[mpich2-commits] r7791 - in mpich2/trunk: . src/include src/mpi/coll src/mpi/comm
goodell at mcs.anl.gov
Thu Jan 20 16:09:17 CST 2011
Author: goodell
Date: 2011-01-20 16:09:17 -0600 (Thu, 20 Jan 2011)
New Revision: 7791
Modified:
mpich2/trunk/CHANGES
mpich2/trunk/src/include/mpiimpl.h
mpich2/trunk/src/mpi/coll/ireduce.c
mpich2/trunk/src/mpi/comm/commutil.c
Log:
default implementation of MPIX_Ireduce
This version only provides a binomial reduce algorithm that was lifted
from the existing MPI_Reduce code.
No reviewer.
Modified: mpich2/trunk/CHANGES
--- mpich2/trunk/CHANGES 2011-01-20 22:09:14 UTC (rev 7790)
+++ mpich2/trunk/CHANGES 2011-01-20 22:09:17 UTC (rev 7791)
@@ -6,7 +6,7 @@
"MPIX_" functions (e.g. "MPIX_Ibcast"). All functions are provided and are
available for device-level overrides, but only a subset of the functions have
device-independent implementations at this time. The current list of working
- functions is: MPIX_Ibcast, MPIX_Ibarrier.
+ functions is: MPIX_Ibcast, MPIX_Ibarrier, MPIX_Ireduce.
Modified: mpich2/trunk/src/include/mpiimpl.h
--- mpich2/trunk/src/include/mpiimpl.h 2011-01-20 22:09:14 UTC (rev 7790)
+++ mpich2/trunk/src/include/mpiimpl.h 2011-01-20 22:09:17 UTC (rev 7791)
@@ -3525,6 +3525,9 @@
int MPIR_Ibcast_SMP(void *buffer, int count, MPI_Datatype datatype, int root, MPID_Comm *comm_ptr, MPID_Sched_t s);
int MPIR_Ibarrier_intra(MPID_Comm *comm_ptr, MPID_Sched_t s);
int MPIR_Ibarrier_inter(MPID_Comm *comm_ptr, MPID_Sched_t s);
+int MPIR_Ireduce_intra(void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPID_Comm *comm_ptr, MPID_Sched_t s);
+int MPIR_Ireduce_inter(void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPID_Comm *comm_ptr, MPID_Sched_t s);
+int MPIR_Ireduce_binomial(void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPID_Comm *comm_ptr, MPID_Sched_t s);
/* random initializers */
Modified: mpich2/trunk/src/mpi/coll/ireduce.c
--- mpich2/trunk/src/mpi/coll/ireduce.c 2011-01-20 22:09:14 UTC (rev 7790)
+++ mpich2/trunk/src/mpi/coll/ireduce.c 2011-01-20 22:09:17 UTC (rev 7791)
@@ -5,6 +5,7 @@
#include "mpiimpl.h"
+#include "collutil.h"
/* -- Begin Profiling Symbol Block for routine MPIX_Ireduce */
#if defined(HAVE_PRAGMA_WEAK)
@@ -25,6 +26,289 @@
/* any non-MPI functions go here, especially non-static ones */
#undef FUNCNAME
+#define FUNCNAME MPIR_Ireduce_binomial
+#undef FCNAME
+#define FCNAME MPIU_QUOTE(FUNCNAME)
+ int mpi_errno = MPI_SUCCESS;
+ int comm_size, rank, is_commutative;
+ int mask, relrank, source, lroot;
+ MPI_Aint true_lb, true_extent, extent;
+ void *tmp_buf;
+ void *real_tmp_buf = NULL;
+ void *real_recvbuf = NULL;
+ MPIU_CHKPMEM_DECL(2);
+ MPIU_THREADPRIV_DECL;
+ MPIU_Assert(comm_ptr->comm_kind == MPID_INTRACOMM);
+ if (count == 0) return MPI_SUCCESS;
+ comm_size = comm_ptr->local_size;
+ rank = comm_ptr->rank;
