[mpich2-commits] r7729 - in mpich2/trunk/src/pm/hydra: include pm/pmiserv tools/bootstrap/external tools/bootstrap/include tools/bootstrap/persist tools/bootstrap/src utils/launch
balaji at mcs.anl.gov
Fri Jan 14 10:16:54 CST 2011
Author: balaji
Date: 2011-01-14 10:16:54 -0600 (Fri, 14 Jan 2011)
New Revision: 7729
Modified:
mpich2/trunk/src/pm/hydra/include/hydra.h
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_pmci.c
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_pmi_v1.c
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_pmi_v2.c
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_utils.c
mpich2/trunk/src/pm/hydra/tools/bootstrap/external/external.h
mpich2/trunk/src/pm/hydra/tools/bootstrap/external/external_launch.c
mpich2/trunk/src/pm/hydra/tools/bootstrap/external/ll.h
mpich2/trunk/src/pm/hydra/tools/bootstrap/external/ll_launch.c
mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm.h
mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm_launch.c
mpich2/trunk/src/pm/hydra/tools/bootstrap/include/bsci.h.in
mpich2/trunk/src/pm/hydra/tools/bootstrap/persist/persist_client.h
mpich2/trunk/src/pm/hydra/tools/bootstrap/persist/persist_launch.c
mpich2/trunk/src/pm/hydra/tools/bootstrap/persist/persist_server.c
mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_launch.c
mpich2/trunk/src/pm/hydra/utils/launch/launch.c
Log:
Redo the quoting of arguments from r7696 and r7709. We now explicitly
quote the executable (again) before passing it to a remote
launcher. This is similar to the approach used in r7696, but we don't
use chdir anymore.
Modified: mpich2/trunk/src/pm/hydra/include/hydra.h
--- mpich2/trunk/src/pm/hydra/include/hydra.h 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/include/hydra.h 2011-01-14 16:16:54 UTC (rev 7729)
@@ -464,8 +464,8 @@
/* launch */
struct HYDT_bind_cpuset_t;
-HYD_status HYDU_create_process(const char *base_path, char **client_arg,
- struct HYD_env *env_list, int *in, int *out, int *err, int *pid,
+HYD_status HYDU_create_process(char **client_arg, struct HYD_env *env_list,
+ int *in, int *out, int *err, int *pid,
struct HYDT_bind_cpuset_t cpuset);
/* others */
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c 2011-01-14 16:16:54 UTC (rev 7729)
@@ -671,7 +671,7 @@
client_args[arg++] = NULL;
HYDT_bind_pid_to_cpuset(process_id, &cpuset);
- status = HYDU_create_process(NULL, client_args, force_env,
+ status = HYDU_create_process(client_args, force_env,
HYD_pmcd_pmip.downstream.pmi_rank[process_id] ? NULL :
&HYD_pmcd_pmip.downstream.in,
&HYD_pmcd_pmip.downstream.out[process_id],
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_pmci.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_pmci.c 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_pmci.c 2011-01-14 16:16:54 UTC (rev 7729)
@@ -157,8 +157,7 @@
HYD_server_info.user_global.bindlib);
HYDU_ERR_POP(status, "unable to initializing binding library");
- status = HYDT_bsci_launch_procs(HYD_server_info.base_path, proxy_args, node_list,
- control_fd);
+ status = HYDT_bsci_launch_procs(proxy_args, node_list, control_fd);
HYDU_ERR_POP(status, "launcher cannot launch processes\n");
for (i = 0, proxy = HYD_server_info.pg_list.proxy_list; proxy; proxy = proxy->next, i++)
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_pmi_v1.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_pmi_v1.c 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_pmi_v1.c 2011-01-14 16:16:54 UTC (rev 7729)
@@ -551,7 +551,7 @@
status = HYD_pmcd_pmi_fill_in_exec_launch_info(pg);
HYDU_ERR_POP(status, "unable to fill in executable arguments\n");
- status = HYDT_bsci_launch_procs(HYD_server_info.base_path, proxy_args, node_list, NULL);
+ status = HYDT_bsci_launch_procs(proxy_args, node_list, NULL);
HYDU_free_node_list(node_list);
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_pmi_v2.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_pmi_v2.c 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_pmi_v2.c 2011-01-14 16:16:54 UTC (rev 7729)
@@ -732,7 +732,7 @@
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_utils.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_utils.c 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_utils.c 2011-01-14 16:16:54 UTC (rev 7729)
@@ -12,7 +12,8 @@
HYD_status HYD_pmcd_pmi_fill_in_proxy_args(char **proxy_args, char *control_port, int pgid)
- int arg, use_ddd, use_valgrind, use_strace;
+ int i, arg, use_ddd, use_valgrind, use_strace;
+ char *path_str[HYD_NUM_TMP_STRINGS];
