[mpich2-commits] r7748 - in mpich2/trunk: src/mpi/topo test/mpi/topo
goodell at mcs.anl.gov goodell at mcs.anl.gov
Tue Jan 18 17:16:54 CST 2011
Author: goodell
Date: 2011-01-18 17:16:54 -0600 (Tue, 18 Jan 2011)
New Revision: 7748
Modified:
   mpich2/trunk/src/mpi/topo/dist_gr_create_adj.c
   mpich2/trunk/test/mpi/topo/distgraph1.c
Log:
bugfix: erroneous ARGNULL check in MPI_Dist_graph_create_adjacent (tt#976)
MPI_UNWEIGHTED==NULL, so NULL actually is a valid value for sourceweights.
This change also adds a weak check for MPI_UNWEIGHTED in the distgraph1
test.
No reviewer.
Modified: mpich2/trunk/src/mpi/topo/dist_gr_create_adj.c
--- mpich2/trunk/src/mpi/topo/dist_gr_create_adj.c	2011-01-18 22:46:16 UTC (rev 7747)
+++ mpich2/trunk/src/mpi/topo/dist_gr_create_adj.c	2011-01-18 23:16:54 UTC (rev 7748)
@@ -117,8 +117,7 @@
                 if (sourceweights == MPI_UNWEIGHTED && destweights != MPI_UNWEIGHTED) {
                     MPIU_ERR_SET(mpi_errno, MPIR_ERR_RECOVERABLE, "**unweightedboth");
-                MPIR_ERRTEST_ARGNULL(sourceweights, "sourceweights", mpi_errno);
-                /* XXX DJG TODO check ranges for array elements too (**argarrayneg / **rankarray)*/
+                /* TODO check ranges for array elements too (**argarrayneg / **rankarray)*/
             if (outdegree > 0) {
                 MPIR_ERRTEST_ARGNULL(destinations, "destinations", mpi_errno);
Modified: mpich2/trunk/test/mpi/topo/distgraph1.c
--- mpich2/trunk/test/mpi/topo/distgraph1.c	2011-01-18 22:46:16 UTC (rev 7747)
+++ mpich2/trunk/test/mpi/topo/distgraph1.c	2011-01-18 23:16:54 UTC (rev 7748)
@@ -260,7 +260,16 @@
             MPI_Comm_free(&comm);
+        /* a weak check that passing MPI_UNWEIGHTED doesn't cause
+         * create_adjacent to explode */
+        MPI_Dist_graph_create_adjacent(MPI_COMM_WORLD, indegree, sources, MPI_UNWEIGHTED,
+                                       outdegree, destinations, MPI_UNWEIGHTED, MPI_INFO_NULL,
+                                       reorder, &comm);
+        MPI_Barrier(comm);
+        /* intentionally no verify here, weights won't match */
+        MPI_Comm_free(&comm);
         /* MPI_Dist_graph_create() where each process specifies its
          * outgoing edges */
         if (rank == 0) DPRINTF(("testing MPI_Dist_graph_create w/ outgoing only\n"));
More information about the mpich2-commits mailing list
