[mpich2-commits] r9549 - in mpich2/trunk: . doc/logging doc/windev maint src/mpe2/src/slog2sdk/doc/jumpshot-4/tex src/mpe2/src/slog2sdk/maint src/mpi/errhan src/mpid/globus src/util/param
balaji at mcs.anl.gov balaji at mcs.anl.gov
Tue Feb 28 17:26:44 CST 2012
Author: balaji
Date: 2012-02-28 17:26:43 -0600 (Tue, 28 Feb 2012)
New Revision: 9549
Added:
   mpich2/trunk/autogen.sh
Removed:
   mpich2/trunk/maint/updatefiles
Modified:
   mpich2/trunk/Makefile.am
   mpich2/trunk/README.vin
   mpich2/trunk/configure.ac
   mpich2/trunk/doc/logging/logging.tex
   mpich2/trunk/doc/windev/getdotin.bat
   mpich2/trunk/doc/windev/testmpich2.wsf
   mpich2/trunk/doc/windev/windev.tex.vin
   mpich2/trunk/maint/Makefile.mk
   mpich2/trunk/maint/release.pl
   mpich2/trunk/src/mpe2/src/slog2sdk/doc/jumpshot-4/tex/rm_html_scale_fig
   mpich2/trunk/src/mpe2/src/slog2sdk/maint/make_slog2update.txt
   mpich2/trunk/src/mpi/errhan/Makefile.mk
   mpich2/trunk/src/mpid/globus/Makefile.sm
   mpich2/trunk/src/util/param/Makefile.mk
Log:
Move maint/updatefiles to autogen.sh to make the naming consistent
with other projects.
Modified: mpich2/trunk/Makefile.am
--- mpich2/trunk/Makefile.am	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/Makefile.am	2012-02-28 23:26:43 UTC (rev 9549)
@@ -17,7 +17,7 @@
 BUILT_SOURCES =
 bin_PROGRAMS =
 bin_SCRIPTS =
-dist_noinst_SCRIPTS =
+dist_noinst_SCRIPTS = autogen.sh
 noinst_DATA =
 dist_noinst_DATA =
 noinst_HEADERS =
@@ -123,7 +123,7 @@
 EXTRA_DIST += README CHANGES COPYRIGHT README.envvar
 # README.vin is tricky, we don't actually distribute it when we use release.pl,
-# but we do need to distribute it in order for ./maint/updatefiles to work
+# but we do need to distribute it in order for ./autogen.sh to work
 # correctly on a distribution tarball.  For now we distribute it when we "make
 # dist".
 EXTRA_DIST += README.vin
Modified: mpich2/trunk/README.vin
--- mpich2/trunk/README.vin	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/README.vin	2012-02-28 23:26:43 UTC (rev 9549)
@@ -946,7 +946,7 @@
     Bring up a cygwin bash shell.
     cd mpich2
-    maint/updatefiles
+    ./autogen.sh
     exit
 (d) Execute winconfigure.wsf
Copied: mpich2/trunk/autogen.sh (from rev 9548, mpich2/trunk/maint/updatefiles)
--- mpich2/trunk/autogen.sh	                        (rev 0)
+++ mpich2/trunk/autogen.sh	2012-02-28 23:26:43 UTC (rev 9549)
@@ -0,0 +1,1076 @@
+#! /bin/sh
+# (C) 2006 by Argonne National Laboratory.
+#     See COPYRIGHT in top-level directory.
+# Update all of the derived files
+# For best performance, execute this in the top-level directory.
+# There are some experimental features to allow it to be executed in
+# subdirectories
+# Eventually, we want to allow this script to be executed anywhere in the
+# mpich tree.  This is not yet implemented.
+## Utility functions
+recreate_tmp() {
+    rm -rf .tmp
+    mkdir .tmp 2>&1 >/dev/null
+warn() {
+    echo "===> WARNING: $@"
+error() {
+    echo "===> ERROR:   $@"
+echo_n() {
+    # "echo -n" isn't portable, must portably implement with printf
+    printf "%s" "$*"
+# Assume Program's install-dir is <install-dir>/bin/<prog>.
+# Given program name as the 1st argument,
+# the install-dir is returned is returned in 2nd argument.
+# e.g., ProgHomeDir libtoolize libtooldir.
+ProgHomeDir() {
+    prog=$1
+    progpath="`which $prog`"
+    progbindir="`dirname $progpath`"
+    proghome=`(cd $progbindir/.. && pwd)`
+    eval $2=$proghome
+## Run any local pre-update hooks
+if test -d maint/hooks/pre ; then
+    for hook in `ls maint/hooks/pre/* 2>/dev/null` ; do
+        if test -x "$hook" ; then
+            echo_n "executing pre-update hook '$hook'... "
+            ./$hook
+            echo done
+        else
+            warn "unable to execute pre-update hook: '$hook'"
+        fi
+    done
+fi
+echo
+echo "##################################"
+echo "## Checking user environment"
+echo
+## Checks to make sure we are running from the correct location
+echo_n "Verifying the location of autogen.sh... "
+if [ ! -d maint -o ! -s maint/simplemake.in ] ; then
+    echo "must execute at top level directory for now"
+    exit 1
+fi
+echo "done"
+## Version checks for svn in developer builds
+# Sanity check that any relative path svn:externals are present.  An
+# SVN version >=1.5 is needed to understand the relative path
+# externals format.  Such externals are used in particular for mpl in
+# hydra and all non-root confdbs.
+# Check for a particular file, not just the directory because several
+# autotools steps (such as libtoolize) will create the aux/macro dir.
+echo_n "Checking for svn checkout errors... "
+svn_externals_sanity_file="src/pm/hydra/version.m4"
+# Note that -e is not an available option for test in the Bourne shell, though
+# some systems that pretend that ksh is the same as sh will accept it.
+if test "!" -f $svn_externals_sanity_file ; then
+    cat <<EOT
+ERROR: The file '$svn_externals_sanity_file'
+is not present, indicating that you do not have a complete source tree.
+This is usually caused by checking out MPICH2 with an SVN client version
+less than v1.6.  Please check your SVN client version (with
+"svn --version") and use a newer version if necessary to obtain MPICH2.
+If you do have a modern SVN client and believe that you have reached
+this error case for some other reason, please file a ticket at:
+  https://trac.mcs.anl.gov/projects/mpich2/newticket
+EOT
+    exit 1
+fi
+echo "done"
+## Initialize variables to default values (possibly from the environment)
+# Default choices
+do_bindings=yes
+do_geterrmsgs=yes
+do_getparms=yes
+do_f77=yes
+do_f77tof90=yes
+do_build_configure=yes
+do_genstates=yes
+do_smpdversion=yes
+do_atdir_check=no
+do_atver_check=yes
+do_subcfg_m4=yes
+export do_build_configure
+# Allow MAKE to be set from the environment
+MAKE=${MAKE-make}
+# externals are the directories for external packages that we have
+# included into MPICH2
+externals="src/mpe2 src/pm/hydra src/mpi/romio src/mpix/armci src/pm/mpd src/openpa"
+# amdirs are the directories that make use of autoreconf
+amdirs=". src/mpl"
+autoreconf_args="-if"
+export autoreconf_args
+## Read the command-line arguments
+# List of steps that we will consider (We do not include depend
+# because the values for depend are not just yes/no)
+AllSteps="geterrmsgs bindings f77 f77tof90 build_configure genstates smpdversion getparms"
+stepsCleared=no
+for arg in "$@" ; do
+    case $arg in
+	-echo)
+	    set -x
+	-atdircheck=*)
+	    val=`echo X$arg | sed -e 's/^X-atdircheck=//'`
+            case $val in
+		yes|YES|true|TRUE|1) do_atdir_check=yes ;;
+		no|NO|false|FALSE|0) do_atdir_check=no ;;
+		*) warn "unknown option: $arg."
+            esac
+	-atvercheck=*)
+            val=`echo X$arg | sed -e 's/^X-atvercheck=//'`
+            case $val in
+		yes|YES|true|TRUE|1) do_atver_check=yes ;;
+		no|NO|false|FALSE|0) do_atver_check=no ;;
+            esac
+	-do=*|--do=*)
+	    opt=`echo A$arg | sed -e 's/^A--*do=//'`
+	    case $opt in
+		build-configure|configure) opt=build_configure ;;
+	    esac
+	    var=do_$opt
+	    # Check that this opt is known
+	    eval oldval=\$"$var"
+	    if [ -z "$oldval" ] ; then
+		echo "-do=$opt is unrecognized"
+		exit 1
+	    else
+		if [ $stepsCleared = no ] ; then
+		    for step in $AllSteps ; do
+			var=do_$step
+			eval $var=no
+		    done
+		    stepsCleared=yes
+		fi
+		var=do_$opt
+		eval $var=yes
+	    fi
+        -verbose-autoreconf|--verbose-autoreconf)
+            autoreconf_args="-vif"
+            export autoreconf_args
+	-with-genstates|--with-genstates)
+	    do_genstates=yes
+	-without-genstates|--without-genstates)
+	    do_genstates=no
+	-with-errmsgs|--with-errmsgs)
+	    do_geterrmsgs=yes
+	-without-errmsgs|--without-errmsgs)
+	    do_geterrmsgs=no
+	-with-bindings|--with-bindings)
+	    do_bindings=yes
+	-without-bindings|--without-bindings)
+	    do_bindings=no
+	-with-f77|--with-f77)
+	    do_f77=yes
+	-without-f77|--without-f77)
+	    do_f77=no
+	-with-autotools=*|--with-autotools=*)
+	    autotoolsdir=`echo "A$arg" | sed -e 's/.*=//'`
+	-help|--help|-usage|--usage)
+	    cat <<EOF
+   ./autogen.sh [ --with-autotools=dir ] \\
+                [ -atdircheck=[yes|no] ] \\
+                [ -atvercheck=[yes|no] ] \\
+                [ --verbose-autoreconf ] \\
+                [ --do=stepname ] [ -distrib ] [ args for simplemake ]
+    Update the files in the MPICH2 build tree.  This file builds the
+    configure files, creates the Makefile.in files (using the simplemake
+    program), extracts the error messages.
