[mpich2-commits] r7774 - in mpich2/trunk/src: include mpi/coll
    goodell at mcs.anl.gov
    Thu Jan 20 16:08:26 CST 2011
Author: goodell
Date: 2011-01-20 16:08:26 -0600 (Thu, 20 Jan 2011)
New Revision: 7774
Modified:
   mpich2/trunk/src/include/mpiimpl.h
   mpich2/trunk/src/mpi/coll/reduce_local.c
Log:
refactor MPI_Reduce_local s.t. it has an _impl
This provides a single, simple way to invoke reduction operators from
within the library.
Reviewed by balaji at .
Modified: mpich2/trunk/src/include/mpiimpl.h
--- mpich2/trunk/src/include/mpiimpl.h	2011-01-20 22:08:23 UTC (rev 7773)
+++ mpich2/trunk/src/include/mpiimpl.h	2011-01-20 22:08:26 UTC (rev 7774)
@@ -3470,6 +3470,8 @@
 int MPIR_Barrier_intra( MPID_Comm *comm_ptr );
 int MPIR_Barrier_inter( MPID_Comm *comm_ptr);
+int MPIR_Reduce_local_impl(void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype, MPI_Op op);
 int MPIR_Setup_intercomm_localcomm( MPID_Comm * );
 int MPIR_Comm_create( MPID_Comm ** );
Modified: mpich2/trunk/src/mpi/coll/reduce_local.c
--- mpich2/trunk/src/mpi/coll/reduce_local.c	2011-01-20 22:08:23 UTC (rev 7773)
+++ mpich2/trunk/src/mpi/coll/reduce_local.c	2011-01-20 22:08:26 UTC (rev 7774)
@@ -24,8 +24,72 @@
 #define MPI_Reduce_local PMPI_Reduce_local
 /* any utility functions should go here, usually prefixed with PMPI_LOCAL to
  * correctly handle weak symbols and the profiling interface */
+#undef FUNCNAME
+#define FUNCNAME MPIR_Reduce_local_impl
+#undef FCNAME
+#define FCNAME MPIU_QUOTE(FUNCNAME)
+    int mpi_errno = MPI_SUCCESS;
+    MPID_Op *op_ptr;
+    MPI_User_function *uop;
+#ifdef HAVE_CXX_BINDING
+    int is_cxx_uop = 0;
 #endif
+    MPIU_THREADPRIV_DECL;
+    if (count == 0) goto fn_exit;
+    MPIU_THREADPRIV_GET;
+    MPIU_THREADPRIV_FIELD(op_errno) = MPI_SUCCESS;
+    if (HANDLE_GET_KIND(op) == HANDLE_KIND_BUILTIN) {
+        /* get the function by indexing into the op table */
+        uop = MPIR_Op_table[op%16 - 1];
+    else {
+        MPID_Op_get_ptr(op, op_ptr);
+        if (op_ptr->language == MPID_LANG_CXX) {
+            uop = (MPI_User_function *) op_ptr->function.c_function;
+            is_cxx_uop = 1;
+        else
+#endif
+            if ((op_ptr->language == MPID_LANG_C))
+            else
+                uop = (MPI_User_function *) op_ptr->function.f77_function;
+    /* actually perform the reduction */
+    if (is_cxx_uop) {
+        (*MPIR_Process.cxx_call_op_fn)(inbuf, inoutbuf, count, datatype, uop);
+    else
+#endif
+        (*uop)(inbuf, inoutbuf, &count, &datatype);
+    /* --BEGIN ERROR HANDLING-- */
+    if (MPIU_THREADPRIV_FIELD(op_errno))
+        mpi_errno = MPIU_THREADPRIV_FIELD(op_errno);
+    /* --END ERROR HANDLING-- */
+fn_exit:
+    return mpi_errno;
+fn_fail:
+    goto fn_exit;
+#endif
 #undef FUNCNAME
 #define FUNCNAME MPI_Reduce_local
 #undef FCNAME
@@ -58,12 +122,7 @@
 int MPI_Reduce_local(void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype, MPI_Op op)
-    MPI_User_function *uop;
     MPID_Op *op_ptr;
-#ifdef HAVE_CXX_BINDING
-    int is_cxx_uop = 0;
-#endif
-    MPIU_THREADPRIV_DECL;
     MPID_MPI_STATE_DECL(MPID_STATE_MPI_REDUCE_LOCAL);
     MPIR_ERRTEST_INITIALIZED_ORDIE();
@@ -98,49 +157,8 @@
     /* ... body of routine ...  */
-    if (count == 0) goto fn_exit;
+    mpi_errno = MPIR_Reduce_local_impl(inbuf, inoutbuf, count, datatype, op);
-    MPIU_THREADPRIV_GET;
-    MPIU_THREADPRIV_FIELD(op_errno) = MPI_SUCCESS;
-    if (HANDLE_GET_KIND(op) == HANDLE_KIND_BUILTIN) {
-        /* get the function by indexing into the op table */
-        uop = MPIR_Op_table[op%16 - 1];
-    else {
-        MPID_Op_get_ptr(op, op_ptr);
-        if (op_ptr->language == MPID_LANG_CXX) {
-            uop = (MPI_User_function *) op_ptr->function.c_function;
-            is_cxx_uop = 1;
-        else
-#endif
-            if ((op_ptr->language == MPID_LANG_C))
-            else
-                uop = (MPI_User_function *) op_ptr->function.f77_function;
-    /* actually perform the reduction */
-    if (is_cxx_uop) {
-        (*MPIR_Process.cxx_call_op_fn)(inbuf, inoutbuf, count, datatype, uop);
-    else
-#endif
-        (*uop)(inbuf, inoutbuf, &count, &datatype);
-    /* --BEGIN ERROR HANDLING-- */
-    if (MPIU_THREADPRIV_FIELD(op_errno))
-        mpi_errno = MPIU_THREADPRIV_FIELD(op_errno);
-    /* --END ERROR HANDLING-- */
     /* ... end of body of routine ... */
   fn_exit:
More information about the mpich2-commits
