[mpich2-commits] r7786 - in mpich2/trunk/src: include mpi/coll mpi/comm
goodell at mcs.anl.gov
Thu Jan 20 16:09:04 CST 2011
Author: goodell
Date: 2011-01-20 16:09:04 -0600 (Thu, 20 Jan 2011)
New Revision: 7786
Modified:
mpich2/trunk/src/include/mpiimpl.h
mpich2/trunk/src/mpi/coll/ibcast.c
mpich2/trunk/src/mpi/comm/commutil.c
Log:
add MPIR_Ibcast_SMP
Reviewed by balaji at .
Modified: mpich2/trunk/src/include/mpiimpl.h
--- mpich2/trunk/src/include/mpiimpl.h 2011-01-20 22:09:01 UTC (rev 7785)
+++ mpich2/trunk/src/include/mpiimpl.h 2011-01-20 22:09:04 UTC (rev 7786)
@@ -3522,6 +3522,7 @@
int MPIR_Ibcast_intra(void *buffer, int count, MPI_Datatype datatype, int root, MPID_Comm *comm_ptr, MPID_Sched_t s);
int MPIR_Ibcast_inter(void *buffer, int count, MPI_Datatype datatype, int root, MPID_Comm *comm_ptr, MPID_Sched_t s);
+int MPIR_Ibcast_SMP(void *buffer, int count, MPI_Datatype datatype, int root, MPID_Comm *comm_ptr, MPID_Sched_t s);
/* random initializers */
Modified: mpich2/trunk/src/mpi/coll/ibcast.c
--- mpich2/trunk/src/mpi/coll/ibcast.c 2011-01-20 22:09:01 UTC (rev 7785)
+++ mpich2/trunk/src/mpi/coll/ibcast.c 2011-01-20 22:09:04 UTC (rev 7786)
@@ -5,6 +5,7 @@
#include "mpiimpl.h"
+#include "collutil.h"
/* -- Begin Profiling Symbol Block for routine MPIX_Ibcast */
#if defined(HAVE_PRAGMA_WEAK)
@@ -186,10 +187,170 @@
#undef FUNCNAME
-#define FUNCNAME MPIR_Ibcast_intra
+#define FUNCNAME MPIR_Ibcast_SMP
#undef FCNAME
#define FCNAME MPIU_QUOTE(FUNCNAME)
-int MPIR_Ibcast_intra(void *buffer, int count, MPI_Datatype datatype, int root, MPID_Comm *comm_ptr, MPI_Request *request)
+ int mpi_errno = MPI_SUCCESS;
+ int type_size, is_homogeneous;
+ int nbytes=0;
+#if !defined(USE_SMP_COLLECTIVES)
+ MPID_Abort(comm_ptr, MPI_ERR_OTHER, 1, "SMP collectives are disabled!");
+#endif
+ MPIU_Assert(MPIR_Comm_is_node_aware(comm_ptr));
+ is_homogeneous = 1;
+#ifdef MPID_HAS_HETERO
+ if (comm_ptr->is_hetero)
+ is_homogeneous = 0;
+#endif
+ MPIU_Assert(is_homogeneous); /* we don't handle the hetero case yet */
+ if (comm_ptr->node_comm) {
+ MPIU_Assert(comm_ptr->node_comm->coll_fns);
+ MPIU_Assert(comm_ptr->node_comm->coll_fns->Ibcast);
+ if (comm_ptr->node_roots_comm) {
+ MPIU_Assert(comm_ptr->node_roots_comm->coll_fns);
+ MPIU_Assert(comm_ptr->node_roots_comm->coll_fns->Ibcast);
+ /* MPI_Type_size() might not give the accurate size of the packed
+ * datatype for heterogeneous systems (because of padding, encoding,
+ * etc). On the other hand, MPI_Pack_size() can become very
+ * expensive, depending on the implementation, especially for
+ * heterogeneous systems. We want to use MPI_Type_size() wherever
+ * possible, and MPI_Pack_size() in other places.