HYD_status status = HYD_SUCCESS;
arg = 0;
@@ -44,7 +45,14 @@
proxy_args[arg++] = HYDU_strdup("-ff");
- proxy_args[arg++] = HYDU_strdup("hydra_pmi_proxy");
+ i = 0;
+ path_str[i++] = HYDU_strdup(HYD_server_info.base_path);
+ path_str[i++] = HYDU_strdup("hydra_pmi_proxy");
+ path_str[i] = NULL;
+ status = HYDU_str_alloc_and_join(path_str, &proxy_args[arg++]);
+ HYDU_ERR_POP(status, "unable to join strings\n");
+ HYDU_free_strlist(path_str);
proxy_args[arg++] = HYDU_strdup("--control-port");
proxy_args[arg++] = HYDU_strdup(control_port);
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/external/external.h
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/external/external.h 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/external/external.h 2011-01-14 16:16:54 UTC (rev 7729)
@@ -14,8 +14,8 @@
#include "sge.h"
#include "pbs.h"
-HYD_status HYDT_bscd_external_launch_procs(const char *base_path, char **args,
- struct HYD_node *node_list, int *control_fd);
+HYD_status HYDT_bscd_external_launch_procs(char **args, struct HYD_node *node_list,
+ int *control_fd);
HYD_status HYDT_bscd_external_launcher_finalize(void);
HYD_status HYDT_bscd_external_query_env_inherit(const char *env_name, int *ret);
HYD_status HYDT_bscd_external_query_native_int(int *ret);
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/external/external_launch.c
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/external/external_launch.c 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/external/external_launch.c 2011-01-14 16:16:54 UTC (rev 7729)
@@ -12,14 +12,15 @@
static int fd_stdout, fd_stderr;
+ int *control_fd)
int num_hosts, idx, i, host_idx, fd, exec_idx, offset, lh;
int *pid, *fd_list, *dummy;
int sockpair[2];
struct HYD_node *node;
char *targs[HYD_NUM_TMP_STRINGS], *path = NULL, *extra_arg_list = NULL, *extra_arg;
+ char quoted_exec_string[HYD_TMP_STRLEN], *original_exec_string;
struct HYD_env *env = NULL;
struct HYDT_bind_cpuset_t cpuset;
@@ -114,6 +115,14 @@
for (i = 0; args[i]; i++)
targs[idx++] = HYDU_strdup(args[i]);
+ /* Store the original exec string */
+ original_exec_string = targs[exec_idx];
+ /* Create a quoted version of the exec string, which is only used
+ * when the executable is not launched directly, but through an
+ * external launcher */
+ HYDU_snprintf(quoted_exec_string, HYD_TMP_STRLEN, "\"%s\"", targs[exec_idx]);
/* pid_list might already have some PIDs */
num_hosts = 0;
for (node = node_list; node; node = node->next)
@@ -190,6 +199,10 @@
else {
offset = 0;
+ /* We are not launching the executable directly; use the
+ * quoted version */
+ targs[exec_idx] = quoted_exec_string;
/* dummy is NULL only for launchers that can handle a
* closed stdin socket. Older versions of ssh and SGE seem
* to have problems when stdin is closed before they are
@@ -210,11 +223,15 @@
/* The stdin pointer is a dummy value. We don't just pass it
* NULL, as older versions of ssh seem to freak out when no
* stdin socket is provided. */
- status = HYDU_create_process(base_path, targs + offset, env, dummy, &fd_stdout,
- &fd_stderr, &HYD_bscu_pid_list[HYD_bscu_pid_count++],
- cpuset);
+ status = HYDU_create_process(targs + offset, env, dummy, &fd_stdout, &fd_stderr,
+ &HYD_bscu_pid_list[HYD_bscu_pid_count++], cpuset);
HYDU_ERR_POP(status, "create process returned error\n");
+ /* Reset to the original exec string */
+ targs[exec_idx] = original_exec_string;
+ /* Reset the exec string to the original value */
if (offset && control_fd) {
close(sockpair[1]);
HYDU_env_free(env);
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/external/ll.h
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/external/ll.h 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/external/ll.h 2011-01-14 16:16:54 UTC (rev 7729)
@@ -9,8 +9,7 @@
#include "hydra.h"
-HYD_status HYDT_bscd_ll_launch_procs(const char *base_path, char **args,
+HYD_status HYDT_bscd_ll_launch_procs(char **args, struct HYD_node *node_list, int *control_fd);
HYD_status HYDT_bscd_ll_query_proxy_id(int *proxy_id);
HYD_status HYDT_bscd_ll_query_node_list(struct HYD_node **node_list);
HYD_status HYDTI_bscd_ll_query_node_count(int *count);
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/external/ll_launch.c
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/external/ll_launch.c 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/external/ll_launch.c 2011-01-14 16:16:54 UTC (rev 7729)
@@ -12,13 +12,12 @@
int idx, i, total_procs, node_count;