+    You can use --with-autotools=dir to specify a directory that
+    contains alternate autotools.
+    -atdircheck=[yes|no] specifies the enforcement of all autotools
+    should be installed in the same directory.
+    -atvercheck=[yes|no] specifies if the check for the version of
+    autotools should be carried out.
+    -distrib creates a distribution version of the Makefile.in files (no
+    targets for updating the Makefile.in from Makefile.sm or rebuilding the
+    autotools targets).  This does not create the configure files because
+    some of those depend on rules in the Makefile.in in that directory.
+    Thus, to build all of the files for a distribution, run autogen.sh
+    twice, as in
+         autogen.sh && autogen.sh -distrib
+    Use --do=stepname to update only a single step.  For example,
+    --do=build_configure only updates the configure scripts.  The available
+    steps are:
+EOF
+		echo "        $step"
+	    done
+	    exit 1
+	    echo "unknown argument $arg"
+	    exit 1
+    esac
+done
+## Check for the location of autotools
+if [ -z "$autotoolsdir" ] ; then
+    autotoolsdir=$MPICH2_AUTOTOOLS_DIR
+fi
+if [ -n "$autotoolsdir" ] ; then
+    if [ -x $autotoolsdir/autoconf -a -x $autotoolsdir/autoheader ] ; then
+        autoconf=$autotoolsdir/autoconf
+        autoheader=$autotoolsdir/autoheader
+        autoreconf=$autotoolsdir/autoreconf
+        automake=$autotoolsdir/automake
+        autom4te=$autotoolsdir/autom4te
+        aclocal=$autotoolsdir/aclocal
+        if [ -x "$autotoolsdir/glibtoolize" ] ; then
+            libtoolize=$autotoolsdir/glibtoolize
+        else
+            libtoolize=$autotoolsdir/libtoolize
+        fi
+	# Simplemake looks in environment variables for the autoconf
+	# and autoheader to use
+	AUTOCONF=$autoconf
+	AUTOHEADER=$autoheader
+        AUTORECONF=$autoreconf
+        AUTOMAKE=$automake
+	AUTOM4TE=$autom4te
+        ACLOCAL=$aclocal
+        LIBTOOLIZE=$libtoolize
+	export AUTOCONF
+	export AUTOHEADER
+        export AUTORECONF
+        export AUTOM4TE
+        export AUTOMAKE
+        export ACLOCAL
+        export LIBTOOLIZE
+    else
+        echo "could not find executable autoconf and autoheader in $autotoolsdir"
+	exit 1
+    fi
+else
+    autoconf=${AUTOCONF:-autoconf}
+    autoheader=${AUTOHEADER:-autoheader}
+    autoreconf=${AUTORECONF:-autoreconf}
+    autom4te=${AUTOM4TE:-autom4te}
+    automake=${AUTOMAKE:-automake}
+    aclocal=${ACLOCAL:-aclocal}
+    libtoolize=${LIBTOOLIZE:-libtoolize}
+fi
+ProgHomeDir $autoconf   autoconfdir
+ProgHomeDir $automake   automakedir
+ProgHomeDir $libtoolize libtooldir
+echo_n "Checking if autotools are in the same location... "
+if [ "$autoconfdir" = "$automakedir" -a "$autoconfdir" = "$libtooldir" ] ; then
+    same_atdir=yes
+    echo "yes, all in $autoconfdir"
+else
+    same_atdir=no
+    echo "no"
+    echo "	autoconf is in $autoconfdir"
+    echo "	automake is in $automakedir"
+    echo "	libtool  is in $libtooldir"
+    # Emit a big warning message if $same_atdir = no.
+    warn "Autotools are in different locations. In rare occasion,"
+    warn "resulting configure or makefile may fail in some unexpected ways."
+fi
+## Check if autoreconf can be patched to work
+## when autotools are not in the same location.
+## This test needs to be done before individual tests of autotools
+# If autotools are not in the same location, override autoreconf appropriately.
+if [ "$same_atdir" != "yes" ] ; then
+    if [ -z "$libtooldir" ] ; then
+        ProgHomeDir $libtoolize libtooldir
+    fi
+    libtoolm4dir="$libtooldir/share/aclocal"
+    echo_n "Checking if $autoreconf accepts -I $libtoolm4dir... "
+    new_autoreconf_works=no
+    if [ -d "$libtoolm4dir" -a -f "$libtoolm4dir/libtool.m4" ] ; then
+        recreate_tmp
+        cat >.tmp/configure.ac <<_EOF
+AC_INIT(foo,1.0)
+AC_PROG_LIBTOOL
+AC_OUTPUT
+_EOF
+        AUTORECONF="$autoreconf -I $libtoolm4dir"
+        if (cd .tmp && $AUTORECONF -ivf >/dev/null 2>&1) ; then
+            new_autoreconf_works=yes
+        fi
+        rm -rf .tmp
+    fi
+    echo "$new_autoreconf_works"
+    # If autoreconf accepts -I <libtool's m4 dir> correctly, use -I.
+    # If not, run libtoolize before autoreconf (i.e. for autoconf <= 2.63)
+    # This test is more general than checking the autoconf version.
+    if [ "$new_autoreconf_works" != "yes" ] ; then
+        echo_n "Checking if $autoreconf works after an additional $libtoolize step... "
+        recreate_tmp
+        # Need AC_CONFIG_
+AC_INIT(foo,1.0)
+AC_CONFIG_AUX_DIR([m4])
+AC_CONFIG_MACRO_DIR([m4])
+AC_PROG_LIBTOOL
+AC_OUTPUT
+_EOF
+        cat >.tmp/Makefile.am <<_EOF
+ACLOCAL_AMFLAGS = -I m4
+_EOF
+        AUTORECONF="eval $libtoolize && $autoreconf"
+        if (cd .tmp && $AUTORECONF -ivf >u.txt 2>&1) ; then
+        fi
+        rm -rf .tmp
+    fi
+    if [ "$new_autoreconf_works" = "yes" ] ; then
+        export AUTORECONF
+        autoreconf="$AUTORECONF"
+    else
+        # Since all autoreconf workarounds do not work, we need
+        # to require all autotools to be in the same directory.
+        do_atdir_check=yes
+        error "Since none of the autoreconf workaround works"
+        error "and autotools are not in the same directory, aborting..."
+        error "Updating autotools or putting all autotools in the same location"
+        error "may resolve the issue."
+        exit 1
+    fi
+fi
+## Verify autoconf version
+echo_n "Checking for autoconf version... "
+recreate_tmp
+ver=2.67
+# petsc.mcs.anl.gov's /usr/bin/autoreconf is version 2.65 which returns OK
+# if configure.ac has AC_PREREQ() withOUT AC_INIT.
+# ~/> hostname
+# petsc
+# ~> /usr/bin/autoconf --version
+# autoconf (GNU Autoconf) 2.65
+# ~/> cat configure.ac
+# AC_PREREQ(2.68)
+# ~/> /usr/bin/autoconf ; echo "rc=$?"
+# configure.ac:1: error: Autoconf version 2.68 or higher is required
+# configure.ac:1: the top level
+# autom4te: /usr/bin/m4 failed with exit status: 63
+# rc=63
+# ~/> /usr/bin/autoreconf ; echo "rc=$?"
+# rc=0
+cat > .tmp/configure.ac<<EOF
+AC_INIT
+AC_PREREQ($ver)
+AC_OUTPUT
+EOF
+if (cd .tmp && $autoreconf $autoreconf_args >/dev/null 2>&1 ) ; then
+    echo ">= $ver"
+else
+    echo "bad autoconf installation"
+    cat <<EOF
+You either do not have autoconf in your path or it is too old (version
+$ver or higher required). You may be able to use
+     autoconf --version
+Unfortunately, there is no standard format for the version output and
+it changes between autotools versions.  In addition, some versions of
+autoconf choose among many versions and provide incorrect output).
+EOF
+    exit 1
+fi
+## Verify automake version
+echo_n "Checking for automake version... "
+recreate_tmp
+ver=1.11
+AC_INIT(testver,1.0)
+m4_ifdef([AM_INIT_AUTOMAKE],,[m4_fatal([AM_INIT_AUTOMAKE not defined])])
+AM_INIT_AUTOMAKE([$ver foreign])
+AC_MSG_RESULT([A message])
+AC_OUTPUT([Makefile])
+EOF
+cat <<EOF >.tmp/Makefile.am
+EOF
+if [ ! -d .tmp/m4 ] ; then mkdir .tmp/m4 >/dev/null 2>&1 ; fi
+    echo ">= $ver"
+else
+    echo "bad automake installation"
+    cat <<EOF
+You either do not have automake in your path or it is too old (version
+     automake --version
+EOF
+    exit 1
+fi
+## Verify libtool version
+echo_n "Checking for libtool version... "
+recreate_tmp
+ver=2.4
+cat <<EOF >.tmp/configure.ac
+m4_ifdef([LT_PREREQ],,[m4_fatal([LT_PREREQ not defined])])
+LT_PREREQ($ver)
+LT_INIT()
+EOF
+EOF
+    echo ">= $ver"
+else
+    echo "bad libtool installation"
+    cat <<EOF
+You either do not have libtool in your path or it is too old
+(version $ver or higher required). You may be able to use
+     libtool --version
+EOF
+    exit 1
+fi
+## Checking for UNIX find
+echo_n "Checking for UNIX find... "
+find . -name 'configure.ac' > /dev/null 2>&1
+if [ $? = 0 ] ; then
+    echo "done"
+else
+    echo "not found (error)"
+    exit 1
+fi
+## Checking if xargs rm -rf works
+echo_n "Checking if xargs rm -rf works... "
+if [ -d "`find . -name __random_dir__`" ] ; then
+    error "found a directory named __random_dir__"
+    exit 1
+else
+    mkdir __random_dir__
+    find . -name __random_dir__ | xargs rm -rf > /dev/null 2>&1
+    if [ $? = 0 ] ; then
+	echo "yes"
+    else
+	echo "no (error)"
+	rm -rf __random_dir__
+	exit 1
+    fi
+fi
+echo
+echo
+echo "###########################################################"
+echo "## Autogenerating required files"
+echo
+## Building maint/Version
+# build a substitute maint/Version script now that we store the single copy of
+# this information in an m4 file for autoconf's benefit
+echo_n "Generating a helper maint/Version... "
+if $autom4te -l M4sugar maint/Version.base.m4 > maint/Version ; then
+    echo "done"
+else
+    echo "error"
+    error "unable to correctly generate maint/Version shell helper"
+fi
+## Building the README
+echo_n "Updating the README... "
+. ./maint/Version
+if [ -f README.vin ] ; then
+    sed -e "s/%VERSION%/${MPICH2_VERSION}/g" README.vin > README
+    echo "done"
+else
+    echo "error"
+    error "README.vin file not present, unable to update README version number (perhaps we are running in a release tarball source tree?)"
