[MPICH2-dev] X-Virus-Scanned: by amavisd-new-20030616-p10 (Debian) at mailgw.mcs.anl.gov
lunasole at interfree.it lunasole at interfree.it
Mon Aug 1 09:38:07 CDT 2005
Hi
I impemented a simple application Client/Server using Name Publishing.
I launched Server with mpiexec command. The Server associated a port name with a private name "SERVER".  After I
launched client on another machine. It looked the port name up by passing name "SERVER" to MPI_Lookup_name.
with LAM I have no problem for this implementation.
with MPICH2 i have the following error message on client side:
        ercole Name_Server]$ mpiexec -n 1 -path sample_MPICH2_MPI/MPI-2/Name_Server/ client
        Port_name= port#32867$description#ercole$rank 0 in job 1  ercole_32771   causedcollective abort of all ranks
exit status of rank 0: killed by signal 9
What is the problem?
Thank's.
   Rosalia Salvatore
Client and Server implementation:
//SERVER
#include <stdio.h>
#include <mpi.h>
#define NUM_LOOP 200
#define MAX_DATA 200
#define TIMER_ELAPSED \
 ( ( tv2.tv_usec - tv1.tv_usec ) \
  + ( ( tv2.tv_sec - tv1.tv_sec) * 1.E6 ) )
int main (int argc, char* argv[])
 int rank, size,again,i;
 static int count=0;
 MPI_Comm client;
 MPI_Status status;
 char port_name[MPI_MAX_PORT_NAME];
 double buf[MAX_DATA];
 int time[NUM_LOOP];
 MPI_Init(&argc,&argv); /* Initialize MPI */
 MPI_Comm_rank(MPI_COMM_WORLD, &rank); /* Get rank */
 MPI_Comm_size(MPI_COMM_WORLD,&size); /* Get size of the LAM universe */
 if (size != 1)
  printf("Error");
  return -1;
 //printf("CIAO\n");
 MPI_Open_port (MPI_INFO_NULL,port_name);
 printf("port_name= %s\n", port_name);
 MPI_Publish_name("SERVER",MPI_INFO_NULL,port_name);
 printf("waiting...\n");
 while(1)
  MPI_Comm_accept (port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &client);
  again=1;
  while (again == 1)
   printf("\nReceive\n");
   MPI_Recv(buf,MAX_DATA,MPI_DOUBLE,MPI_ANY_SOURCE,MPI_ANY_TAG, client, &status);
   MPI_Send(buf, MAX_DATA, MPI_DOUBLE, 0, 2, client);
   printf("MPI_TAG =%d\n ", status.MPI_TAG);
   switch(status.MPI_TAG)
    case 0:
     MPI_Comm_free(&client);
     MPI_Close_port(port_name);
     MPI_Finalize();
     return 0;
    case 1:
					MPI_Comm_disconnect(&client);
					again =0;
					break;
				case 2:
					//for (i=0;i<MAX_DATA;i++)
					printf("buf[%d]= %f",1,buf[1]);
					//}//end for
					break;
				default:
     MPI_Abort (MPI_COMM_WORLD,1);
     break;
   } //end of switch
  } //end while again
} //infinity
// CLIENT
#include <stdio.h>
#include <mpi.h>
#include <sys/time.h>
#define LOOP 10000
 int rank, size,i, tag=0, done=1;
 MPI_Comm server;
 MPI_Status status;
 double var=0.0;
   int time[LOOP];
 struct timeval tv1, tv2;
 FILE *fp;
 long max=0, min=20000000;
 //MPI_Comm_size(MPI_COMM_WORLD,&size); /* Get size of the LAM universe */
 MPI_Lookup_name("SERVER", MPI_INFO_NULL, port_name);
 printf("\nMPI_Lookup_name Port_name= %s", port_name);
 MPI_Comm_connect (port_name, MPI_INFO_NULL,0, MPI_COMM_WORLD, &server);
  buf[i]= i*2.0;
  //printf("buf[%d]= %f\t",i,buf[i]);
 tag=2;
 for(i=0;i<LOOP;i++)
  gettimeofday(&tv1, NULL);
  MPI_Send(buf, MAX_DATA, MPI_DOUBLE, 0, tag, server);
  MPI_Recv(buf,MAX_DATA,MPI_DOUBLE,MPI_ANY_SOURCE,MPI_ANY_TAG, server, &status);
  gettimeofday(&tv2, NULL);
  time[i]=(int)TIMER_ELAPSED;
  printf("\nsend and receive con buf[%d]= %f\n",1,buf[1]);
  printf("Client Tempo[%d]= %d\n",i, time[i]);
 } //end for
 tag=1;
	printf("\nSend con tag 1\n");
	MPI_Comm_disconnect(&server);
	MPI_Finalize();
	/* *************** TIME RESULTS ***************** */
	fp= fopen("Results.txt","w");
	for(i=0;i<LOOP;i++)
		fprintf(fp,"%d    %ld \n", i+1 ,time[i]);
		var=var+time[i];
		if(time[i]<min) min=time[i];
    		if(time[i]>max) max=time[i];
	var=var/LOOP-1;
	printf("Tempo del client %d = %f usec\n",rank,var);
 fprintf(fp,"LATENCY TIME MIN = %ld microsec\n", min);
 fprintf(fp,"LATENCY TIME MAX = %ld microsec\n", max);
 fprintf(fp,"LATENCY TIME AVERAGE = %f microsec\n", var);
 fclose (fp);
 return 0;
Visita http://domini.interfree.it, il sito di Interfree dove trovare
soluzioni semplici e complete che soddisfano le tue esigenze in Internet,
ecco due esempi di offerte:
-  Registrazione Dominio: un dominio con 1 MB di spazio disco +  2 caselle
   email a soli 18,59 euro
-  MioDominio: un dominio con 20 MB di spazio disco + 5 caselle email
   a soli 51,13 euro
Vieni a trovarci!
Lo Staff di Interfree
More information about the mpich2-dev mailing list
