[MPICH2-dev] MPICH2 bugs in configure and maybe MPI_Cancel
Philippe Combes Philippe.Combes at ens-lyon.fr
Sat Nov 18 10:29:20 CST 2006
Guillaume Mercier a écrit :
> Hello,
> On Fri, 17 Nov 2006, Philippe Combes wrote:
>>./configure --with-device=ch3:ssm --without-mpe --disable-f77
>>--disable-f90 --enable-cxx --enable-fast --enable-sharedlibs=gcc
>>--enable-strict --enable-error-checking=all --enable-error-messages=all
>>--enable-g=all --enable-debuginfo -prefix=/usr/local/mpich_dbg
>>First, after the configure runs, I still have a "#undef
>>HAVE_ERROR_CHECKING" in mpichconf.h, and MPICH_ERROR_MSG_LEVEL was set
>>to MPICH_ERROR_MSG_NONE. Strange, isn't it ?
> I may be wrong, but I think that --enable-fast disables error checking.
> That might explain the configure problem.
That's true ! You are right. Sorry, I have not read anything about it. I
have checked that it disables error checking as well as error messages.
There is only that issue about shared libs left now...
>>Now let's talk about the initial errors.
>>Running my 3-node program under gdb leads to three SIGSEV. On two
>  Error encountered before initializing MPICH
> .. it says "before intializing" although these errors occur AT THE END of the execution and all communications were OK before.
It was a clue, actually. But LAM/MPI error message was more explicit: I
have a function that calls MPI_Finalize, but it performs some MPI_Test's
and MPI_Cancel's before. That function was called twice, and thus
MPI_Cancel was called AFTER MPI_Finalize - silly me !
Best regards
Philippe
More information about the mpich2-dev mailing list