+ /* set op_errno to 0. stored in perthread structure */
+ MPIU_THREADPRIV_GET;
+ MPIU_THREADPRIV_FIELD(op_errno) = 0;
+ /* Create a temporary buffer */
+ MPIR_Type_get_true_extent_impl(datatype, &true_lb, &true_extent);
+ MPID_Datatype_get_extent_macro(datatype, extent);
+ is_commutative = MPIR_Op_is_commutative(op);
+ /* I think this is the worse case, so we can avoid an assert()
+ * inside the for loop */
+ /* should be buf+{this}? */
+ MPID_Ensure_Aint_fits_in_pointer(count * MPIR_MAX(extent, true_extent));
+ MPIU_CHKPMEM_MALLOC(tmp_buf, void *, count*(MPIR_MAX(extent,true_extent)),
+ mpi_errno, "temporary buffer");
+ /* adjust for potential negative lower bound in datatype */
+ real_tmp_buf = tmp_buf;
+ tmp_buf = (void *)((char*)tmp_buf - true_lb);
+ /* If I'm not the root, then my recvbuf may not be valid, therefore
+ I have to allocate a temporary one */
+ if (rank != root) {
+ MPIU_CHKPMEM_MALLOC(recvbuf, void *,
+ count*(MPIR_MAX(extent,true_extent)),
+ mpi_errno, "receive buffer");
+ real_recvbuf = recvbuf;
+ recvbuf = (void *)((char*)recvbuf - true_lb);
+ if ((rank != root) || (sendbuf != MPI_IN_PLACE)) {
+ /* could do this up front as an MPIR_Localcopy instead, but we'll defer
+ * it to the progress engine */
+ mpi_errno = MPID_Sched_copy(sendbuf, count, datatype, recvbuf, count, datatype, s);
+ if (mpi_errno) MPIU_ERR_POP(mpi_errno);
+ mpi_errno = MPID_Sched_barrier(s);
+ /* This code is from MPICH-1. */
+ /* Here's the algorithm. Relative to the root, look at the bit pattern in
+ my rank. Starting from the right (lsb), if the bit is 1, send to
+ the node with that bit zero and exit; if the bit is 0, receive from the
+ node with that bit set and combine (as long as that node is within the
+ group)
+ Note that by receiving with source selection, we guarentee that we get
+ the same bits with the same input. If we allowed the parent to receive
+ the children in any order, then timing differences could cause different
+ results (roundoff error, over/underflows in some cases, etc).
+ Because of the way these are ordered, if root is 0, then this is correct
+ for both commutative and non-commutitive operations. If root is not
+ 0, then for non-commutitive, we use a root of zero and then send
+ the result to the root. To see this, note that the ordering is
+ mask = 1: (ab)(cd)(ef)(gh) (odds send to evens)
+ mask = 2: ((ab)(cd))((ef)(gh)) (3,6 send to 0,4)
+ mask = 4: (((ab)(cd))((ef)(gh))) (4 sends to 0)
+ Comments on buffering.
+ If the datatype is not contiguous, we still need to pass contiguous
+ data to the user routine.
+ In this case, we should make a copy of the data in some format,
+ and send/operate on that.
+ In general, we can't use MPI_PACK, because the alignment of that
+ is rather vague, and the data may not be re-usable. What we actually
+ need is a "squeeze" operation that removes the skips.
