[MPICH2-dev] fortran 90 compiling error on G5
Heinz, Michael mheinz at silverstorm.com
Wed Sep 7 12:46:36 CDT 2005
I haven't tried building for xlf90 on mac yet, but past experience makes me think this is a problem with blending GCC libraries with xlf90 code.
I would suggest doing an
nm libmpich.a | grep mpi_init
and looking at the result. I suspect that you will find the mpi_init in the library is called "__mpi_init" instead of "_mpi_init".
You probably want to see what IBM has to say about linking xlf90 code with gcc code and vice-versa. They may have compiler options to deal with this.
-----Original Message-----
Sent: Wednesday, September 07, 2005 12:02 PM
To: mpich2-dev at mcs.anl.gov
Subject: [MPICH2-dev] fortran 90 compiling error on G5
Dear Mpich2 Developers
I meet some problems with compiling fortran file using mpif90, I
don't know whether it is a bug
I installed the MPICH2 on my Mac G5 following the document. The steps
are
1, configure --prefix=/usr/local --enable-f90
2, make
3, sudo make install
The fortran compiler on my G5 is the xlf90 from IBM.
Everything goes well until I tried to compile some fortran90 file
like the on given in the examples/f90/pi3f90.f90
the err is strange :
/usr/bin/ld: Undefined symbols:
_mpi_init
_mpi_comm_rank
_mpi_comm_size
_mpi_bcast
_mpi_reduce
_mpi_finalize
I tried the mpif90 -show, the result is
f90 -I/usr/local/include -I/usr/local/include -L/usr/local/lib -
lmpichf90 -lmpichf90 -lpmpich -lmpich
That's what I can do so far. I don't  know whether this is a bug or
because of some mistake I made during the installation. I also attach
the config.log
More information about the mpich2-dev mailing list
