[MPICH2-dev] MPICH2/baseattrwinf90 fails on testing
Derbunovich, Andrey
andrey.derbunovich at intel.com
Wed Oct 12 05:29:24 CDT 2005
Dear All,
We have found bug in the implementation of Fortran binding for
MPI_Win_get_attr function. It does not work correctly for 64-bit
platform like x86_64 (EM64t). The tests showing problem are
test/mpi/f77/attr/baseattrwinf.f and corresponding
test/mpi/f90/attr/baseattrwinf90.f90.
Problem description:
1. The 3-rd argument passed to MPI_win_get_attr function should be
big enough to fit address value. But in the baseattrwinf tests this
parameter defined as INTEGER*4 which is too short for 64-bit
architecture. We suggest that definition should be changed to INTEGER
(kind=MPI_ADDRESS_KIND) for f90 test and automatically changed at
configuration phase to INTEGER*8 for f77 test.
2. There is a wrong data assignment in the MPI_win_get_attr()
function. Data of MPI_Aint type (actually long) assigned to variable
MPI_Fint type (actually int). Look at the src/mpi/attr/win_get_attr.c
(lines 140, 145). This is not correct operation on 64-bit platform like
em64t because may cause data lost or memory garbage in the Fortran
application. There is a suggestion to change definition of internal
variable attr_int in the MPI_Win_get_attr function from MPI_Fint to
MPI_Aint to avoid such behavior. You could find the suggested patch
below.
--- win_get_attr.c.ori 2005-10-06 19:40:13.000000000 +0400
+++ win_get_attr.c 2005-10-06 19:40:59.000000000 +0400
@@ -112,7 +112,7 @@
int attr_idx = win_keyval & 0x0000000f;
void **attr_val_p = (void **)attribute_val;
#ifdef HAVE_FORTRAN_BINDING
- MPI_Fint *attr_int = (MPI_Fint *)attribute_val;
+ MPI_Aint *attr_int = (MPI_Aint *)attribute_val;
#endif
*flag = 1;
Best regards,
Andrey
Andrey Derbunovich E-mail: Andrey.Derbunovich at intel.com
<blocked::mailto:Andrey.Derbunovich at intel.com>
Intel Phone: +7 (831 30)70 700
Sarov, Russia iNET: 313-2480
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20051012/0af6b42a/attachment.htm>
More information about the mpich2-dev
