[mpich2-commits] r7804 - in mpich2/trunk: . src/include src/mpi/coll src/mpi/comm
goodell at mcs.anl.gov
Fri Jan 21 12:37:25 CST 2011
Author: goodell
Date: 2011-01-21 12:37:25 -0600 (Fri, 21 Jan 2011)
New Revision: 7804
Modified:
mpich2/trunk/CHANGES
mpich2/trunk/src/include/mpiimpl.h
mpich2/trunk/src/mpi/coll/iallreduce.c
mpich2/trunk/src/mpi/comm/commutil.c
Log:
default implementation of MPIX_Iallreduce
This version uses a naive ireduce+ibcast algorithm for intracomms. We should
definitely port the other algorithms from MPIR_Allreduce_intra to this
routine.
No reviewer.
Modified: mpich2/trunk/CHANGES
--- mpich2/trunk/CHANGES 2011-01-21 18:32:12 UTC (rev 7803)
+++ mpich2/trunk/CHANGES 2011-01-21 18:37:25 UTC (rev 7804)
@@ -6,7 +6,8 @@
"MPIX_" functions (e.g. "MPIX_Ibcast"). All functions are provided and are
available for device-level overrides, but only a subset of the functions have
device-independent implementations at this time. The current list of working
- functions is: MPIX_Ibcast, MPIX_Ibarrier, MPIX_Ireduce, MPIX_Ialltoallv.
+ functions is: MPIX_Ibcast, MPIX_Ibarrier, MPIX_Ireduce, MPIX_Ialltoallv,
+ MPIX_Iallreduce.
Modified: mpich2/trunk/src/include/mpiimpl.h
--- mpich2/trunk/src/include/mpiimpl.h 2011-01-21 18:32:12 UTC (rev 7803)
+++ mpich2/trunk/src/include/mpiimpl.h 2011-01-21 18:37:25 UTC (rev 7804)
@@ -3553,6 +3553,9 @@
int MPIR_Ireduce_binomial(void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPID_Comm *comm_ptr, MPID_Sched_t s);
int MPIR_Ialltoallv_intra(void *sendbuf, int *sendcounts, int *sdispls, MPI_Datatype sendtype, void *recvbuf, int *recvcounts, int *rdispls, MPI_Datatype recvtype, MPID_Comm *comm_ptr, MPID_Sched_t s);
int MPIR_Ialltoallv_inter(void *sendbuf, int *sendcounts, int *sdispls, MPI_Datatype sendtype, void *recvbuf, int *recvcounts, int *rdispls, MPI_Datatype recvtype, MPID_Comm *comm_ptr, MPID_Sched_t s);
+int MPIR_Iallreduce_intra(void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPID_Comm *comm_ptr, MPID_Sched_t s);
+int MPIR_Iallreduce_inter(void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPID_Comm *comm_ptr, MPID_Sched_t s);
+int MPIR_Iallreduce_naive(void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPID_Comm *comm_ptr, MPID_Sched_t s);
/* random initializers */
Modified: mpich2/trunk/src/mpi/coll/iallreduce.c
--- mpich2/trunk/src/mpi/coll/iallreduce.c 2011-01-21 18:32:12 UTC (rev 7803)
+++ mpich2/trunk/src/mpi/coll/iallreduce.c 2011-01-21 18:37:25 UTC (rev 7804)
@@ -24,7 +24,134 @@
/* any non-MPI functions go here, especially non-static ones */
+/* implements the naive intracomm allreduce, that is, reduce followed by bcast */
#undef FUNCNAME
+#define FUNCNAME MPIR_Iallreduce_naive
+#undef FCNAME
+#define FCNAME MPIU_QUOTE(FUNCNAME)
+ int mpi_errno = MPI_SUCCESS;
+ mpi_errno = MPIR_Ireduce_intra(sendbuf, recvbuf, count, datatype, op, 0, comm_ptr, s);
+ if (mpi_errno) MPIU_ERR_POP(mpi_errno);
+ mpi_errno = MPID_Sched_barrier(s);
+ mpi_errno = MPIR_Ibcast_intra(recvbuf, count, datatype, 0, comm_ptr, s);
+fn_exit:
+ return mpi_errno;
+fn_fail:
+ goto fn_exit;
+#undef FUNCNAME
+#define FUNCNAME MPIR_Iallreduce_intra
+#undef FCNAME
+ int is_homogeneous;
+ MPIU_Assert(comm_ptr->comm_kind == MPID_INTRACOMM);
+ is_homogeneous = TRUE;
+#ifdef MPID_HAS_HETERO
+ if (comm_ptr->is_hetero)
+ is_homogeneous = FALSE;
+#endif
+ MPIU_Assert(is_homogeneous); /* no hetero for the moment */
+ /* TODO port the better algorithms from MPIR_Allreduce_intra to augment the
+ * naive implementation */
+ mpi_errno = MPIR_Iallreduce_naive(sendbuf, recvbuf, count, datatype, op, comm_ptr, s);
+fn_exit:
+ return mpi_errno;
+fn_fail:
+ goto fn_exit;
+#undef FUNCNAME
+#define FUNCNAME MPIR_Iallreduce_inter
+#undef FCNAME
+/* Intercommunicator Allreduce.