+fi
+## Update SMPD version
+if [ "$do_smpdversion" = yes ] ; then
+    echo_n "Creating src/pm/smpd/smpd_version.h... "
+    smpdVersion=${MPICH2_VERSION}
+    cat >src/pm/smpd/smpd_version.h <<EOF
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ *  (C) 2005 by Argonne National Laboratory.
+ *      See COPYRIGHT in top-level directory.
+#define SMPD_VERSION "$smpdVersion"
+EOF
+    echo "done"
+fi
+## Building subsys_include.m4
+if [ "X$do_subcfg_m4" = Xyes ] ; then
+    echo_n "Creating subsys_include.m4... "
+    ./maint/gen_subcfg_m4
+    echo "done"
+fi
+## Building non-C interfaces
+# Create the bindings if necessary
+if [ $do_bindings = "yes" ] ; then
+    build_f77=no
+    build_f90=no
+    build_cxx=no
+    if [ $do_f77 = "yes" ] ; then
+        if [ ! -s src/binding/f77/abortf.c ] ; then
+	    build_f77=yes
+        elif find src/binding/f77 -name 'buildiface' -newer 'src/binding/f77/abortf.c' >/dev/null 2>&1 ; then
+	    build_f77=yes
+        fi
+        if [ ! -s src/binding/f90/mpi_base.f90 ] ; then
+ 	    build_f90=yes
+        elif find src/binding/f90 -name 'buildiface' -newer 'src/binding/f90/mpi_base.f90' >/dev/null 2>&1 ; then
+	    build_f90=yes
+        fi
+    fi
+    if [ $build_f77 = "yes" ] ; then
+	echo_n "Building Fortran 77 interface... "
+	( cd src/binding/f77 && chmod a+x ./buildiface && ./buildiface )
+	echo "done"
+    fi
+    if [ $build_f90 = "yes" ] ; then
+	echo_n "Building Fortran 90 interface... "
+	# Remove any copy of mpi_base.f90 (this is used to handle the
+	# Double precision vs. Real*8 option
+	rm -f src/binding/f90/mpi_base.f90.orig
+	( cd src/binding/f90 && chmod a+x ./buildiface && ./buildiface )
+	( cd src/binding/f90 && ../f77/buildiface -infile=cf90t.h -deffile=cf90tdefs)
+	echo "done"
+    fi
+    if [ ! -s src/binding/cxx/mpicxx.h ] ; then
+	build_cxx=yes
+    elif find src/binding/cxx -name 'buildiface' -newer 'src/binding/cxx/mpicxx.h' >/dev/null 2>&1 ; then
+	build_cxx=yes
+    fi
+    if [ $build_cxx = "yes" ] ; then
+	echo_n "Building C++ interface... "
+	( cd src/binding/cxx && chmod a+x ./buildiface &&
+	  ./buildiface -nosep $otherarg )
+	echo "done"
+    fi
+fi
+## Extract error messages
+# Capture the error messages
+if [ $do_geterrmsgs = "yes" ] ; then
+    if [ ! -x maint/extracterrmsgs -a -s maint/extracterrmsgs ] ; then
+        # grrr.  CVS doesn't maintain permissions correctly across Windows/Unix
+        chmod a+x maint/extracterrmsgs
+    fi
+    if [ -x maint/extracterrmsgs ] ; then
+        echo_n "Extracting error messages... "
+        rm -rf .tmp
+        rm -f .err
+	rm -f unusederr.txt
+        maint/extracterrmsgs -careful=unusederr.txt \
+	    -skip=src/util/multichannel/mpi.c `cat maint/errmsgdirs` > \
+	    .tmp 2>.err
+        # (error here is ok)
+	echo "done"
+        update_errdefs=yes
+        if [ -s .err ] ; then
+            cat .err
+            rm -f .err2
+            grep -v "Warning:" .err > .err2
+            if [ -s .err2 ] ; then
+                warn "Because of errors in extracting error messages, the file"
+                warn "src/mpi/errhan/defmsg.h was not updated."
+		error "Error message files in src/mpi/errhan were not updated."
+   	        rm -f .tmp .err .err2
+		exit 1
+            fi
+            rm -f .err .err2
+        else
+            # Incase it exists but has zero size
+            rm -f .err
+        fi
+	if [ -s unusederr.txt ] ; then
+	    warn "There are unused error message texts in src/mpi/errhan/errnames.txt"
+	    warn "See the file unusederr.txt for the complete list"
+        fi
+        if [ -s .tmp -a "$update_errdefs" = "yes" ] ; then
+            mv .tmp src/mpi/errhan/defmsg.h
+        fi
+        if [ ! -s src/mpi/errhan/defmsg.h ] ; then
+            echo_n "Creating a dummy defmsg.h file... "
+	    cat > src/mpi/errhan/defmsg.h <<EOF
+typedef struct { const unsigned int sentinal1; const char *short_name, *long_name; const unsigned int sentinal2; } msgpair;
+static const int generic_msgs_len = 0;
+static msgpair generic_err_msgs[] = { {0xacebad03, 0, "no error catalog", 0xcb0bfa11}, };
+static const int specific_msgs_len = 0;
+static msgpair specific_err_msgs[] = {  {0xacebad03,0,0,0xcb0bfa11}, };
+#if MPICH_ERROR_MSG_LEVEL > MPICH_ERROR_MSG_NONE
+#define MPIR_MAX_ERROR_CLASS_INDEX 54
+static int class_to_index[] = {
+0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+0, 0, 0, 0 };
+#endif
+EOF
+	    echo "done"
+        fi
+    fi
+fi  # do_geterrmsgs
+## Build required scripts
+echo
+echo "------------------------------------"
+echo "Initiating building required scripts"
+# Build scripts such as simplemake if necessary
+made_simplemake=no
+run_configure=no
+# The information that autoconf uses is saved in the autom4te*.cache
+# file; since this cache is not accurate, we delete it.
+if [ ! -x maint/configure ] ; then
+    (cd maint && $autoconf && rm -rf autom4te*.cache )
+elif find maint -name 'configure.ac' -newer 'maint/configure' >/dev/null 2>&1 ; then
+    # The above relies on the Unix find command
+    (cd maint && $autoconf && rm -rf autom4te*.cache)
+fi
+if [ ! -x maint/simplemake -o ! -x maint/genstates ] ; then
+    run_configure=yes
+fi
+# The following relies on the Unix find command
+if [ -s maint/simplemake ] ; then
+    if find maint -name 'simplemake.in' -newer 'maint/simplemake' >/dev/null 2>&1 ; then
+        run_configure=yes
+    fi
+else
+    run_configure=yes
+fi
+if [ -s maint/genstates ] ; then
+    if find maint -name 'genstates.in' -newer 'maint/genstates' >/dev/null 2>&1 ; then
+        run_configure=yes
+    fi
+else
+    run_configure=yes
+fi
+if [ "$run_configure" = "yes" ] ; then
+    (cd maint && ./configure)
+    made_simplemake=yes
+fi
+echo "Done building required scripts"
+echo
+if [ ! -x maint/simplemake ] ; then
+    echo "Could not create simplemake"
+    echo "You can copy simplemake.in to simplemake, replacing @PERL@ with the"
+    echo "path to Perl (version5).  Make sure the resulting file has"
+    echo "execute permissions set."
+    exit 1
+fi
+# Run some of the simple codes
+echo_n "Creating the enumeration of logging states into src/include/mpiallstates.h... "
+if [ -x maint/extractstates -a $do_genstates = "yes" ] ; then
+    ./maint/extractstates
+fi
+echo "done"
+# new parameter code
+echo_n "Generating parameter handling code... "
+if test -x maint/genparams -a "$do_getparms" = "yes" ; then
+    if ./maint/genparams ; then
+        echo "done"
+    else
+        echo "failed"
+        error "unable to generate parameter handling code"
+        exit 1
+    fi
+else
+    echo "skipped"
+fi
+# simplemake
+if [ $made_simplemake != "no" ] ; then
+    echo_n "Checking if simplemake is created correctly... "
+    # Check that only the first three lines were changed:
+    rm -f .t1 .t2
+    sed -e 1,3d maint/simplemake.in > .t1
+    sed -e 1,3d maint/simplemake > .t2
+    if diff .t1 .t2 >/dev/null 2>&1 ; then
+	echo "done"
+    else
+	echo "done"
+        echo "Something is wrong with simplemake; configure may have"
+        echo "replaced variables that it should not have."
