[mpich2-commits] r7831 - in mpich2/trunk: confdb test/mpi
    chan at mcs.anl.gov
    chan at mcs.anl.gov
    Tue Jan 25 22:28:44 CST 2011
Author: chan
Date: 2011-01-25 22:28:43 -0600 (Tue, 25 Jan 2011)
New Revision: 7831
Modified:
   mpich2/trunk/confdb/aclocal_f77.m4
   mpich2/trunk/confdb/aclocal_f77new.m4
   mpich2/trunk/confdb/aclocal_fc.m4
   mpich2/trunk/test/mpi/configure.in
Log:
patched PAC_PROG_F*_HAS_POINTER to check for extra cray-pointer flag so allocmenf* tests can be carried if compiler support is there.  This resolves req#1079.
Modified: mpich2/trunk/confdb/aclocal_f77.m4
--- mpich2/trunk/confdb/aclocal_f77.m4	2011-01-25 19:45:58 UTC (rev 7830)
+++ mpich2/trunk/confdb/aclocal_f77.m4	2011-01-26 04:28:43 UTC (rev 7831)
@@ -1158,34 +1158,6 @@
-dnl /*D
-dnl PAC_PROG_F77_HAS_POINTER - Determine if Fortran allows pointer type
-dnl
-dnl Synopsis:
-dnl   PAC_PROG_F77_HAS_POINTER(action-if-true,action-if-false)
-dnl D*/
-AC_DEFUN([PAC_PROG_F77_HAS_POINTER],[
-AC_CACHE_CHECK([whether Fortran has pointer declaration],
-pac_cv_prog_f77_has_pointer,[
-AC_LANG_SAVE
-AC_LANG_FORTRAN77
-AC_COMPILE_IFELSE([AC_LANG_PROGRAM(,[
-        integer M
-        pointer (MPTR,M)
-        data MPTR/0/
-    pac_cv_prog_f77_has_pointer="yes",
-    pac_cv_prog_f77_has_pointer="no")
-AC_LANG_RESTORE
-if test "$pac_cv_prog_f77_has_pointer" = "yes" ; then
-    ifelse([$1],,:,[$1])
-else
-    ifelse([$2],,:,[$2])
-fi
 dnl pac_prog_f77_run_proc_from_c( c main program, fortran routine,
 dnl                               action-if-works, action-if-fails,
 dnl                               cross-action )
Modified: mpich2/trunk/confdb/aclocal_f77new.m4
--- mpich2/trunk/confdb/aclocal_f77new.m4	2011-01-25 19:45:58 UTC (rev 7830)
+++ mpich2/trunk/confdb/aclocal_f77new.m4	2011-01-26 04:28:43 UTC (rev 7831)
@@ -52,3 +52,39 @@
 AC_LANG_POP([Fortran 77])
 AC_MSG_RESULT([$pac_cv_f77_accepts_F])
+dnl /*D
+dnl PAC_PROG_F77_HAS_POINTER - Determine if Fortran allows pointer type
+dnl
+dnl Synopsis:
+dnl   PAC_PROG_F77_HAS_POINTER(action-if-true,action-if-false)
+dnl D*/
+AC_DEFUN([PAC_PROG_F77_HAS_POINTER],[
+AC_CACHE_CHECK([whether Fortran 77 supports Cray-style pointer],
+pac_cv_prog_f77_has_pointer,[
+AC_LANG_PUSH([Fortran 77])
+AC_LANG_CONFTEST([
+    AC_LANG_PROGRAM([],[
+        integer M
+        pointer (MPTR,M)
+        data MPTR/0/
+saved_FFLAGS="$FFLAGS"
+pac_cv_prog_f77_has_pointer=""
+for ptrflag in '' '-fcray-pointer' ; do
+    FFLAGS="$saved_FFLAGS $ptrflag"
+    AC_COMPILE_IFELSE([], [pac_cv_prog_f77_has_pointer="yes";break], [])
+done
+if test "$pac_cv_prog_f77_has_pointer" = "yes" -a "X$ptrflag" != "X" ; then
+    pac_cv_prog_f77_has_pointer="with $ptrflag"
+fi
+AC_LANG_POP([Fortran 77])
+if test "X$pac_cv_prog_f77_has_pointer" != "X" ; then
+    ifelse([$1],,:,[$1])
+else
+    ifelse([$2],,:,[$2])
+fi
Modified: mpich2/trunk/confdb/aclocal_fc.m4
--- mpich2/trunk/confdb/aclocal_fc.m4	2011-01-25 19:45:58 UTC (rev 7830)
+++ mpich2/trunk/confdb/aclocal_fc.m4	2011-01-26 04:28:43 UTC (rev 7831)
@@ -419,23 +419,28 @@
 dnl   PAC_PROG_FC_HAS_POINTER(action-if-true,action-if-false)
 dnl D*/
 AC_DEFUN([PAC_PROG_FC_HAS_POINTER],[
-AC_CACHE_CHECK([whether Fortran 90 has Cray-style pointer declaration],
+AC_CACHE_CHECK([whether Fortran 90 supports Cray-style pointer],
 pac_cv_prog_fc_has_pointer,[
 AC_LANG_PUSH(Fortran)
+AC_LANG_CONFTEST([
         integer M
         pointer (MPTR,M)
         data MPTR/0/
-    pac_cv_prog_fc_has_pointer="yes"
-    pac_cv_prog_fc_has_pointer="no"
-]) dnl Endof AC_COMPILE_IFELSE
+saved_FCFLAGS="$FCFLAGS"
+pac_cv_prog_fc_has_pointer=""
+    FCFLAGS="$saved_FCFLAGS $ptrflag"
+    AC_COMPILE_IFELSE([], [pac_cv_prog_fc_has_pointer="yes";break], [])
+done
+if test "$pac_cv_prog_fc_has_pointer" = "yes" -a "X$ptrflag" != "X" ; then
+    pac_cv_prog_fc_has_pointer="with $ptrflag"
+fi
 AC_LANG_POP(Fortran)
-if test "$pac_cv_prog_fc_has_pointer" = "yes" ; then
+if test "X$pac_cv_prog_fc_has_pointer" != "X" ; then
 else
Modified: mpich2/trunk/test/mpi/configure.in
--- mpich2/trunk/test/mpi/configure.in	2011-01-25 19:45:58 UTC (rev 7830)
+++ mpich2/trunk/test/mpi/configure.in	2011-01-26 04:28:43 UTC (rev 7831)
@@ -976,12 +976,6 @@
 if test "$FROM_MPICH2" = yes ; then
     # Set compilers/flags to be substituted in output files, e.g. Makefiles.
     LDFLAGS="$saveLDFLAGS"
-    # As part of MPICH2 configure, set all xFLAGS to null
-    # as mpiXX already contains xFLAGS.
-    CFLAGS=""
-    CXXFLAGS=""
-    FFLAGS=""
-    FCFLAGS=""
     # note that the default definition of bindir is
     #    '${exec_prefix}/bin'
     # so even if prefix is set, exec prefix is not until
More information about the mpich2-commits
