[MPICH2-dev] Freeing context IDs, error handling in MPI_Win_create()
Doug Gilmore dgilmore at cray.com
Fri Sep 12 20:20:49 CDT 2003
I tracked down the following problems when testing the
MPICH2-0.94b1 release on RMA test in the Pallas performance
suite.  The test creates and deletes many RMA windows
so the problem in freeing context IDs was exposed
very quickly.
Also in MPID_Win_create() there is some error path
cleanup that should probably be attended to, such as
freeing allocations done before the error was detected.
Doug
*** commutil.c.~1.1.1.6~	Fri Sep 12 15:56:52 2003
--- commutil.c	Fri Sep 12 16:34:08 2003
*** 167,175 ****
      int idx, bitpos;
      /* Convert the context id to the bit position */
      /* printf( "Freeed id = %d\n", context_id ); */
!     context_id <<= 2;       /* Remove the shift of a factor of four */
!     idx = context_id % 32;
!     bitpos = context_id / 32;
      context_mask[idx] |= (0x1 << bitpos);
--- 167,175 ----
      int idx, bitpos;
!     context_id >>= 2;       /* Remove the shift of a factor of four */
!     idx = context_id / 32;
!     bitpos = context_id % 32;
*** win_create.c.~1.1.1.4~	Fri Sep 12 17:19:41 2003
--- win_create.c	Fri Sep 12 17:20:43 2003
*** 106,112 ****
  #   endif /* HAVE_ERROR_CHECKING */
!     MPID_Win_create(base, size, disp_unit, info, comm_ptr, &win_ptr);
      /* return the handle of the window object to the user */
      *win = win_ptr->handle;
--- 106,113 ----
!     if (mpi_errno = MPID_Win_create(base, size, disp_unit, info, comm_ptr, &win_ptr))
! 	return mpi_errno;
More information about the mpich2-dev mailing list
