[MPICH2-dev] mpd client library and protocol?
Greg Watson
gwatson at lanl.gov
Mon May 22 12:47:19 CDT 2006
Rusty,
Ok, thanks. I think I have all I need for the moment. I've already
got a simple command interpreter working with mpd and I'm just in the
process of interfacing this with PTP. I should have something
working soon.
Oak Ridge in July should be fine. Let me know if you'd like a PTP
demo or something.
Greg
On May 18, 2006, at 12:12 PM, Rusty Lusk wrote:
> Hi Greg,
> Now that I see what you need, I have a different answer. At
> least
> most of what you need has been implemented and documented as part
> of the
> mpd package, which includes other commands besides mpiexec, such as
> mpdlistjobs, mpdsigjob, and mpdkilljob. Other parts may be
> available as
> effects of doing something to the mpiexec process, like suspending it,
> continuing it, or killing it. (These were originally implemented for
> the purpose of interactive control, but should do what you want if you
> deliver the appropriate signals to mpiexec.) For at least one
> level of
> documentation, once you have installed mpd, you can do
> mpdhelp
> to get a list of the mpd commands, and then
> <mpdcmd> --help
> to get a description of how to use each command. More information
> is in
> the MPICH2 Installer's Guide and User's Guide, in the doc subdirectory
> of mpich2.
> What these commands do (including mpiexec) is contact the locally
> running mpd and talk to it via messages consisting of python
> dictionaries. Yes, you could write your own program to generate these
> messages, but I would hope that we have already implemented much of
> what
> you need, and we would be interested in implementing the rest of what
> you need in collaboration with you.
> Regards,
> Rusty
> P.S. I am about to invite you to a workshop at Oak Ridge on July
> 12-14
> at Oak Ridge. Mark your calendar.. :-)
> From: Greg Watson <gwatson at lanl.gov>
> Subject: Re: [MPICH2-dev] mpd client library and protocol?
> Date: Thu, 18 May 2006 11:15:30 -0600
>> Rajeev,
>> Sorry for not being clearer. Yes, I need to be able to control an
>> MPI program, not implement MPI or a process manager. I'm exploring
>> the possibility of using Eclipse (via the Parallel Tools Platform) to
>> manage the launch and control of MPI programs using MPICH2. The
>> architecture requires an interface between PTP (Java) and the runtime
>> system (in this case the MPICH2 process manager) that supports a few
>> basic commands (including RUN, TERMINATE, GETJOBS, GETPROCESSES,
>> etc.) and responds to certain events, such as process termination.
>> Unless you can suggest a better approach, I'm thinking of writing a
>> python program that will provide this interface to mpd. I'd prefer to
>> do it in Java or C as I'll have to re-implement a bunch of stuff in
>> python, but because of the way you serialize python objects it
>> doesn't look possible the use a non-python program to communicate
>> with mpd.
>> If you have any documentation that would assist, it would be
>> appreciated.
>> Regards,
>> Greg
>> On May 17, 2006, at 7:46 PM, Rajeev Thakur wrote:
>>> Greg,
>>> What exactly are you trying to do? That might help us figure
>>> out what
>>> might be your best option. I am attaching the document describing
>>> the PMI
>>> interface. We use use PMI to *implement* MPI. You seem to want to
>>> control
>>> MPI program. Is that right?
>>> Rajeev
>>> On Wed, 17 May 2006, Greg Watson wrote:
>>>> Bill,
>>>> I'm not sure, since I still don't really understand the
>>>> architecture.
>>>> Can I use PMI to launch and control an MPI program on a cluster? Or
>>>> is that something that will be available in the future? I would
>>>> rather not have to provide a different program for each process
>>>> manager, but cluster support is also essential.
>>>> Any information or documentation you can provide on the
>>>> architecture
>>>> and APIs would be appreciated.
>>>> Greg
>>>> On May 16, 2006, at 10:21 PM, William Gropp wrote:
>>>>> At 11:15 PM 5/16/2006, Greg Watson wrote:
>>>>>> Rajeev,
>>>>>> Many thanks for your reply. Can you suggest the best approach
>>>>>> if I
>>>>>> want to write a C program to control mpd? At a minimum, I'd
>>>>>> like to
>>>>>> be able to spawn/terminate an MPI job using a C program. Is PMI
>>>>>> what
>>>>>> I'd use to do this?
>>>>>> Any documentation you could provide would be appreciated.
>>>>> An alternative is to not use MPD at all and to use the PMI
>>>>> interface. A C example of this is the "gforker" process manager;
>>>>> this is built using a set of utility routines in mpich2/src/pm/
>>>>> util
>>>>> that provide the "other" side of the simple PMI interface.
>>>>> gforker
>>>>> implements all of the PM functions, including spawning MPI jobs.
>>>>> Let me know if this is the direction in which you are interested.
>>>>> Bill
>>>>>> Thanks,
>>>>>> Greg
>>>>>> On May 16, 2006, at 7:56 PM, Rajeev Thakur wrote:
>>>>>>> Greg,
>>>>>>>> I assume that mpdlib.py is a client library that other
>>>>>>>> applications
>>>>>>>> (i.e. other than mpiexec) could potentially use to communicate
>>>>>>>> with
>>>>>>>> and/or control mpd.
>>>>>>>> 1. Is there any API documentation?
>>>>>>> The API is the Process Manager Interface (PMI), which is the
>>>>>>> interface
>>>>>>> MPICH2 uses for interacting with process managers. There is some
>>>>>>> documentation for it, which I could send you if you like (it may
>>>>>>> not be 100%
>>>>>>> up to date).
>>>>>>>> 2. Is there a C version of the client library?
>>>>>>> The PMI library is in C. It is implemented in src/pmi/simple/
>>>>>>> simple_pmi.c.
>>>>>>>> 3. Is the mpd protocol documented anywhere?
>>>>>>> Not currently, but the plan is to :-).
>>>>>>>> 4. Is the protocol used by mpd the same as that used by smpd?
>>>>>>> No, they are different.
>>>>>>> Rajeev
>>>>> William Gropp
>>>>> http://www.mcs.anl.gov/~gropp
>>>> <paper.pdf>
More information about the mpich2-dev
