with C++, use the mpicxx as compiler.
Ever since I inserted calls to MPE on that code, am having a freezing with
message "Enabling the synchronization of the clocks..."
If I remove calls to MPE on that code it works fine.
I did not included MPE on my MPI-1 codes, so I don't know if MPE would work
for me on MPI-1 mpich implementation.
I am using linux on x86 and ppc-g4, the same problem in both platforms.
Any hint will help.
Thanks a lot, best regards.
Gustavo Longhin
Computational Mechanics Lab - UNICAMP - Brazil
More information about the mpich2-dev