+        diff .t1 .t2
+        exit 1
+    fi
+    rm -f .t1 .t2
+fi
+# Create and/or update the f90 tests
+if [ -x ./maint/f77tof90 -a $do_f77tof90 = "yes" ] ; then
+    echo_n "Create or update the Fortran 90 tests derived from the Fortran 77 tests... "
+    for dir in test/mpi/f77/* ; do
+        if [ ! -d $dir ] ; then continue ; fi
+	leafDir=`basename $dir`
+        if [ ! -d test/mpi/f90/$leafDir ] ; then
+	    mkdir test/mpi/f90/$leafDir
+        fi
+        maint/f77tof90 $dir test/mpi/f90/$leafDir Makefile.am Makefile.ap
+        echo "timestamp" > test/mpi/f90/$leafDir/Makefile.am-stamp
+    done
+    echo "done"
+fi
+echo
+echo
+echo "## Generating configure in simplemake directories"
+echo
+## Creating configures in simplemake directories
+# Create the configure files and run autoheader
+fixBackWhackCtrlMBug=no
+if [ $do_build_configure = yes ] ; then
+    # Check for out-of-date configures (the dependency handling isn't
+    # 100% accurate, so we use this step as an additional check)
+    if [ ! -s maint/conftimestamp ] ; then
+	echo_n "Deleting all configure scripts because of missing confdbtimestamp... "
+	find . -name configure -print | grep -v maint/configure | xargs rm -f
+	find . -name autom4te.cache -print | xargs rm -rf
+	date > maint/conftimestamp
+	echo "done"
+    else
+	# We can't use a status check here because find will always
+	# report success, even if there are no newer files in confdb
+	files=`find confdb -newer  maint/conftimestamp 2>&1`
+	if [ -n "$files" ] ; then
+	    echo_n "Deleting all configure scripts because of changes in confdb... "
+	    echo "done"
+	fi
+    fi
+    echo
+    echo "---------------------------------------------------------------"
+    echo "Generating configure scripts"
+    for dir in `find . -name 'configure.ac' -print` ; do
+        dir=`dirname $dir`
+	found=0
+	for d in $amdirs $externals ; do
+	    foo=`echo $dir | sed -e 's%.*'"$d"'.*%FOUNDDIR%'`
+	    if [ "$foo" = "FOUNDDIR" ] ; then
+		# We'll use autoreconf later in this script for these
+		# directories
+		found=1
+		break
+	    fi
+	done
+	if [ "$found" = "1" ] ; then
+	    continue
+	fi
+	qtestmaint=`echo $dir | sed -e 's%.*test/mpi/maint.*%FOUNDTESTMAINT%'`
+	if [ "$qtestmaint" = "FOUNDTESTMAINT" ] ; then
+	    # echo "Found test/maint directory; skipping"
+	    # test/maint has its own autogen.sh script, which should
+	    # be used instead of this one when building that configure
+	    continue
+        fi
+	if [ -s $dir/Makefile.in ] ; then
+	    # First, check for a configure target in Makefile.in
+	    # FIXME: this check is completely broken for Makefiles
+	    # that have multiple targets on the same line (e.g.,
+	    # configure config.h: configure.ac)
+	    if grep 'configure:' $dir/Makefile.in >/dev/null 2>&1 ; then
+		# The make -q checks whether the target is upto date first;
+		# if it isn't, we remake it.
+		# The make target should be for ${srcdir}/configure,
+		# so in the make line, the target needs to be
+		# ./configure Using just "configure" is incorrect and
+		# will fail with some makes.
+		rm -f $dir/mf.out
+		rm -f $dir/mf.newer
+		date > $dir/mf.newer
+                (cd $dir && rm -f mf.tmp ; \
+                     sed -e 's%@SHELL@%/bin/sh%' -e "s%@srcdir@%.%g" \
+                         -e '/include .*alldeps/d' -e '/@SET_MAKE@/d' \
+                         -e 's%@VPATH@%%' Makefile.in > mf.tmp ; \
+                 echo "Found $dir/configure.ac; executing ${MAKE} -f mf.tmp ./configure" ; \
+                 if ${MAKE} -q -f mf.tmp ./configure >mf.out 2>&1 ; then \
+                 else \
+                     ${MAKE} -f mf.tmp ./configure ; \
+                 fi \
+		# Remove make output now that we no longer need it.
+		rm -f $dir/mf.out
+		rm -f $dir/mf.tmp
+            fi
+        fi
+	# Make sure a configure was created
+	if [ ! -x $dir/configure ] ; then
+	    echo "Could not build configure in $dir"
+	    exit 1
+	elif grep '\bPAC_' $dir/configure >/dev/null 2>&1 ; then
+	    echo "configure in $dir contains unresolved PAC macros"
+	    exit 1
+	fi
+    done
+    echo "Done generating configure scripts"
+    echo
+fi
+# Under cygwin, sometimes (?) configure ends up containing \^M (that's
+# <ctrl>-M).  We may need to add this sed step sed -e '/"\
+"/d' -e
+# 's/\
+//g' (the first removes case statements on \^M, the second
+# removes the \^M from the ac_config_files statement
+echo_n "Fixing ^M characters in configure files... "
+for cf in `find . -name 'configure' -print` ; do
+    if grep 'src/Makefile \\ src' $cf 2>&1 >/dev/null ; then
+	fixBackWhackCtrlMBug=yes
+    elif grep 'src/Makefile \\
+ src' $cf 2>&1 >/dev/null ; then
+    elif grep 'attr/Makefile \\ util' $cf 2>&1 >/dev/null ; then
+' $cf 2>&1 >/dev/null ; then
+    elif grep 'mpi2-other/info/Makefile \\
+    elif grep 'maint/testmerge \\
+    fi
+    # Add other tests here (sigh) as necessary
+    if [ "$fixBackWhackCtrlMBug" = yes ] ; then
+	rm -f c.tmp
+  	sed -e '/"\\
+/d' -e 's/\\
+//g' $dir/configure > c.tmp
+	rm -f $dir/configure
+	mv c.tmp $dir/configure
+	chmod a+x $dir/configure
+    fi
+done
+echo "done"
+echo
+echo
+echo "## Generating configure in non-simplemake directories"
+echo
+## Running autotools on non-simplemake directories
+if [ "$do_build_configure" = "yes" ] ; then
+    for external in $externals ; do
+       if [ -d "$external" -o -L "$external" ] ; then
+           echo "------------------------------------------------------------------------"
+           echo "running third-party initialization in $external"
+           (cd $external && ./autogen.sh) || exit 1
+       fi
+    done
+    for amdir in $amdirs ; do
+	if [ -d "$amdir" -o -L "$amdir" ] ; then
+	    echo "running $autoreconf in $amdir"
+            (cd $amdir && $autoreconf $autoreconf_args) || exit 1
+            # fix depcomp to support pgcc correctly
+            if grep "pgcc)" confdb/depcomp 2>&1 >/dev/null ; then :
+            else
+                echo 'patching "confdb/depcomp" to support pgcc'
+                patch -f -p0 < confdb/depcomp_pgcc.patch
+            fi
+	fi
+    done
+fi
Modified: mpich2/trunk/configure.ac
--- mpich2/trunk/configure.ac	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/configure.ac	2012-02-28 23:26:43 UTC (rev 9549)
@@ -230,7 +230,7 @@
 # quashing these variables have various drawbacks.  The alternatives are listed
 # here to avoid rediscovery of these problems by someone else in the future:
-# 1) Strategy: Rewrite mpichconf.h.in with sed at maint/updatefiles time.
+# 1) Strategy: Rewrite mpichconf.h.in with sed at autogen.sh time.
 #    Problem: Automatic remaking of config.status and friends will re-run
 #             autoheader and blow away our sed changes without an opportunity to
 #             patch the resulting file again.
@@ -2803,7 +2803,7 @@
 	AC_HELP_STRING([--enable-dependencies],
 		[Generate dependencies for sourcefiles.  This requires
 		that the Makefile.in files are also created to support
-		dependencies (see maint/updatefiles)]),,enable_dependencies=default)
+		dependencies (see autogen.sh)]),,enable_dependencies=default)
 if test -z "$enable_dependencies" ; then
Modified: mpich2/trunk/doc/logging/logging.tex
--- mpich2/trunk/doc/logging/logging.tex	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/doc/logging/logging.tex	2012-02-28 23:26:43 UTC (rev 9549)
@@ -147,7 +147,7 @@
 This is how the \texttt{maint/genstates} script works:
 \begin{enumerate}
-\item \texttt{maint/updatefiles} creates \texttt{genstates} from
+\item \texttt{autogen.sh} creates \texttt{genstates} from
 \texttt{genstates.in} replacing \texttt{@PERL@} with the appropriate path to
 perl and then runs \texttt{genstates}.
Modified: mpich2/trunk/doc/windev/getdotin.bat
--- mpich2/trunk/doc/windev/getdotin.bat	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/doc/windev/getdotin.bat	2012-02-28 23:26:43 UTC (rev 9549)
@@ -15,7 +15,7 @@
 GOTO END
 :AFTERHELP
 set CVS_RSH=ssh
-REM bash -c "echo cd `pwd` && echo maint/updatefiles" > bashcmds.txt
+REM bash -c "echo cd `pwd` && echo autogen.sh" > bashcmds.txt
 REM bash --login < bashcmds.txt
 echo cd /sandbox/%USERNAME% > sshcmds.txt
 echo mkdir dotintmp >> sshcmds.txt
@@ -27,7 +27,7 @@
 echo cvs -d /home/MPI/cvsMaster export -r HEAD mpich2allWithMPE >> sshcmds.txt
 :AFTER_EXPORT_HEAD
 echo cd mpich2 >> sshcmds.txt
-echo maint/updatefiles >> sshcmds.txt
+echo autogen.sh >> sshcmds.txt
 echo tar cvf dotin.tar `find . -name "*.h.in"` >> sshcmds.txt
 echo gzip dotin.tar >> sshcmds.txt
 echo exit >> sshcmds.txt
Modified: mpich2/trunk/doc/windev/testmpich2.wsf
--- mpich2/trunk/doc/windev/testmpich2.wsf	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/doc/windev/testmpich2.wsf	2012-02-28 23:26:43 UTC (rev 9549)
@@ -2185,14 +2185,14 @@
 		' check out mpich2 locally
 		CheckOut("mpich2")
 		WshShell.CurrentDirectory = "mpich2"
-		' check out mpich2 remotely, run maint/updatefiles and tar up the .h.in files
+		' check out mpich2 remotely, run autogen.sh and tar up the .h.in files
 		set fout = f.CreateTextFile("sshcmds.txt")
 		fout.WriteLine( "cd /sandbox/" & username )
 		fout.WriteLine( "mkdir " & hostname & "dotintmp" )
 		fout.WriteLine( "cd " & hostname & "dotintmp" )
 		fout.WriteLine( "cvs -d " & cvs_root_dir & " export -r " & cvsTag & " mpich2allWithMPE" )
 		fout.WriteLine( "cd mpich2" )
-		fout.WriteLine( "maint/updatefiles" )
+		fout.WriteLine( "autogen.sh" )
 		fout.WriteLine( "tar cvf dotin.tar `find . -name ""*.h.in""`" )
 		fout.WriteLine( "gzip dotin.tar" )
 		fout.WriteLine( "exit" )
Modified: mpich2/trunk/doc/windev/windev.tex.vin
--- mpich2/trunk/doc/windev/windev.tex.vin	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/doc/windev/windev.tex.vin	2012-02-28 23:26:43 UTC (rev 9549)
@@ -176,7 +176,7 @@
 The batch file executes the following steps:
 \begin{enumerate}
 \item Check out trunk from the MPICH2 svn repository.
