[MPICH2-dev] Publish/Lookup
Rajeev Thakur thakur at mcs.anl.gov
Tue May 16 20:31:24 CDT 2006
One problem in your code is that there is no synchronization between the
call to Publish_name on the server and Lookup_name on the client. So the
client may be calling Lookup_name before the name has been published.
An example program is in test/mpi/spawn/namepub.c.
Rajeev
  _____
From: owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-dev at mcs.anl.gov] On
Behalf Of Denis Lima
Sent: Tuesday, May 16, 2006 3:54 PM
To: robl
Cc: mpich2-dev
Subject: Re: [MPICH2-dev] Publish/Lookup
Hey Rob,
I'm running the following code, and the client does not find the service
name "SERVER".
Thanks
Denis
//SERVER
#include <mpi.h>
#include <stdio.h>
int main ( int argc, char * argv[] )
 MPI_Comm newcomm;
 char port_name [MPI_MAX_PORT_NAME];
 int test = 0;
 MPI_Status status;
 MPI_Init ( &argc, &argv );
 MPI_Open_port ( MPI_INFO_NULL, port_name );
 MPI_Publish_name ( "SERVER", MPI_INFO_NULL, port_name );
 MPI_Comm_accept( port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &newcomm );
 MPI_Recv ( &test, 1, MPI_INT, 0, 1, MPI_COMM_WORLD, &status );
 printf ( "%d", test );
 MPI_Unpublish_name ( "SERVER", MPI_INFO_NULL, port_name );
 MPI_Close_port ( port_name );
 MPI_Finalize ( );
 return 0;
//CLIENT
#include <mpi.h>
#include <stdio.h>
 MPI_Comm newcomm;
 int test = 1234;
 MPI_Lookup_name ( "SERVER", MPI_INFO_NULL, port_name );
 MPI_Comm_connect ( port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &newcomm );
 MPI_Send ( &test, 1, MPI_INT, 0, 1, MPI_COMM_WORLD );
 MPI_Comm_disconnect ( &newcomm );
 MPI_Finalize ( );
 return 0;
> On Tue, May 16, 2006 at 04:07:22PM -0300, Denis Lima wrote:
> > Hello guys,
> > I'm not been able to use the Publish_name/LookUp_name functions in
> > MPICH2. Do you have any sample c code that works?
> The 'server' has to do something like this:
> MPI_Comm newcomm;
> char port_name[MPI_MAX_PORT_NAME];
> MPI_Open_port(MPI_INFO_NULL, port_name);
> MPI_Publish_name("port_name", MPI_INFO_NULL, port_name);
> MPI_Comm_accept(port_name, MPI_INFO_NULL, 0, comm, &newcomm);
> And the 'client':
> MPI_Comm newcomm;
> MPI_Lookup_name("port_name", MPI_INFO_NULL, port_name);
> MPI_Comm_connect(port_name, MPI_INFO_NULL, 0, comm, &newcomm);
> Naturally, use whatever you like instead of "port_name". Also, i've
> omitted checking return values. You'll need an MPD ring up and running
> for this to work. Can you elaborate on what is not working for you?
> ==rob
> Rob Latham
> Mathematics and Computer Science Division A215 0178 EA2D B059 8CDF
> Argonne National Labs, IL USA B29D F333 664A 4280 315B
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20060516/5d42573b/attachment.htm>
More information about the mpich2-dev mailing list
