[mpich2-commits] r7827 - in mpich2/trunk/src: include mpi/pt2pt
goodell at mcs.anl.gov
Tue Jan 25 11:18:52 CST 2011
Author: goodell
Date: 2011-01-25 11:18:52 -0600 (Tue, 25 Jan 2011)
New Revision: 7827
Modified:
mpich2/trunk/src/include/mpiimpl.h
mpich2/trunk/src/mpi/pt2pt/mpir_request.c
mpich2/trunk/src/mpi/pt2pt/waitall.c
Log:
"fastpath" MPI_Waitall for high-message-rate situations
Based on suggestions from Sameer Kumar and others at IBM.
Reviewed by buntinas at .
Modified: mpich2/trunk/src/include/mpiimpl.h
--- mpich2/trunk/src/include/mpiimpl.h 2011-01-25 05:15:30 UTC (rev 7826)
+++ mpich2/trunk/src/include/mpiimpl.h 2011-01-25 17:18:52 UTC (rev 7827)
@@ -2080,6 +2080,7 @@
int MPIR_dup_fn ( MPI_Comm, int, void *, void *, void *, int * );
/* marks a request as complete, extracting the status */
int MPIR_Request_complete(MPI_Request *, MPID_Request *, MPI_Status *, int *);
int MPIR_Request_get_error(MPID_Request *);
/* run the progress engine until the given request is complete */
int MPIR_Progress_wait_request(MPID_Request *req);
@@ -3675,4 +3676,41 @@
int MPIR_Comm_set_attr_impl(MPID_Comm *comm_ptr, int comm_keyval, void *attribute_val,
MPIR_AttrType attrType);
+/* The "fastpath" version of MPIR_Request_complete. It only handles
+ * MPID_REQUEST_SEND and MPID_REQUEST_RECV kinds, and it does not attempt to
+ * deal with status structures under the assumption that bleeding fast code will
+ * pass either MPI_STATUS_IGNORE or MPI_STATUSES_IGNORE as appropriate. This
+ * routine (or some a variation of it) is an unfortunately necessary stunt to
+ * get high message rates on key benchmarks for high-end systems.
+#undef FUNCNAME
+#define FUNCNAME MPIR_Request_complete_fastpath
+#undef FCNAME
+#define FCNAME MPIU_QUOTE(FUNCNAME)
+static inline int MPIR_Request_complete_fastpath(MPI_Request *request, MPID_Request *request_ptr)
+ int mpi_errno = MPI_SUCCESS;
+ MPIU_Assert(request_ptr->kind == MPID_REQUEST_SEND || request_ptr->kind == MPID_REQUEST_RECV);
+ if (request_ptr->kind == MPID_REQUEST_SEND) {
+ /* FIXME: are Ibsend requests added to the send queue? */
+ MPIR_SENDQ_FORGET(request_ptr);
+ /* the completion path for SEND and RECV is the same at this time, modulo
+ * the SENDQ hook above */
+ mpi_errno = request_ptr->status.MPI_ERROR;
+ MPID_Request_release(request_ptr);
+ *request = MPI_REQUEST_NULL;
+ /* avoid normal fn_exit/fn_fail jump pattern to reduce jumps and compiler confusion */
+ return mpi_errno;
+/* avoid conflicts in source files with old-style "char FCNAME[]" vars */
+#undef FUNCNAME
+#undef FCNAME
#endif /* MPIIMPL_INCLUDED */
Modified: mpich2/trunk/src/mpi/pt2pt/mpir_request.c
--- mpich2/trunk/src/mpi/pt2pt/mpir_request.c 2011-01-25 05:15:30 UTC (rev 7826)
+++ mpich2/trunk/src/mpi/pt2pt/mpir_request.c 2011-01-25 17:18:52 UTC (rev 7827)
@@ -44,7 +44,6 @@
return mpi_errno;
#undef FUNCNAME
#undef FCNAME
Modified: mpich2/trunk/src/mpi/pt2pt/waitall.c
--- mpich2/trunk/src/mpi/pt2pt/waitall.c 2011-01-25 05:15:30 UTC (rev 7826)
+++ mpich2/trunk/src/mpi/pt2pt/waitall.c 2011-01-25 17:18:52 UTC (rev 7827)
@@ -8,7 +8,8 @@
#include "mpiimpl.h"
#if !defined(MPID_REQUEST_PTR_ARRAY_SIZE)
-#define MPID_REQUEST_PTR_ARRAY_SIZE 16
+/* use a larger default size of 64 in order to enhance SQMR performance */
+#define MPID_REQUEST_PTR_ARRAY_SIZE 64
#endif
/* -- Begin Profiling Symbol Block for routine MPI_Waitall */
@@ -45,8 +46,9 @@
int rc;
int n_greqs;
const int ignoring_statuses = (array_of_statuses == MPI_STATUSES_IGNORE);
+ int optimize = ignoring_statuses; /* see NOTE-O1 */
MPIU_CHKLMEM_DECL(1);
/* Convert MPI request handles to a request object pointers */
if (count > MPID_REQUEST_PTR_ARRAY_SIZE)
@@ -71,6 +73,12 @@
MPID_END_ERROR_CHECKS;
# endif
+ if (request_ptrs[i]->kind != MPID_REQUEST_RECV &&
+ request_ptrs[i]->kind != MPID_REQUEST_SEND)
+ optimize = FALSE;
if (request_ptrs[i]->kind == MPID_UREQUEST)
++n_greqs;
@@ -80,6 +88,7 @@
MPIR_Status_set_empty(status_ptr);
request_ptrs[i] = NULL;
n_completed += 1;
+ optimize = FALSE;
@@ -88,6 +97,34 @@
goto fn_exit;
+ /* NOTE-O1: high-message-rate optimization. For simple send and recv
+ * operations and MPI_STATUSES_IGNORE we use a fastpath approach that strips
+ * out as many unnecessary jumps and error handling as possible.
+ * Possible variation: permit request_ptrs[i]==NULL at the cost of an
+ * additional branch inside the for-loop below. */
+ if (optimize) {
+ for (i = 0; i < count; ++i) {
+ while (!MPID_Request_is_complete(request_ptrs[i])) {
+ mpi_errno = MPID_Progress_wait(&progress_state);
+ /* must check and handle the error, can't guard with HAVE_ERROR_CHECKING, but it's
+ * OK for the error case to be slower */
+ if (unlikely(mpi_errno)) {
+ /* --BEGIN ERROR HANDLING-- */
+ MPID_Progress_end(&progress_state);
+ MPIU_ERR_POP(mpi_errno);
+ /* --END ERROR HANDLING-- */
+ mpi_errno = MPIR_Request_complete_fastpath(&array_of_requests[i], request_ptrs[i]);
+ if (mpi_errno) MPIU_ERR_POP(mpi_errno);
+ goto fn_exit;
+ /* ------ "slow" code path below ------ */
/* Grequest_waitall may run the progress engine - thus, we don't
invoke progress_start until after running Grequest_waitall */
/* first, complete any generalized requests */
More information about the mpich2-commits