-\item Run \texttt{maint/updatefiles} to generate the autogenerated files
+\item Run \texttt{autogen.sh} to generate the autogenerated files
 \item Run ``\texttt{winconfigure.wsf --cleancode}'' to configure mpich2 for Windows and output
 all the generated files like mpi.h and the fortran interface files, etc.
 \item Run the Visual Studio command line tool to build all the components of MPICH2.  This
@@ -229,7 +229,7 @@
 \texttt{svn checkout https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk mpich2}.
 \item cd into mpich2 directory
-\item run \texttt{maint/updatefiles}
+\item run \texttt{autogen.sh}
 \item Open a Visual Studio command prompt
 \item From within the Visual Studio command prompt run
Modified: mpich2/trunk/maint/Makefile.mk
--- mpich2/trunk/maint/Makefile.mk	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/maint/Makefile.mk	2012-02-28 23:26:43 UTC (rev 9549)
@@ -37,7 +37,6 @@
     maint/testbuild                   \
     maint/update_windows_version      \
     maint/testpmpi                    \
-    maint/updatefiles                 \
     maint/smlib/libadd.smlib
 dist_noinst_DATA +=                        \
Modified: mpich2/trunk/maint/release.pl
--- mpich2/trunk/maint/release.pl	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/maint/release.pl	2012-02-28 23:26:43 UTC (rev 9549)
@@ -203,7 +203,7 @@
 print("===> Creating configure in the main package... ");
 chdir("${root}/${pack}-${version}");
-    my $cmd = "./maint/updatefiles";
+    my $cmd = "./autogen.sh";
     $cmd .= " --with-autoconf=$with_autoconf" if $with_autoconf;
     $cmd .= " --with-automake=$with_automake" if $with_automake;
     run_cmd($cmd);
@@ -233,7 +233,7 @@
 print("===> Configuring and making the secondary package... ");
 chdir("${root}/${pack}-${version}-tmp");
     run_cmd($cmd);
Deleted: mpich2/trunk/maint/updatefiles
--- mpich2/trunk/maint/updatefiles	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/maint/updatefiles	2012-02-28 23:26:43 UTC (rev 9549)
@@ -1,1077 +0,0 @@
-#! /bin/sh
-# (C) 2006 by Argonne National Laboratory.
-#     See COPYRIGHT in top-level directory.
-# Update all of the derived files
-# For best performance, execute this in the top-level directory.
-# There are some experimental features to allow it to be executed in
-# subdirectories
-# Eventually, we want to allow this script to be executed anywhere in the
-# mpich tree.  This is not yet implemented.
-## Utility functions
-recreate_tmp() {
-    rm -rf .tmp
-    mkdir .tmp 2>&1 >/dev/null
-warn() {
-    echo "===> WARNING: $@"
-error() {
-    echo "===> ERROR:   $@"
-echo_n() {
-    # "echo -n" isn't portable, must portably implement with printf
-    printf "%s" "$*"
-# Assume Program's install-dir is <install-dir>/bin/<prog>.
-# Given program name as the 1st argument,
-# the install-dir is returned is returned in 2nd argument.
-# e.g., ProgHomeDir libtoolize libtooldir.
-ProgHomeDir() {
-    prog=$1
-    progpath="`which $prog`"
-    progbindir="`dirname $progpath`"
-    proghome=`(cd $progbindir/.. && pwd)`
-    eval $2=$proghome
-## Run any local pre-update hooks
-if test -d maint/hooks/pre ; then
-    for hook in `ls maint/hooks/pre/* 2>/dev/null` ; do
-        if test -x "$hook" ; then
-            echo_n "executing pre-update hook '$hook'... "
-            ./$hook
-            echo done
-        else
-            warn "unable to execute pre-update hook: '$hook'"
-        fi
-    done
-fi
-echo
-echo "##################################"
-echo "## Checking user environment"
-echo
-## Checks to make sure we are running from the correct location
-echo_n "Verifying the location of updatefiles... "
-if [ ! -d maint -o ! -s maint/simplemake.in ] ; then
-    echo "must execute at top level directory for now"
-    exit 1
-fi
-echo "done"
-## Version checks for svn in developer builds
-# Sanity check that any relative path svn:externals are present.  An
-# SVN version >=1.5 is needed to understand the relative path
-# externals format.  Such externals are used in particular for mpl in
-# hydra and all non-root confdbs.
-# Check for a particular file, not just the directory because several
-# autotools steps (such as libtoolize) will create the aux/macro dir.
-echo_n "Checking for svn checkout errors... "
-svn_externals_sanity_file="src/pm/hydra/version.m4"
-# Note that -e is not an available option for test in the Bourne shell, though
-# some systems that pretend that ksh is the same as sh will accept it.
-if test "!" -f $svn_externals_sanity_file ; then
-    cat <<EOT
-ERROR: The file '$svn_externals_sanity_file'
-is not present, indicating that you do not have a complete source tree.
-This is usually caused by checking out MPICH2 with an SVN client version
-less than v1.6.  Please check your SVN client version (with
-"svn --version") and use a newer version if necessary to obtain MPICH2.
-If you do have a modern SVN client and believe that you have reached
-this error case for some other reason, please file a ticket at:
-  https://trac.mcs.anl.gov/projects/mpich2/newticket
-EOT
-    exit 1
-fi
-echo "done"
-## Initialize variables to default values (possibly from the environment)
-# Default choices
-do_bindings=yes
-do_geterrmsgs=yes
-do_getparms=yes
-do_f77=yes
-do_f77tof90=yes
-do_build_configure=yes
-do_genstates=yes
-do_smpdversion=yes
-do_atdir_check=no
-do_atver_check=yes
-do_subcfg_m4=yes
-export do_build_configure
-# Allow MAKE to be set from the environment
-MAKE=${MAKE-make}
-# externals are the directories for external packages that we have
-# included into MPICH2
-externals="src/mpe2 src/pm/hydra src/mpi/romio src/mpix/armci src/pm/mpd src/openpa"
-# amdirs are the directories that make use of autoreconf
-amdirs=". src/mpl"
-autoreconf_args="-if"
-export autoreconf_args
-## Read the command-line arguments
-# List of steps that we will consider (We do not include depend
-# because the values for depend are not just yes/no)
-AllSteps="geterrmsgs bindings f77 f77tof90 build_configure genstates smpdversion getparms"
-stepsCleared=no
-# Extract the arguments intended for updatefiles.
-for arg in "$@" ; do
-    case $arg in
-	-echo)
-	    set -x
-	-atdircheck=*)
-	    val=`echo X$arg | sed -e 's/^X-atdircheck=//'`
-            case $val in
-		yes|YES|true|TRUE|1) do_atdir_check=yes ;;
-		no|NO|false|FALSE|0) do_atdir_check=no ;;
-		*) warn "unknown option: $arg."
-            esac
-	-atvercheck=*)
-            val=`echo X$arg | sed -e 's/^X-atvercheck=//'`
-            case $val in
-		yes|YES|true|TRUE|1) do_atver_check=yes ;;
-		no|NO|false|FALSE|0) do_atver_check=no ;;
-            esac
-	-do=*|--do=*)
-	    opt=`echo A$arg | sed -e 's/^A--*do=//'`
-	    case $opt in
-		build-configure|configure) opt=build_configure ;;
-	    esac
-	    var=do_$opt
-	    # Check that this opt is known
-	    eval oldval=\$"$var"
-	    if [ -z "$oldval" ] ; then
-		echo "-do=$opt is unrecognized"
-		exit 1
-	    else
-		if [ $stepsCleared = no ] ; then
-		    for step in $AllSteps ; do
-			var=do_$step
-			eval $var=no
-		    done
-		    stepsCleared=yes
-		fi
-		var=do_$opt
-		eval $var=yes
-	    fi
-        -verbose-autoreconf|--verbose-autoreconf)
-            autoreconf_args="-vif"
-            export autoreconf_args
-	-with-genstates|--with-genstates)
-	    do_genstates=yes
-	-without-genstates|--without-genstates)
-	    do_genstates=no
-	-with-errmsgs|--with-errmsgs)
-	    do_geterrmsgs=yes
-	-without-errmsgs|--without-errmsgs)
-	    do_geterrmsgs=no
-	-with-bindings|--with-bindings)
-	    do_bindings=yes
-	-without-bindings|--without-bindings)
-	    do_bindings=no
-	-with-f77|--with-f77)
-	    do_f77=yes
-	-without-f77|--without-f77)
-	    do_f77=no
-	-with-autotools=*|--with-autotools=*)
-	    autotoolsdir=`echo "A$arg" | sed -e 's/.*=//'`
-	-help|--help|-usage|--usage)
-	    cat <<EOF
-    updatefiles [ --with-autotools=dir ] \\
-                [ -atdircheck=[yes|no] ] \\
-                [ -atvercheck=[yes|no] ] \\
-                [ --verbose-autoreconf ] \\
-                [ --do=stepname ] [ -distrib ] [ args for simplemake ]
-    Update the files in the MPICH2 build tree.  This file builds the
-    configure files, creates the Makefile.in files (using the simplemake
-    program), extracts the error messages.
-    You can use --with-autotools=dir to specify a directory that
-    contains alternate autotools.
