[mpich2-commits] r7780 - in mpich2/trunk/src: include mpi/comm
goodell at mcs.anl.gov goodell at mcs.anl.gov
Thu Jan 20 16:08:44 CST 2011
Author: goodell
Date: 2011-01-20 16:08:44 -0600 (Thu, 20 Jan 2011)
New Revision: 7780
Modified:
   mpich2/trunk/src/include/mpiimpl.h
   mpich2/trunk/src/mpi/comm/commutil.c
Log:
replace is_node_aware in MPID_Comm with a more expressive enum
This should simplify logic for any coll_ops overrides by the device.
Reviewed by balaji at .
Modified: mpich2/trunk/src/include/mpiimpl.h
--- mpich2/trunk/src/include/mpiimpl.h	2011-01-20 22:08:41 UTC (rev 7779)
+++ mpich2/trunk/src/include/mpiimpl.h	2011-01-20 22:08:44 UTC (rev 7780)
@@ -1043,6 +1043,16 @@
 typedef enum MPID_Comm_kind_t {
     MPID_INTRACOMM = 0,
     MPID_INTERCOMM = 1 } MPID_Comm_kind_t;
+/* ideally we could add these to MPID_Comm_kind_t, but there's too much existing
+ * code that assumes that the only valid values are INTRACOMM or INTERCOMM */
+typedef enum MPID_Comm_hierarchy_kind_t {
+    MPID_HIERARCHY_FLAT = 0,        /* no hierarchy */
+    MPID_HIERARCHY_PARENT = 1,      /* has subcommunicators */
+    MPID_HIERARCHY_NODE_ROOTS = 2,  /* is the subcomm for node roots */
+    MPID_HIERARCHY_NODE = 3,        /* is the subcomm for a node */
+    MPID_HIERARCHY_SIZE             /* cardinality of this enum */
+} MPID_Comm_hierarchy_kind_t;
 /* Communicators */
 /*S
@@ -1128,8 +1138,8 @@
     MPID_Errhandler *errhandler; /* Pointer to the error handler structure */
     struct MPID_Comm    *local_comm; /* Defined only for intercomms, holds
 				        an intracomm for the local group */
-    int is_node_aware;           /* true if node topology info is available,
-                                    such as node_comm and node_roots_comm */
+    MPID_Comm_hierarchy_kind_t hierarchy_kind; /* flat, parent, node, or node_roots */
     struct MPID_Comm *node_comm; /* Comm of processes in this comm that are on
                                     the same node as this process. */
     struct MPID_Comm *node_roots_comm; /* Comm of root processes for other nodes. */
@@ -1140,6 +1150,7 @@
     int *internode_table;        /* internode_table[i] gives the rank in
                                     node_roots_comm of rank i in this comm.
                                     It is of size 'local_size'. */
     int           is_low_group;  /* For intercomms only, this boolean is
 				    set for all members of one of the
 				    two groups of processes and clear for
Modified: mpich2/trunk/src/mpi/comm/commutil.c
--- mpich2/trunk/src/mpi/comm/commutil.c	2011-01-20 22:08:41 UTC (rev 7779)
+++ mpich2/trunk/src/mpi/comm/commutil.c	2011-01-20 22:08:44 UTC (rev 7780)
@@ -90,7 +90,7 @@
     comm_p->topo_fns     = NULL;
     comm_p->name[0]      = '\0';
-    comm_p->is_node_aware   = 0;
+    comm_p->hierarchy_kind  = MPID_HIERARCHY_FLAT;
     comm_p->node_comm       = NULL;
     comm_p->node_roots_comm = NULL;
     comm_p->intranode_table = NULL;
@@ -259,6 +259,7 @@
             comm->node_comm->recvcontext_id = comm->node_comm->context_id;
             comm->node_comm->rank = local_rank;
             comm->node_comm->comm_kind = MPID_INTRACOMM;
+            comm->node_comm->hierarchy_kind = MPID_HIERARCHY_NODE;
             comm->node_comm->local_comm = NULL;
             comm->node_comm->local_size  = num_local;
@@ -287,6 +288,7 @@
             comm->node_roots_comm->recvcontext_id = comm->node_roots_comm->context_id;
             comm->node_roots_comm->rank = external_rank;
             comm->node_roots_comm->comm_kind = MPID_INTRACOMM;
+            comm->node_roots_comm->hierarchy_kind = MPID_HIERARCHY_NODE_ROOTS;
             comm->node_roots_comm->local_comm = NULL;
             comm->node_roots_comm->local_size  = num_external;
@@ -305,7 +307,7 @@
             /* don't call MPIR_Comm_commit here */
-        comm->is_node_aware = 1;
+        comm->hierarchy_kind = MPID_HIERARCHY_PARENT;
 fn_exit:
@@ -325,7 +327,7 @@
    collective communication, for example. */
 int MPIR_Comm_is_node_aware(MPID_Comm * comm)
-    return comm->is_node_aware;
+    return (comm->hierarchy_kind == MPID_HIERARCHY_PARENT);
 /* Returns true if the communicator is node-aware and processes in all the nodes
@@ -336,7 +338,7 @@
     int i = 0, curr_nodeidx = 0;
     int *internode_table = comm->internode_table;
-    if (!comm->is_node_aware)
+    if (!MPIR_Comm_is_node_aware(comm))
         return 0;
     for (; i < comm->local_size; i++)
More information about the mpich2-commits mailing list
