[MPICH2-dev] problem with "read-modife-write" in ADIOI_NFS_WriteStrided() function on IPF SLES9 systems
Ryzhykh, Alexey
alexey.ryzhykh at intel.com
Fri Dec 2 09:15:56 CST 2005
Hi all,
I got the following failure on SLES9 IPF system for one node and 2 processes:
# Benchmarking P_Write_Indv
# #processes = 2
# MODE: NON-AGGREGATE
#bytes #repetitions t_min[usec] t_max[usec] t_avg[usec] Mbytes/sec defects
0 10 51.19 54.10 52.64 0.00 0.00
1 10 12967.40 14173.91 13570.65 0.00 0.00
2 10 13039.40 14255.71 13647.56 0.00 0.00
4 10 12352.80 13607.41 12980.10 0.00 0.00
8 10 18121.31 19392.51 18756.91 0.00 0.00
16 10 18214.11 19414.11 18814.11 0.00 0.00
32 10 18416.62 19636.30 19026.46 0.00 0.00
64 10 18043.02 19242.60 18642.81 0.00 0.00
128 10 18240.69 19533.30 18887.00 0.01 0.00
256 10 18082.09 19281.48 18681.79 0.01 0.00
512 10 18573.50 19767.50 19170.50 0.02 0.00
2: read fail fd=10 offset=2048 bufflen=1024 buf=0x20000000049dc010
read error:: Input/output error
MPI error 497025056 occurred
7!: error code=497025056
30!: file write fail 497025056
Other I/O error , error stack:
(unknown)(): Other I/O error
I investigated this failure and found that it appears due to call of read () function inside function ADIOI_NFS_WriteStrided() for "read-modify-write", file romio/adio/ad_nfs/ad_nfs_write.c.
Below is the piece of code showing such read() operations:
/* initial read for the read-modify-write */
writebuf_off = offset;
writebuf = (char *) ADIOI_Malloc(max_bufsize);
writebuf_len = (int)(ADIOI_MIN(max_bufsize,end_offset-writebuf_off+1));
if (!(fd->atomicity)) ADIOI_WRITE_LOCK(fd, writebuf_off, SEEK_SET, writebuf_len);
lseek(fd->fd_sys, writebuf_off, SEEK_SET); \
err = read(fd->fd_sys, writebuf, writebuf_len);
This read sometimes fails with errno equal to EIO
Description from man:
EIO I/O error. This will happen for example when the process is in a
background process group, tries to read from its controlling
tty, and either it is ignoring or blocking SIGTTIN or its pro-
cess group is orphaned. It may also occur when there is a low-
level I/O error while reading from a disk or tape.
I think this kernel or NFS specific issue because there are no any causes for this error.
And all work fine on other Linux.
I suggest the following fix for this problem is to replace all "read-modify-write"
by
int i;
for( i=0; i<I_MPI_NREAD_ATTEMPTS; i++) {
if( (err == 0 ) || (errno != EIO)) break;
Attached is the patch for file romio/adio/ad_nfs/ad_nfs_write.c.
With best regards,
Alexey Ryzhykh
Intel Sarov,
Russia
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20051202/75d1a0d5/attachment.htm>
Desc: ad_nfs_write.c.diff
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20051202/75d1a0d5/attachment.obj>
More information about the mpich2-dev