-    -atdircheck=[yes|no] specifies the enforcement of all autotools
-    should be installed in the same directory.
-    -atvercheck=[yes|no] specifies if the check for the version of
-    autotools should be carried out.
-    -distrib creates a distribution version of the Makefile.in files (no
-    targets for updating the Makefile.in from Makefile.sm or rebuilding the
-    autotools targets).  This does not create the configure files because
-    some of those depend on rules in the Makefile.in in that directory.
-    Thus, to build all of the files for a distribution, run maint/updatefiles
-    twice, as in
-         maint/updatefiles && maint/updatefiles -distrib
-    Use --do=stepname to update only a single step.  For example,
-    --do=build_configure only updates the configure scripts.  The available
-    steps are:
-EOF
-		echo "        $step"
-	    done
-	    exit 1
-	    echo "unknown argument $arg"
-	    exit 1
-    esac
-done
-## Check for the location of autotools
-if [ -z "$autotoolsdir" ] ; then
-    autotoolsdir=$MPICH2_AUTOTOOLS_DIR
-fi
-if [ -n "$autotoolsdir" ] ; then
-    if [ -x $autotoolsdir/autoconf -a -x $autotoolsdir/autoheader ] ; then
-        autoconf=$autotoolsdir/autoconf
-        autoheader=$autotoolsdir/autoheader
-        autoreconf=$autotoolsdir/autoreconf
-        automake=$autotoolsdir/automake
-        autom4te=$autotoolsdir/autom4te
-        aclocal=$autotoolsdir/aclocal
-        if [ -x "$autotoolsdir/glibtoolize" ] ; then
-            libtoolize=$autotoolsdir/glibtoolize
-        else
-            libtoolize=$autotoolsdir/libtoolize
-        fi
-	# Simplemake looks in environment variables for the autoconf
-	# and autoheader to use
-	AUTOCONF=$autoconf
-	AUTOHEADER=$autoheader
-        AUTORECONF=$autoreconf
-        AUTOMAKE=$automake
-	AUTOM4TE=$autom4te
-        ACLOCAL=$aclocal
-        LIBTOOLIZE=$libtoolize
-	export AUTOCONF
-	export AUTOHEADER
-        export AUTORECONF
-        export AUTOM4TE
-        export AUTOMAKE
-        export ACLOCAL
-        export LIBTOOLIZE
-    else
-        echo "could not find executable autoconf and autoheader in $autotoolsdir"
-	exit 1
-    fi
-else
-    autoconf=${AUTOCONF:-autoconf}
-    autoheader=${AUTOHEADER:-autoheader}
-    autoreconf=${AUTORECONF:-autoreconf}
-    autom4te=${AUTOM4TE:-autom4te}
-    automake=${AUTOMAKE:-automake}
-    aclocal=${ACLOCAL:-aclocal}
-    libtoolize=${LIBTOOLIZE:-libtoolize}
-fi
-ProgHomeDir $autoconf   autoconfdir
-ProgHomeDir $automake   automakedir
-ProgHomeDir $libtoolize libtooldir
-echo_n "Checking if autotools are in the same location... "
-if [ "$autoconfdir" = "$automakedir" -a "$autoconfdir" = "$libtooldir" ] ; then
-    same_atdir=yes
-    echo "yes, all in $autoconfdir"
-else
-    same_atdir=no
-    echo "no"
-    echo "	autoconf is in $autoconfdir"
-    echo "	automake is in $automakedir"
-    echo "	libtool  is in $libtooldir"
-    # Emit a big warning message if $same_atdir = no.
-    warn "Autotools are in different locations. In rare occasion,"
-    warn "resulting configure or makefile may fail in some unexpected ways."
-fi
-## Check if autoreconf can be patched to work
-## when autotools are not in the same location.
-## This test needs to be done before individual tests of autotools
-# If autotools are not in the same location, override autoreconf appropriately.
-if [ "$same_atdir" != "yes" ] ; then
-    if [ -z "$libtooldir" ] ; then
-        ProgHomeDir $libtoolize libtooldir
-    fi
-    libtoolm4dir="$libtooldir/share/aclocal"
-    echo_n "Checking if $autoreconf accepts -I $libtoolm4dir... "
-    new_autoreconf_works=no
-    if [ -d "$libtoolm4dir" -a -f "$libtoolm4dir/libtool.m4" ] ; then
-        recreate_tmp
-        cat >.tmp/configure.ac <<_EOF
-AC_INIT(foo,1.0)
-AC_PROG_LIBTOOL
-AC_OUTPUT
-_EOF
-        AUTORECONF="$autoreconf -I $libtoolm4dir"
-        if (cd .tmp && $AUTORECONF -ivf >/dev/null 2>&1) ; then
-            new_autoreconf_works=yes
-        fi
-        rm -rf .tmp
-    fi
-    echo "$new_autoreconf_works"
-    # If autoreconf accepts -I <libtool's m4 dir> correctly, use -I.
-    # If not, run libtoolize before autoreconf (i.e. for autoconf <= 2.63)
-    # This test is more general than checking the autoconf version.
-    if [ "$new_autoreconf_works" != "yes" ] ; then
-        echo_n "Checking if $autoreconf works after an additional $libtoolize step... "
-        recreate_tmp
-        # Need AC_CONFIG_
-AC_INIT(foo,1.0)
-AC_CONFIG_AUX_DIR([m4])
-AC_CONFIG_MACRO_DIR([m4])
-AC_PROG_LIBTOOL
-AC_OUTPUT
-_EOF
-        cat >.tmp/Makefile.am <<_EOF
-ACLOCAL_AMFLAGS = -I m4
-_EOF
-        AUTORECONF="eval $libtoolize && $autoreconf"
-        if (cd .tmp && $AUTORECONF -ivf >u.txt 2>&1) ; then
-        fi
-        rm -rf .tmp
-    fi
-    if [ "$new_autoreconf_works" = "yes" ] ; then
-        export AUTORECONF
-        autoreconf="$AUTORECONF"
-    else
-        # Since all autoreconf workarounds do not work, we need
-        # to require all autotools to be in the same directory.
-        do_atdir_check=yes
-        error "Since none of the autoreconf workaround works"
-        error "and autotools are not in the same directory, aborting..."
-        error "Updating autotools or putting all autotools in the same location"
-        error "may resolve the issue."
-        exit 1
-    fi
-fi
-## Verify autoconf version
-echo_n "Checking for autoconf version... "
-recreate_tmp
-ver=2.67
-# petsc.mcs.anl.gov's /usr/bin/autoreconf is version 2.65 which returns OK
-# if configure.ac has AC_PREREQ() withOUT AC_INIT.
-# ~/> hostname
-# petsc
-# ~> /usr/bin/autoconf --version
-# autoconf (GNU Autoconf) 2.65
-# ~/> cat configure.ac
-# AC_PREREQ(2.68)
-# ~/> /usr/bin/autoconf ; echo "rc=$?"
-# configure.ac:1: error: Autoconf version 2.68 or higher is required
-# configure.ac:1: the top level
-# autom4te: /usr/bin/m4 failed with exit status: 63
-# rc=63
-# ~/> /usr/bin/autoreconf ; echo "rc=$?"
-# rc=0
-cat > .tmp/configure.ac<<EOF
-AC_INIT
-AC_PREREQ($ver)
-AC_OUTPUT
-EOF
-if (cd .tmp && $autoreconf $autoreconf_args >/dev/null 2>&1 ) ; then
-    echo ">= $ver"
-else
-    echo "bad autoconf installation"
-    cat <<EOF
-You either do not have autoconf in your path or it is too old (version
-$ver or higher required). You may be able to use
-     autoconf --version
-Unfortunately, there is no standard format for the version output and
-it changes between autotools versions.  In addition, some versions of
-autoconf choose among many versions and provide incorrect output).
-EOF
-    exit 1
-fi
-## Verify automake version
-echo_n "Checking for automake version... "
-recreate_tmp
-ver=1.11
-AC_INIT(testver,1.0)
-m4_ifdef([AM_INIT_AUTOMAKE],,[m4_fatal([AM_INIT_AUTOMAKE not defined])])
-AM_INIT_AUTOMAKE([$ver foreign])
-AC_MSG_RESULT([A message])
-AC_OUTPUT([Makefile])
-EOF
-cat <<EOF >.tmp/Makefile.am
-EOF
-if [ ! -d .tmp/m4 ] ; then mkdir .tmp/m4 >/dev/null 2>&1 ; fi
-    echo ">= $ver"
-else
-    echo "bad automake installation"
-    cat <<EOF
-You either do not have automake in your path or it is too old (version
-     automake --version
-EOF
-    exit 1
-fi
-## Verify libtool version
-echo_n "Checking for libtool version... "
-recreate_tmp
-ver=2.4
-cat <<EOF >.tmp/configure.ac
-m4_ifdef([LT_PREREQ],,[m4_fatal([LT_PREREQ not defined])])
-LT_PREREQ($ver)
-LT_INIT()
-EOF
-EOF
-    echo ">= $ver"
-else
-    echo "bad libtool installation"
-    cat <<EOF
-You either do not have libtool in your path or it is too old
-(version $ver or higher required). You may be able to use
-     libtool --version
-EOF
-    exit 1
-fi
-## Checking for UNIX find
-echo_n "Checking for UNIX find... "
-find . -name 'configure.ac' > /dev/null 2>&1
-if [ $? = 0 ] ; then
-    echo "done"
-else
-    echo "not found (error)"
-    exit 1
-fi
-## Checking if xargs rm -rf works
-echo_n "Checking if xargs rm -rf works... "
-if [ -d "`find . -name __random_dir__`" ] ; then
-    error "found a directory named __random_dir__"
-    exit 1
-else
-    mkdir __random_dir__
-    find . -name __random_dir__ | xargs rm -rf > /dev/null 2>&1
-    if [ $? = 0 ] ; then
-	echo "yes"
-    else
-	echo "no (error)"
-	rm -rf __random_dir__
-	exit 1
-    fi
-fi
-echo
-echo
-echo "###########################################################"
-echo "## Autogenerating required files"
-echo
-## Building maint/Version
-# build a substitute maint/Version script now that we store the single copy of
-# this information in an m4 file for autoconf's benefit
-echo_n "Generating a helper maint/Version... "
-if $autom4te -l M4sugar maint/Version.base.m4 > maint/Version ; then
-    echo "done"
-else
-    echo "error"
-    error "unable to correctly generate maint/Version shell helper"
-fi
-## Building the README
-echo_n "Updating the README... "
-. ./maint/Version
-if [ -f README.vin ] ; then
-    sed -e "s/%VERSION%/${MPICH2_VERSION}/g" README.vin > README
-    echo "done"
-else
-    echo "error"
-    error "README.vin file not present, unable to update README version number (perhaps we are running in a release tarball source tree?)"