+ We first do an intercommunicator reduce to rank 0 on left group,
+ then an intercommunicator reduce to rank 0 on right group, followed
+ by local intracommunicator broadcasts in each group.
+ We don't do local reduces first and then intercommunicator
+ broadcasts because it would require allocation of a temporary buffer.
+ int rank, root;
+ MPID_Comm *lcomm_ptr = NULL;
+ MPIU_Assert(comm_ptr->comm_kind == MPID_INTERCOMM);
+ rank = comm_ptr->rank;
+ /* first do a reduce from right group to rank 0 in left group,
+ then from left group to rank 0 in right group*/
+ if (comm_ptr->is_low_group) {
+ /* reduce from right group to rank 0*/
+ root = (rank == 0) ? MPI_ROOT : MPI_PROC_NULL;
+ mpi_errno = MPIR_Ireduce_inter(sendbuf, recvbuf, count, datatype, op, root, comm_ptr, s);
+ /* no barrier, these reductions can be concurrent */
+ /* reduce to rank 0 of right group */
+ root = 0;
+ else {
+ /* reduce to rank 0 of left group */
+ root = 0;
+ /* reduce from right group to rank 0 */
+ /* don't bcast until the reductions have finished */
+ /* Get the local intracommunicator */
+ if (!comm_ptr->local_comm) {
+ MPIR_Setup_intercomm_localcomm( comm_ptr );
+ lcomm_ptr = comm_ptr->local_comm;
+ MPIU_Assert(lcomm_ptr->coll_fns && lcomm_ptr->coll_fns->Ibcast);
+ mpi_errno = lcomm_ptr->coll_fns->Ibcast(recvbuf, count, datatype, 0, lcomm_ptr, s);
+fn_exit:
+ return mpi_errno;
+fn_fail:
+ goto fn_exit;
+#undef FUNCNAME
#define FUNCNAME MPIR_Iallreduce_impl
#undef FCNAME
Modified: mpich2/trunk/src/mpi/comm/commutil.c
--- mpich2/trunk/src/mpi/comm/commutil.c 2011-01-21 18:32:12 UTC (rev 7803)
+++ mpich2/trunk/src/mpi/comm/commutil.c 2011-01-21 18:37:25 UTC (rev 7804)
@@ -245,6 +245,7 @@
ops->Ibarrier = &MPIR_Ibarrier_intra;
ops->Ireduce = &MPIR_Ireduce_intra;
ops->Ialltoallv = &MPIR_Ialltoallv_intra;
+ ops->Iallreduce = &MPIR_Iallreduce_intra;
/* TODO add other fns here as they are added */
/* override defaults, such as for SMP */
@@ -276,6 +277,7 @@
ops->Ibarrier = &MPIR_Ibarrier_inter;
ops->Ireduce = &MPIR_Ireduce_inter;
ops->Ialltoallv = &MPIR_Ialltoallv_inter;
+ ops->Iallreduce = &MPIR_Iallreduce_inter;
ic_default_collops = ops;
More information about the mpich2-commits