+ if (is_homogeneous)
+ MPID_Datatype_get_size_macro(datatype, type_size);
+ else
+ MPIR_Pack_size_impl(1, datatype, &type_size);
+ nbytes = type_size * count;
+ /* TODO insert packing here */
+ if ((nbytes < MPIR_PARAM_BCAST_SHORT_MSG_SIZE) || (comm_ptr->local_size < MPIR_PARAM_BCAST_MIN_PROCS))
+ /* send to intranode-rank 0 on the root's node */
+ if (comm_ptr->node_comm != NULL &&
+ MPIU_Get_intranode_rank(comm_ptr, root) > 0) /* is not the node root (0) */
+ { /* and is on our node (!-1) */
+ if (root == comm_ptr->rank) {
+ mpi_errno = MPID_Sched_send(buffer, count, datatype, 0, comm_ptr->node_comm, s);
+ else if (0 == comm_ptr->node_comm->rank) {
+ mpi_errno = MPID_Sched_recv(buffer, count, datatype, MPIU_Get_intranode_rank(comm_ptr, root),
+ comm_ptr->node_comm, s);
+ if (mpi_errno) MPIU_ERR_POP(mpi_errno);
+ mpi_errno = MPID_Sched_barrier(s);
+ /* perform the internode broadcast */
+ if (comm_ptr->node_roots_comm != NULL)
+ mpi_errno = comm_ptr->node_roots_comm->coll_fns->Ibcast(buffer, count, datatype,
+ MPIU_Get_internode_rank(comm_ptr, root),
+ comm_ptr->node_roots_comm, s);
+ /* don't allow the local ops for the intranode phase to start until this has completed */
+ /* perform the intranode broadcast on all except for the root's node */
+ if (comm_ptr->node_comm != NULL)
+ mpi_errno = comm_ptr->node_comm->coll_fns->Ibcast(buffer, count, datatype, 0, comm_ptr->node_comm, s);
+ else /* (nbytes > MPIR_PARAM_BCAST_SHORT_MSG_SIZE) && (comm_ptr->size >= MPIR_PARAM_BCAST_MIN_PROCS) */
+ /* supposedly...
+ smp+doubling good for pof2
+ reg+ring better for non-pof2 */
+ if (nbytes < MPIR_PARAM_BCAST_LONG_MSG_SIZE && MPIU_is_pof2(comm_ptr->local_size, NULL))
+ /* medium-sized msg and pof2 np */
+ /* perform the intranode broadcast on the root's node */
+ /* was binomial */
+ MPIU_Get_intranode_rank(comm_ptr, root),
+ /* FIXME do we need barriers in here at all? */
+#if 0
+ if (MPIU_is_pof2(comm_ptr->node_roots_comm->local_size, NULL))
+ /* was scatter doubling allgather */
+ else
+ /* was scatter ring allgather */
+#endif
+ MPIU_Get_intranode_rank(comm_ptr, root) <= 0) /* 0 if root was local root too */
+ { /* -1 if different node than root */
+ else /* large msg or non-pof2 */
+ /* TODO port scatter_ring_allgather to NBC */
+ mpi_errno = MPIR_Bcast_scatter_ring_allgather(buffer, count, datatype, root, comm_ptr);
+ mpi_errno = MPIR_Ibcast_binomial(buffer, count, datatype, root, comm_ptr, s);
+fn_exit:
+ return mpi_errno;
+fn_fail:
+ goto fn_exit;
+/* Provides a generic "flat" broadcast that doesn't know anything about hierarchy. It will choose
+ * between several different algorithms based on the given parameters. */
#undef FUNCNAME
#undef FCNAME
Modified: mpich2/trunk/src/mpi/comm/commutil.c
--- mpich2/trunk/src/mpi/comm/commutil.c 2011-01-20 22:09:01 UTC (rev 7785)
+++ mpich2/trunk/src/mpi/comm/commutil.c 2011-01-20 22:09:04 UTC (rev 7786)
@@ -249,6 +249,7 @@
case MPID_HIERARCHY_FLAT:
break;
case MPID_HIERARCHY_PARENT:
+ ops->Ibcast = &MPIR_Ibcast_SMP;
break;
case MPID_HIERARCHY_NODE:
break;
More information about the mpich2-commits
