[MPICH2-dev] [patch] create valid default defmsg.h if  building one fails
    William Gropp
    gropp at mcs.anl.gov
    Thu Oct  6 10:08:28 CDT 2005
At 11:38 AM 10/5/2005, Ashley Pittman wrote:
>Hi,
>We've hit a bug several times now where we add error codes to the source
>without writing a long description for it, this in turn causes
>maint/extracterrmsgs to fail (as it should) but the fallback defmsg.h
>that updatefiles creates is un-usable leading to compile errors later
>on.
>This patch causes the fallback file to be generated properly.  It's
>tested in so much as the code compiles but I haven't tried running any
>code with it yet, I'll let you know the results of the testsuite
>tomorrow.
Thanks for the patch, I've applied it and will check it in today.
Bill
>Ashley,
>Index: maint/updatefiles
>RCS file: /cvs/master/quadrics/mpi2/mpich2/maint/updatefiles,v
>retrieving revision 1.1.1.2
>retrieving revision 1.4
>diff -u -3 -p -r1.1.1.2 -r1.4
>--- maint/updatefiles   23 Jun 2005 13:56:39 -0000      1.1.1.2
>+++ maint/updatefiles   5 Oct 2005 16:30:50 -0000       1.4
>@@ -287,18 +287,19 @@ Error message files in src/mpi/errhan we
>          if [ ! -s src/mpi/errhan/defmsg.h ] ; then
>              echo "Creating a dummy defmsg.h file"
>             cat > src/mpi/errhan/defmsg.h <<EOF
>-typedef struct { const char *short_name, *long_name; } msgpair;
>+typedef struct { const unsigned int sentinal1; const char *short_name,
>*long_name; const unsigned int sentinal2; } msgpair;
>  static const int generic_msgs_len = 0;
>-static msgpair generic_err_msgs[] { {0, "no error catalog"}, };
>+static msgpair generic_err_msgs[] = { {0xacebad03, 0, "no error
>catalog", 0xcb0bfa11}, };
>  static const int specific_msgs_len = 0;
>-static msgpair specific_err_msgs[] {  {0,0}, };
>+static msgpair specific_err_msgs[] = {  {0xacebad03,0,0,0xcb0bfa11}, };
>  static int class_to_index[] = {
>  0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
>-0, 0, 0, 0 }
>+0, 0, 0, 0 };
>+#define MPIR_MAX_ERROR_CLASS_INDEX 1
>  EOF
>          fi
>      fi
William Gropp
http://www.mcs.anl.gov/~gropp
More information about the mpich2-dev