-fi
-## Update SMPD version
-if [ "$do_smpdversion" = yes ] ; then
-    echo_n "Creating src/pm/smpd/smpd_version.h... "
-    smpdVersion=${MPICH2_VERSION}
-    cat >src/pm/smpd/smpd_version.h <<EOF
-/* -*- Mode: C; c-basic-offset:4 ; -*- */
- *  (C) 2005 by Argonne National Laboratory.
- *      See COPYRIGHT in top-level directory.
-#define SMPD_VERSION "$smpdVersion"
-EOF
-    echo "done"
-fi
-## Building subsys_include.m4
-if [ "X$do_subcfg_m4" = Xyes ] ; then
-    echo_n "Creating subsys_include.m4... "
-    ./maint/gen_subcfg_m4
-    echo "done"
-fi
-## Building non-C interfaces
-# Create the bindings if necessary
-if [ $do_bindings = "yes" ] ; then
-    build_f77=no
-    build_f90=no
-    build_cxx=no
-    if [ $do_f77 = "yes" ] ; then
-        if [ ! -s src/binding/f77/abortf.c ] ; then
-	    build_f77=yes
-        elif find src/binding/f77 -name 'buildiface' -newer 'src/binding/f77/abortf.c' >/dev/null 2>&1 ; then
-	    build_f77=yes
-        fi
-        if [ ! -s src/binding/f90/mpi_base.f90 ] ; then
- 	    build_f90=yes
-        elif find src/binding/f90 -name 'buildiface' -newer 'src/binding/f90/mpi_base.f90' >/dev/null 2>&1 ; then
-	    build_f90=yes
-        fi
-    fi
-    if [ $build_f77 = "yes" ] ; then
-	echo_n "Building Fortran 77 interface... "
-	( cd src/binding/f77 && chmod a+x ./buildiface && ./buildiface )
-	echo "done"
-    fi
-    if [ $build_f90 = "yes" ] ; then
-	echo_n "Building Fortran 90 interface... "
-	# Remove any copy of mpi_base.f90 (this is used to handle the
-	# Double precision vs. Real*8 option
-	rm -f src/binding/f90/mpi_base.f90.orig
-	( cd src/binding/f90 && chmod a+x ./buildiface && ./buildiface )
-	( cd src/binding/f90 && ../f77/buildiface -infile=cf90t.h -deffile=cf90tdefs)
-	echo "done"
-    fi
-    if [ ! -s src/binding/cxx/mpicxx.h ] ; then
-	build_cxx=yes
-    elif find src/binding/cxx -name 'buildiface' -newer 'src/binding/cxx/mpicxx.h' >/dev/null 2>&1 ; then
-	build_cxx=yes
-    fi
-    if [ $build_cxx = "yes" ] ; then
-	echo_n "Building C++ interface... "
-	( cd src/binding/cxx && chmod a+x ./buildiface &&
-	  ./buildiface -nosep $otherarg )
-	echo "done"
-    fi
-fi
-## Extract error messages
-# Capture the error messages
-if [ $do_geterrmsgs = "yes" ] ; then
-    if [ ! -x maint/extracterrmsgs -a -s maint/extracterrmsgs ] ; then
-        # grrr.  CVS doesn't maintain permissions correctly across Windows/Unix
-        chmod a+x maint/extracterrmsgs
-    fi
-    if [ -x maint/extracterrmsgs ] ; then
-        echo_n "Extracting error messages... "
-        rm -rf .tmp
-        rm -f .err
-	rm -f unusederr.txt
-        maint/extracterrmsgs -careful=unusederr.txt \
-	    -skip=src/util/multichannel/mpi.c `cat maint/errmsgdirs` > \
-	    .tmp 2>.err
-        # (error here is ok)
-	echo "done"
-        update_errdefs=yes
-        if [ -s .err ] ; then
-            cat .err
-            rm -f .err2
-            grep -v "Warning:" .err > .err2
-            if [ -s .err2 ] ; then
-                warn "Because of errors in extracting error messages, the file"
-                warn "src/mpi/errhan/defmsg.h was not updated."
-		error "Error message files in src/mpi/errhan were not updated."
-   	        rm -f .tmp .err .err2
-		exit 1
-            fi
-            rm -f .err .err2
-        else
-            # Incase it exists but has zero size
-            rm -f .err
-        fi
-	if [ -s unusederr.txt ] ; then
-	    warn "There are unused error message texts in src/mpi/errhan/errnames.txt"
-	    warn "See the file unusederr.txt for the complete list"
-        fi
-        if [ -s .tmp -a "$update_errdefs" = "yes" ] ; then
-            mv .tmp src/mpi/errhan/defmsg.h
-        fi
-        if [ ! -s src/mpi/errhan/defmsg.h ] ; then
-            echo_n "Creating a dummy defmsg.h file... "
-	    cat > src/mpi/errhan/defmsg.h <<EOF
-typedef struct { const unsigned int sentinal1; const char *short_name, *long_name; const unsigned int sentinal2; } msgpair;
-static const int generic_msgs_len = 0;
-static msgpair generic_err_msgs[] = { {0xacebad03, 0, "no error catalog", 0xcb0bfa11}, };
-static const int specific_msgs_len = 0;
-static msgpair specific_err_msgs[] = {  {0xacebad03,0,0,0xcb0bfa11}, };
-#if MPICH_ERROR_MSG_LEVEL > MPICH_ERROR_MSG_NONE
-#define MPIR_MAX_ERROR_CLASS_INDEX 54
-static int class_to_index[] = {
-0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
-0, 0, 0, 0 };
-#endif
-EOF
-	    echo "done"
-        fi
-    fi
-fi  # do_geterrmsgs
-## Build required scripts
-echo
-echo "------------------------------------"
-echo "Initiating building required scripts"
-# Build scripts such as simplemake if necessary
-made_simplemake=no
-run_configure=no
-# The information that autoconf uses is saved in the autom4te*.cache
-# file; since this cache is not accurate, we delete it.
-if [ ! -x maint/configure ] ; then
-    (cd maint && $autoconf && rm -rf autom4te*.cache )
-elif find maint -name 'configure.ac' -newer 'maint/configure' >/dev/null 2>&1 ; then
-    # The above relies on the Unix find command
-    (cd maint && $autoconf && rm -rf autom4te*.cache)
-fi
-if [ ! -x maint/simplemake -o ! -x maint/genstates ] ; then
-    run_configure=yes
-fi
-# The following relies on the Unix find command
-if [ -s maint/simplemake ] ; then
-    if find maint -name 'simplemake.in' -newer 'maint/simplemake' >/dev/null 2>&1 ; then
-        run_configure=yes
-    fi
-else
-    run_configure=yes
-fi
-if [ -s maint/genstates ] ; then
-    if find maint -name 'genstates.in' -newer 'maint/genstates' >/dev/null 2>&1 ; then
-        run_configure=yes
-    fi
-else
-    run_configure=yes
-fi
-if [ "$run_configure" = "yes" ] ; then
-    (cd maint && ./configure)
-    made_simplemake=yes
-fi
-echo "Done building required scripts"
-echo
-if [ ! -x maint/simplemake ] ; then
-    echo "Could not create simplemake"
-    echo "You can copy simplemake.in to simplemake, replacing @PERL@ with the"
-    echo "path to Perl (version5).  Make sure the resulting file has"
-    echo "execute permissions set."
-    exit 1
-fi
-# Run some of the simple codes
-echo_n "Creating the enumeration of logging states into src/include/mpiallstates.h... "
-if [ -x maint/extractstates -a $do_genstates = "yes" ] ; then
-    ./maint/extractstates
-fi
-echo "done"
-# new parameter code
-echo_n "Generating parameter handling code... "
-if test -x maint/genparams -a "$do_getparms" = "yes" ; then
-    if ./maint/genparams ; then
-        echo "done"
-    else
-        echo "failed"
-        error "unable to generate parameter handling code"
-        exit 1
-    fi
-else
-    echo "skipped"
-fi
-# simplemake
-if [ $made_simplemake != "no" ] ; then
-    echo_n "Checking if simplemake is created correctly... "
-    # Check that only the first three lines were changed:
-    rm -f .t1 .t2
-    sed -e 1,3d maint/simplemake.in > .t1
-    sed -e 1,3d maint/simplemake > .t2
-    if diff .t1 .t2 >/dev/null 2>&1 ; then
-	echo "done"
-    else
-	echo "done"
-        echo "Something is wrong with simplemake; configure may have"
-        echo "replaced variables that it should not have."
