[MPICH2-dev] Error creating custom MPI Type struct
Rajeev Thakur
thakur at mcs.anl.gov
Wed Apr 26 15:00:15 CDT 2006
This code runs on Linux without any problem. You are running on Windows I
believe. I don't know about the Windows version. In the mpi.h file, just
check wether the #defines for the datatypes appear meaningful (not 0 for
example). In my Linux build, it looks something like:
#define MPI_CHAR ((MPI_Datatype)0x4c000101)
#define MPI_SIGNED_CHAR ((MPI_Datatype)0x4c000118)
#define MPI_UNSIGNED_CHAR ((MPI_Datatype)0x4c000102)
#define MPI_BYTE ((MPI_Datatype)0x4c00010d)
#define MPI_WCHAR ((MPI_Datatype)0x4c00040e)
#define MPI_SHORT ((MPI_Datatype)0x4c000203)
#define MPI_UNSIGNED_SHORT ((MPI_Datatype)0x4c000204)
#define MPI_INT ((MPI_Datatype)0x4c000405)
#define MPI_UNSIGNED ((MPI_Datatype)0x4c000406)
#define MPI_LONG ((MPI_Datatype)0x4c000407)
#define MPI_UNSIGNED_LONG ((MPI_Datatype)0x4c000408)
#define MPI_FLOAT ((MPI_Datatype)0x4c00040a)
#define MPI_DOUBLE ((MPI_Datatype)0x4c00080b)
#define MPI_LONG_DOUBLE ((MPI_Datatype)0x4c000c0c)
#define MPI_LONG_LONG_INT ((MPI_Datatype)0x4c000809)
#define MPI_UNSIGNED_LONG_LONG ((MPI_Datatype)0x4c000819)
#define MPI_LONG_LONG MPI_LONG_LONG_INT
#define MPI_PACKED ((MPI_Datatype)0x4c00010f)
#define MPI_LB ((MPI_Datatype)0x4c000010)
#define MPI_UB ((MPI_Datatype)0x4c000011)
Rajeev
> -----Original Message-----
> From: owner-mpich2-dev at mcs.anl.gov
> [mailto:owner-mpich2-dev at mcs.anl.gov] On Behalf Of Shankar,
> Shashank (US - New York)
> Sent: Wednesday, April 26, 2006 2:32 PM
> To: Rusty Lusk
> Cc: mpich2-dev at mcs.anl.gov; mpich2-maint at mcs.anl.gov
> Subject: RE: [MPICH2-dev] Error creating custom MPI Type struct
> Hello Rusty,
> As the custom datatype is slightly large, I am attaching a text file
> that contains the code defining the c datatype, and the function to
> create the MPI data type.
> Thanks!
> Regards,
> Shashank Shankar
> Consultant/Enterprise Business Integration/Technology Integration,
> Deloitte Consulting LLP
> Tel: +1 212 618 4702
> Mobile: + 1 281 636 8712
> From: Rusty Lusk [mailto:lusk at mcs.anl.gov]
> Sent: Wednesday, April 26, 2006 3:20 PM
> To: Shankar, Shashank (US - New York)
> Subject: Re: [MPICH2-dev] Error creating custom MPI Type struct
> Can you send the code that constructs and commits this
> dataype? Thanks.
> From: "Shankar, Shashank (US - New York)" <shashankar at deloitte.com>
> Subject: [MPICH2-dev] Error creating custom MPI Type struct
> Date: Wed, 26 Apr 2006 15:03:27 -0400
> > Hello,
> > Thanks to John Vert, for answering my previous question!
> > I am trying to develop a distributed application utilizing
> MPI as the
> > communication mechanism, and have run into an error while creating a
> > custom MPI Type struct for data transfer between MPI processes. A
> > snippet from the mpiexec output is as:
> > job aborted:
> > rank: node: exit code[: error message]
> > 0: socw3s4ap01.solnet.com: 13
> > 1: socw3s4ap01.solnet.com: 13: Fatal error in
> MPI_Type_struct: Invalid
> > datatype, error stack:
> > MPI_Type_struct(191): MPI_Type_struct(count=365,
> blocklens=0x0012EDAC,
> > indices=0x0012E244,
> > old_types=0x0012E7F8, new_type_p=0x0046C854) failed
> > MPI_Type_struct(130): Invalid datatype
> > Any help or suggestions in this regards will be very appreciated.
> > Thanks!
> > Regards,
> > Shashank Shankar
> > This message (including any attachments) contains confidential
> information intended for a specific individual and purpose, and is
> protected by law. If you are not the intended recipient, you should
> delete this message.
> > Any disclosure, copying, or distribution of this message, or the
> taking of any action based on it, is strictly prohibited. [v.E.1]
More information about the mpich2-dev
