[MPICH2-dev] mpd client library and protocol?
Greg Watson gwatson at lanl.gov
Thu May 18 12:15:30 CDT 2006
Rajeev,
Sorry for not being clearer.  Yes, I need to be able to control an
MPI program, not implement MPI or a process manager. I'm exploring
the possibility of using Eclipse (via the Parallel Tools Platform) to
manage the launch and control of MPI programs using MPICH2. The
architecture requires an interface between PTP (Java) and the runtime
system (in this case the MPICH2 process manager) that supports a few
basic commands (including RUN, TERMINATE, GETJOBS, GETPROCESSES,
etc.) and responds to certain events, such as process termination.
Unless you can suggest a better approach, I'm thinking of writing a
python program that will provide this interface to mpd. I'd prefer to
do it in Java or C as I'll have to re-implement a bunch of stuff in
python, but because of the way you serialize python objects it
doesn't look possible the use a non-python program to communicate
with mpd.
If you have any documentation that would assist, it would be
appreciated.
Greg
On May 17, 2006, at 7:46 PM, Rajeev Thakur wrote:
> Greg,
>      What exactly are you trying to do? That might help us figure
> out what
> might be your best option. I am attaching the document describing
> the PMI
> interface. We use use PMI to *implement* MPI. You seem to want to
> control
> MPI program. Is that right?
> Rajeev
> On Wed, 17 May 2006, Greg Watson wrote:
>> Bill,
>> I'm not sure, since I still don't really understand the architecture.
>> Can I use PMI to launch and control an MPI program on a cluster? Or
>> is that something that will be available in the future? I would
>> rather not have to provide a different program for each process
>> manager, but cluster support is also essential.
>> Any information or documentation you can provide on the architecture
>> and APIs would be appreciated.
>> Greg
>> On May 16, 2006, at 10:21 PM, William Gropp wrote:
>>> At 11:15 PM 5/16/2006, Greg Watson wrote:
>>>> Rajeev,
>>>> Many thanks for your reply. Can you suggest the best approach if I
>>>> want to write a C program to control mpd? At a minimum, I'd like to
>>>> be able to spawn/terminate an MPI job using a C program. Is PMI
>>>> what
>>>> I'd use to do this?
>>>> Any documentation you could provide would be appreciated.
>>> An alternative is to not use MPD at all and to use the PMI
>>> interface.  A C example of this is the "gforker" process manager;
>>> this is built using a set of utility routines in mpich2/src/pm/util
>>> that provide the "other" side of the simple PMI interface.  gforker
>>> implements all of the PM functions, including spawning MPI jobs.
>>> Let me know if this is the direction in which you are interested.
>>> Bill
>>>> Thanks,
>>>> Greg
>>>> On May 16, 2006, at 7:56 PM, Rajeev Thakur wrote:
>>>>> Greg,
>>>>>> I assume that mpdlib.py is a client library that other
>>>>>> applications
>>>>>> (i.e. other than mpiexec) could potentially use to communicate
>>>>>> with
>>>>>> and/or control mpd.
>>>>>> 1. Is there any API documentation?
>>>>> The API is the Process Manager Interface (PMI), which is the
>>>>> interface
>>>>> MPICH2 uses for interacting with process managers. There is some
>>>>> documentation for it, which I could send you if you like (it may
>>>>> not be 100%
>>>>> up to date).
>>>>>> 2. Is there a C version of the client library?
>>>>> The PMI library is in C. It is implemented in src/pmi/simple/
>>>>> simple_pmi.c.
>>>>>> 3. Is the mpd protocol documented anywhere?
>>>>> Not currently, but the plan is to :-).
>>>>>> 4. Is the protocol used by mpd the same as that used by smpd?
>>>>> No, they are different.
>>>>> Rajeev
>>> William Gropp
>>> http://www.mcs.anl.gov/~gropp
>> <paper.pdf>
More information about the mpich2-dev mailing list