+ mask = 0x1;
+ if (is_commutative)
+ lroot = root;
+ else
+ lroot = 0;
+ relrank = (rank - lroot + comm_size) % comm_size;
+ while (mask < comm_size) {
+ /* Receive */
+ if ((mask & relrank) == 0) {
+ source = (relrank | mask);
+ if (source < comm_size) {
+ source = (source + lroot) % comm_size;
+ mpi_errno = MPID_Sched_recv(tmp_buf, count, datatype, source, comm_ptr, s);
+ /* The sender is above us, so the received buffer must be
+ the second argument (in the noncommutative case). */
+ if (is_commutative) {
+ mpi_errno = MPID_Sched_reduce(tmp_buf, recvbuf, count, datatype, op, s);
+ else {
+ mpi_errno = MPID_Sched_reduce(recvbuf, tmp_buf, count, datatype, op, s);
+ mpi_errno = MPID_Sched_copy(tmp_buf, count, datatype, recvbuf, count, datatype, s);
+ else {
+ /* I've received all that I'm going to. Send my result to
+ my parent */
+ source = ((relrank & (~ mask)) + lroot) % comm_size;
+ mpi_errno = MPID_Sched_send(recvbuf, count, datatype, source, comm_ptr, s);
+ break;
+ mask <<= 1;
+ if (!is_commutative && (root != 0))
+ if (rank == 0)
+ mpi_errno = MPID_Sched_send(recvbuf, count, datatype, root, comm_ptr, s);
+ else if (rank == root)
+ mpi_errno = MPID_Sched_recv(recvbuf, count, datatype, 0, comm_ptr, s);
+ if (real_tmp_buf) {
+ mpi_errno = MPID_Sched_cb(&MPIR_Sched_cb_free_buf, real_tmp_buf, s);
+ if (rank != root && real_recvbuf) {
+ mpi_errno = MPID_Sched_cb(&MPIR_Sched_cb_free_buf, real_recvbuf, s);
+ MPIU_CHKPMEM_COMMIT();
+fn_exit:
+ return mpi_errno;
+fn_fail:
+ MPIU_CHKPMEM_REAP();
+ goto fn_exit;
+#undef FUNCNAME
+#define FUNCNAME MPIR_Ireduce_intra
+#undef FCNAME
+ /* TODO need to implement additional algorithms */
+ mpi_errno = MPIR_Ireduce_binomial(sendbuf, recvbuf, count, datatype, op, root, comm_ptr, s);
+fn_exit:
+ return mpi_errno;
+fn_fail:
+ goto fn_exit;
+#undef FUNCNAME
+#define FUNCNAME MPIR_Ireduce_inter
+#undef FCNAME
+ int rank;
+ void *tmp_buf = NULL;
+ MPIU_CHKPMEM_DECL(1);
+ MPIU_Assert(comm_ptr->comm_kind == MPID_INTERCOMM);
+/* Intercommunicator reduce.
+ Remote group does a local intracommunicator
+ reduce to rank 0. Rank 0 then sends data to root.
+ if (root == MPI_PROC_NULL) {
+ /* local processes other than root do nothing */
+ return MPI_SUCCESS;
+ if (root == MPI_ROOT) {
+ /* root receives data from rank 0 on remote group */
+ else {
+ /* remote group. Rank 0 allocates temporary buffer, does
+ local intracommunicator reduce, and then sends the data
+ to root. */
+ if (rank == 0) {
+ /* Should MPIU_CHKPMEM_MALLOC do this? */
+ MPIU_CHKPMEM_MALLOC(tmp_buf, void *, count*(MPIR_MAX(extent,true_extent)), mpi_errno, "temporary buffer");
+ if (!comm_ptr->local_comm) {
+ mpi_errno = MPIR_Setup_intercomm_localcomm(comm_ptr);
+ mpi_errno = MPIR_Ireduce_intra(sendbuf, tmp_buf, count, datatype, op, 0, comm_ptr->local_comm, s);
+ if (rank == 0) {
+ mpi_errno = MPID_Sched_send(tmp_buf, count, datatype, root, comm_ptr, s);
+fn_exit:
+ return mpi_errno;
+fn_fail:
+ goto fn_exit;
+#undef FUNCNAME
#define FUNCNAME MPIR_Ireduce_impl
#undef FCNAME
Modified: mpich2/trunk/src/mpi/comm/commutil.c
--- mpich2/trunk/src/mpi/comm/commutil.c 2011-01-20 22:09:14 UTC (rev 7790)
+++ mpich2/trunk/src/mpi/comm/commutil.c 2011-01-20 22:09:17 UTC (rev 7791)
@@ -243,6 +243,7 @@
/* intracomm default defaults... */
ops->Ibcast = &MPIR_Ibcast_intra;
ops->Ibarrier = &MPIR_Ibarrier_intra;
+ ops->Ireduce = &MPIR_Ireduce_intra;
/* TODO add other fns here as they are added */
/* override defaults, such as for SMP */
@@ -272,6 +273,7 @@
/* intracomm defaults */
ops->Ibcast = &MPIR_Ibcast_inter;
ops->Ibarrier = &MPIR_Ibarrier_inter;
+ ops->Ireduce = &MPIR_Ireduce_inter;
ic_default_collops = ops;
More information about the mpich2-commits
