[MPICH2-dev] mpich-test/pt2pt/allpair2 test case issue.
Rajeev Thakur thakur at mcs.anl.gov
Mon Mar 27 14:00:02 CST 2006
Yes, this bug has been fixed in our CVS. Here is the latest file.
Rajeev
  _____
From: owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-dev at mcs.anl.gov] On
Behalf Of Sapronov, Sergey
Sent: Monday, March 27, 2006 6:22 AM
To: mpich2-dev at mcs.anl.gov
Cc: Supalov, Alexander; Voronov, German; Sapronov, Sergey
Subject: [MPICH2-dev] mpich-test/pt2pt/allpair2 test case issue.
Dear Sirs,
allpair2.f test case from mpich-test/pt2pt test suite fails sometimes with
the following output:
< Fatal error (code 0x4009430f) in MPI_Test():
< MPI_Test(154): MPI_Test(request=0x60000fffffff7684,
flag=0x60000fffffff7620, status=0x60000fffffff76b0) failed
< MPIDI_CH3U_Handle_recv_pkt(245): Ready send from source 0 and with tag
3456 had no matching receive
< ABORT - process 1
The failure happens in 'Persistent ready sends' section (start line #460 in
allpair2.f source).
I guess the test case handles persistent ready send incorrectly.
According to standard "A send that uses the ready communication mode may be
started only if the matching receive is already posted. Otherwise, the
operation is erroneous and its outcome is undefined."
In our case, process 0 starts ready send operation (line #484 : call
MPI_Startall(2, requests, ierr))
and process 1 starts corresponding receive operation (line #501: call
MPI_Start(requests(2), ierr))
without any synchronizing actions. Thus, the test case does not guarantee
that receive is posted before ready send start.
I believe allpair2.f test case should be fixed similar to 'Persistent ready
sends' section fixing in analogous allpair.f test case.
What is your opinion?
Perhaps, the issue has been already fixed. And we can only take new version
of the test suite?
Currently we use allpair2.f test case updated 2 Jul. 2004.
Thank you.
Best Regards.
Sergey Sapronov
Senior Software Engineer,
Intel SSG/DPD/Parallel Solution Lab,
Russia, Sarov.
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20060327/009335a0/attachment.htm>
Desc: not available
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20060327/009335a0/attachment.obj>
More information about the mpich2-dev mailing list
