[MPICH2-dev] Publish/Lookup
Robert Latham robl at mcs.anl.gov
Tue May 16 14:30:17 CDT 2006
On Tue, May 16, 2006 at 04:07:22PM -0300, Denis Lima wrote:
> Hello guys,
> I'm not been able to use the Publish_name/LookUp_name functions in
> MPICH2.  Do you have any sample c code that works?
The 'server' has to do something like this:
        MPI_Comm newcomm;
        char port_name[MPI_MAX_PORT_NAME];
        MPI_Open_port(MPI_INFO_NULL, port_name);
        MPI_Publish_name("port_name", MPI_INFO_NULL, port_name);
        MPI_Comm_accept(port_name, MPI_INFO_NULL, 0, comm, &newcomm);
And the 'client':
        MPI_Comm newcomm;
        MPI_Lookup_name("port_name", MPI_INFO_NULL, port_name);
        MPI_Comm_connect(port_name, MPI_INFO_NULL, 0, comm, &newcomm);
Naturally, use whatever you like instead of "port_name".  Also, i've
omitted checking return values. You'll need an MPD ring up and running
for this to work.  Can you elaborate on what is not working for you?
==rob
Rob Latham
Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
Argonne National Labs, IL USA                B29D F333 664A 4280 315B
More information about the mpich2-dev mailing list
