[mpich2-commits] r9535 - mpich2/trunk
balaji at mcs.anl.gov
Fri Feb 24 21:54:38 CST 2012
Author: balaji
Date: 2012-02-24 21:54:37 -0600 (Fri, 24 Feb 2012)
New Revision: 9535
Modified:
mpich2/trunk/configure.in
Log:
Get rid of CHAR_PTR_IS_BYTE and HAVE_LARGEST_STRUCT_ALIGNMENT since
they are unused.
Modified: mpich2/trunk/configure.in
--- mpich2/trunk/configure.in 2012-02-25 03:54:33 UTC (rev 9534)
+++ mpich2/trunk/configure.in 2012-02-25 03:54:37 UTC (rev 9535)
@@ -2900,8 +2900,6 @@
pac_cv_c_struct_align_nr=4
elif test "$pac_cv_c_max_integer_align" = "eight" ; then
pac_cv_c_struct_align_nr=8
-elif test "$pac_cv_c_max_integer_align" = "largest" ; then
- AC_DEFINE(HAVE_LARGEST_STRUCT_ALIGNMENT,1,[Define when alignment of structures is based on largest component])
fi
if test -n "$pac_cv_c_struct_align_nr" ; then
@@ -4504,23 +4502,8 @@
fi
-# Is char * the byte address?
-AC_CACHE_CHECK([if char * pointers use byte addresses],
-pac_cv_c_char_p_is_byte,[
-AC_TRY_RUN([
-int main(int argc, char **argv ){
-char *a, buf;
-a = &buf;
-if ((long)(a-(char*)0) == (long)(a)) return 0; return 1;
-}],pac_cv_c_char_p_is_byte=yes,pac_cv_char_p_is_byte=no,
-pac_cv_char_p_is_byte=unknown)])
-if test "$pac_cv_char_p_is_byte" = "yes" ; then
- AC_DEFINE(CHAR_PTR_IS_BYTE,1,[define if char * is byte pointer])
-fi
# Check for the alignment rules moves with types int64_t etc. These
# are used in the datatype code to perform pack and unpack operations.
# These only determine if different alignments *work*, not whether they
More information about the mpich2-commits