-        diff .t1 .t2
-        exit 1
-    fi
-    rm -f .t1 .t2
-fi
-# Create and/or update the f90 tests
-if [ -x ./maint/f77tof90 -a $do_f77tof90 = "yes" ] ; then
-    echo_n "Create or update the Fortran 90 tests derived from the Fortran 77 tests... "
-    for dir in test/mpi/f77/* ; do
-        if [ ! -d $dir ] ; then continue ; fi
-	leafDir=`basename $dir`
-        if [ ! -d test/mpi/f90/$leafDir ] ; then
-	    mkdir test/mpi/f90/$leafDir
-        fi
-        maint/f77tof90 $dir test/mpi/f90/$leafDir Makefile.am Makefile.ap
-        echo "timestamp" > test/mpi/f90/$leafDir/Makefile.am-stamp
-    done
-    echo "done"
-fi
-echo
-echo
-echo "## Generating configure in simplemake directories"
-echo
-## Creating configures in simplemake directories
-# Create the configure files and run autoheader
-fixBackWhackCtrlMBug=no
-if [ $do_build_configure = yes ] ; then
-    # Check for out-of-date configures (the dependency handling isn't
-    # 100% accurate, so we use this step as an additional check)
-    if [ ! -s maint/conftimestamp ] ; then
-	echo_n "Deleting all configure scripts because of missing confdbtimestamp... "
-	find . -name configure -print | grep -v maint/configure | xargs rm -f
-	find . -name autom4te.cache -print | xargs rm -rf
-	date > maint/conftimestamp
-	echo "done"
-    else
-	# We can't use a status check here because find will always
-	# report success, even if there are no newer files in confdb
-	files=`find confdb -newer  maint/conftimestamp 2>&1`
-	if [ -n "$files" ] ; then
-	    echo_n "Deleting all configure scripts because of changes in confdb... "
-	    echo "done"
-	fi
-    fi
-    echo
-    echo "---------------------------------------------------------------"
-    echo "Generating configure scripts"
-    for dir in `find . -name 'configure.ac' -print` ; do
-        dir=`dirname $dir`
-	found=0
-	for d in $amdirs $externals ; do
-	    foo=`echo $dir | sed -e 's%.*'"$d"'.*%FOUNDDIR%'`
-	    if [ "$foo" = "FOUNDDIR" ] ; then
-		# We'll use autoreconf later in this script for these
-		# directories
-		found=1
-		break
-	    fi
-	done
-	if [ "$found" = "1" ] ; then
-	    continue
-	fi
-	qtestmaint=`echo $dir | sed -e 's%.*test/mpi/maint.*%FOUNDTESTMAINT%'`
-	if [ "$qtestmaint" = "FOUNDTESTMAINT" ] ; then
-	    # echo "Found test/maint directory; skipping"
-	    # test/maint has its own updatefiles script, which should
-	    # be used instead of this one when building that configure
-	    continue
-        fi
-	if [ -s $dir/Makefile.in ] ; then
-	    # First, check for a configure target in Makefile.in
-	    # FIXME: this check is completely broken for Makefiles
-	    # that have multiple targets on the same line (e.g.,
-	    # configure config.h: configure.ac)
-	    if grep 'configure:' $dir/Makefile.in >/dev/null 2>&1 ; then
-		# The make -q checks whether the target is upto date first;
-		# if it isn't, we remake it.
-		# The make target should be for ${srcdir}/configure,
-		# so in the make line, the target needs to be
-		# ./configure Using just "configure" is incorrect and
-		# will fail with some makes.
-		rm -f $dir/mf.out
-		rm -f $dir/mf.newer
-		date > $dir/mf.newer
-                (cd $dir && rm -f mf.tmp ; \
-                     sed -e 's%@SHELL@%/bin/sh%' -e "s%@srcdir@%.%g" \
-                         -e '/include .*alldeps/d' -e '/@SET_MAKE@/d' \
-                         -e 's%@VPATH@%%' Makefile.in > mf.tmp ; \
-                 echo "Found $dir/configure.ac; executing ${MAKE} -f mf.tmp ./configure" ; \
-                 if ${MAKE} -q -f mf.tmp ./configure >mf.out 2>&1 ; then \
-                 else \
-                     ${MAKE} -f mf.tmp ./configure ; \
-                 fi \
-		# Remove make output now that we no longer need it.
-		rm -f $dir/mf.out
-		rm -f $dir/mf.tmp
-            fi
-        fi
-	# Make sure a configure was created
-	if [ ! -x $dir/configure ] ; then
-	    echo "Could not build configure in $dir"
-	    exit 1
-	elif grep '\bPAC_' $dir/configure >/dev/null 2>&1 ; then
-	    echo "configure in $dir contains unresolved PAC macros"
-	    exit 1
-	fi
-    done
-    echo "Done generating configure scripts"
-    echo
-fi
-# Under cygwin, sometimes (?) configure ends up containing \^M (that's
-# <ctrl>-M).  We may need to add this sed step sed -e '/"\
-"/d' -e
-# 's/\
-//g' (the first removes case statements on \^M, the second
-# removes the \^M from the ac_config_files statement
-echo_n "Fixing ^M characters in configure files... "
-for cf in `find . -name 'configure' -print` ; do
-    if grep 'src/Makefile \\ src' $cf 2>&1 >/dev/null ; then
-	fixBackWhackCtrlMBug=yes
-    elif grep 'src/Makefile \\
- src' $cf 2>&1 >/dev/null ; then
-    elif grep 'attr/Makefile \\ util' $cf 2>&1 >/dev/null ; then
-' $cf 2>&1 >/dev/null ; then
-    elif grep 'mpi2-other/info/Makefile \\
-    elif grep 'maint/testmerge \\
-    fi
-    # Add other tests here (sigh) as necessary
-    if [ "$fixBackWhackCtrlMBug" = yes ] ; then
-	rm -f c.tmp
-  	sed -e '/"\\
-/d' -e 's/\\
-//g' $dir/configure > c.tmp
-	rm -f $dir/configure
-	mv c.tmp $dir/configure
-	chmod a+x $dir/configure
-    fi
-done
-echo "done"
-echo
-echo
-echo "## Generating configure in non-simplemake directories"
-echo
-## Running autotools on non-simplemake directories
-if [ "$do_build_configure" = "yes" ] ; then
-    for external in $externals ; do
-       if [ -d "$external" -o -L "$external" ] ; then
-           echo "------------------------------------------------------------------------"
-           echo "running third-party initialization in $external"
-           (cd $external && ./autogen.sh) || exit 1
-       fi
-    done
-    for amdir in $amdirs ; do
-	if [ -d "$amdir" -o -L "$amdir" ] ; then
-	    echo "running $autoreconf in $amdir"
-            (cd $amdir && $autoreconf $autoreconf_args) || exit 1
-            # fix depcomp to support pgcc correctly
-            if grep "pgcc)" confdb/depcomp 2>&1 >/dev/null ; then :
-            else
-                echo 'patching "confdb/depcomp" to support pgcc'
-                patch -f -p0 < confdb/depcomp_pgcc.patch
-            fi
-	fi
-    done
-fi
Modified: mpich2/trunk/src/mpe2/src/slog2sdk/doc/jumpshot-4/tex/rm_html_scale_fig
--- mpich2/trunk/src/mpe2/src/slog2sdk/doc/jumpshot-4/tex/rm_html_scale_fig	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/src/mpe2/src/slog2sdk/doc/jumpshot-4/tex/rm_html_scale_fig	2012-02-28 23:26:43 UTC (rev 9549)
@@ -1,7 +1,7 @@
 #!/bin/sh
 # PWD is not guaranteed to be set to the current directory in all cases
-# (e.g., in /bin/sh, (cd src/mpe2 && maint/updatefiles won't set PWD to
+# (e.g., in /bin/sh, (cd src/mpe2 && autogen.sh won't set PWD to
 # .../src/mpe2) The parent directory of where this script is located
 saved_wd=`pwd`
 cd `dirname $0`/.. && master_dir=`pwd`
Modified: mpich2/trunk/src/mpe2/src/slog2sdk/maint/make_slog2update.txt
--- mpich2/trunk/src/mpe2/src/slog2sdk/maint/make_slog2update.txt	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/src/mpe2/src/slog2sdk/maint/make_slog2update.txt	2012-02-28 23:26:43 UTC (rev 9549)
@@ -4,7 +4,7 @@
 cp -a /home/chan/slog2/slog2sdk-032705/src/* /home/chan/slog2/slog2sdk/src_205
 maint/rename_oldsrc src_205
-maint/updatefiles
+autogen.sh
 cd /home/chan/slog2/build
 /home/chan/slog2/slog2sdk/configure --with-oldsource=src_205 \
Modified: mpich2/trunk/src/mpi/errhan/Makefile.mk
--- mpich2/trunk/src/mpi/errhan/Makefile.mk	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/src/mpi/errhan/Makefile.mk	2012-02-28 23:26:43 UTC (rev 9549)
@@ -54,7 +54,7 @@
 MAINTAINERCLEANFILES += $(top_srcdir)/src/mpi/errhan/defmsg.h
 # FIXME DUPLICATION
-# This code is lifted from maint/updatefiles.  This extra logic should just be
+# This code is lifted from autogen.sh.  This extra logic should just be
 # rolled up into the extracterrmsgs script itself.
 $(top_srcdir)/src/mpi/errhan/defmsg.h: $(errnames_txt_files) src/mpi/errhan/baseerrnames.txt
 	( cd $(top_srcdir) && rm -f .err unusederr.txt ; rm -rf .tmp )
Modified: mpich2/trunk/src/mpid/globus/Makefile.sm
--- mpich2/trunk/src/mpid/globus/Makefile.sm	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/src/mpid/globus/Makefile.sm	2012-02-28 23:26:43 UTC (rev 9549)
@@ -157,7 +157,7 @@
 	-rm -f mpiexec
-# clean up files created by maint/updatefiles (autoheader, autoconf, etc.)
+# clean up files created by autogen.sh (autoheader, autoconf, etc.)
 maintainer-clean-local:
 	-rm -f mpidconf.h.in
Modified: mpich2/trunk/src/util/param/Makefile.mk
--- mpich2/trunk/src/util/param/Makefile.mk	2012-02-28 23:26:34 UTC (rev 9548)
+++ mpich2/trunk/src/util/param/Makefile.mk	2012-02-28 23:26:43 UTC (rev 9549)
@@ -11,7 +11,7 @@
 dist_noinst_DATA += src/util/param/params.yml
 if MAINTAINER_MODE
-# normally built by maint/updatefiles, but this rebuild rule is here
+# normally built by autogen.sh, but this rebuild rule is here
 src/util/param/param_vals.c: src/util/param/params.yml $(top_srcdir)/maint/genparams
 	( cd $(top_srcdir) && ./maint/genparams )
 endif MAINTAINER_MODE
More information about the mpich2-commits mailing list