- int *pid, *fd_list;
+ int *pid, *fd_list, exec_idx;
char *targs[HYD_NUM_TMP_STRINGS], *node_list_str = NULL;
- char *path = NULL, *extra_arg_list = NULL, *extra_arg;
+ char *path = NULL, *extra_arg_list = NULL, *extra_arg, quoted_exec_string[HYD_TMP_STRLEN];
@@ -66,9 +65,17 @@
/* Fill in the remaining arguments */
+ exec_idx = idx;
+ HYDU_FREE(targs[exec_idx]);
/* Increase pid list to accommodate the new pid */
HYDU_MALLOC(pid, int *, (HYD_bscu_pid_count + 1) * sizeof(int), status);
for (i = 0; i < HYD_bscu_pid_count; i++)
@@ -88,7 +95,7 @@
targs[idx++] = NULL;
HYDT_bind_cpuset_zero(&cpuset);
- status = HYDU_create_process(base_path, targs, NULL, NULL, &fd_stdout, &fd_stderr,
+ status = HYDU_create_process(targs, NULL, NULL, &fd_stdout, &fd_stderr,
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm.h
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm.h 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm.h 2011-01-14 16:16:54 UTC (rev 7729)
@@ -9,8 +9,8 @@
#include "hydra.h"
-HYD_status HYDT_bscd_slurm_launch_procs(const char *base_path, char **args,
+HYD_status HYDT_bscd_slurm_launch_procs(char **args, struct HYD_node *node_list,
+ int *control_fd);
HYD_status HYDT_bscd_slurm_query_proxy_id(int *proxy_id);
HYD_status HYDT_bscd_slurm_query_node_list(struct HYD_node **node_list);
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm_launch.c
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm_launch.c 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm_launch.c 2011-01-14 16:16:54 UTC (rev 7729)
@@ -59,12 +59,12 @@
goto fn_exit;
+ int *control_fd)
- int num_hosts, idx, i;
+ int num_hosts, idx, i, exec_idx;
int *pid, *fd_list;
- char *targs[HYD_NUM_TMP_STRINGS], *node_list_str = NULL;
+ char *targs[HYD_NUM_TMP_STRINGS], *node_list_str = NULL, quoted_exec_string[HYD_TMP_STRLEN];
@@ -114,9 +114,17 @@
+ exec_idx = idx;
@@ -141,7 +149,7 @@
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/include/bsci.h.in
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/include/bsci.h.in 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/include/bsci.h.in 2011-01-14 16:16:54 UTC (rev 7729)
@@ -51,8 +51,7 @@
/* Launcher functions */
/** \brief Launch processes */
- HYD_status(*launch_procs) (const char *base_path, char **args, struct HYD_node *node_list,
- int *control_fd);
+ HYD_status(*launch_procs) (char **args, struct HYD_node *node_list, int *control_fd);
/** \brief Finalize the bootstrap control device */
HYD_status(*launcher_finalize) (void);
@@ -97,7 +96,6 @@
* \brief HYDT_bsci_launch_procs - Launch processes
- * \param[in] base_path Base path to launch processes from
* \param[in] args Arguments to be used for the launched processes
* \param[in] node_list List of nodes to launch processes on
* \param[out] control_fd Control socket to communicate with the launched process
@@ -115,8 +113,7 @@
* but allow proxies to query their ID information on each node using
* the HYDT_bsci_query_proxy_id function.
-HYD_status HYDT_bsci_launch_procs(const char *base_path, char **args, struct HYD_node *node_list,
- int *control_fd);
+HYD_status HYDT_bsci_launch_procs(char **args, struct HYD_node *node_list, int *control_fd);
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/persist/persist_client.h
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/persist/persist_client.h 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/persist/persist_client.h 2011-01-14 16:16:54 UTC (rev 7729)
@@ -11,8 +11,8 @@
#include "bscu.h"
#include "persist.h"
-HYD_status HYDT_bscd_persist_launch_procs(const char *base_path, char **args,
+HYD_status HYDT_bscd_persist_launch_procs(char **args, struct HYD_node *node_list,
+ int *control_fd);
HYD_status HYDT_bscd_persist_wait_for_completion(int timeout);
extern int *HYDT_bscd_persist_control_fd;
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/persist/persist_launch.c
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/persist/persist_launch.c 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/persist/persist_launch.c 2011-01-14 16:16:54 UTC (rev 7729)
@@ -58,8 +58,8 @@
goto fn_exit;
+ int *control_fd)
int idx, i;
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/persist/persist_server.c
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/persist/persist_server.c 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/persist/persist_server.c 2011-01-14 16:16:54 UTC (rev 7729)
@@ -194,7 +194,7 @@
/* spawn process */
- status = HYDU_create_process(NULL, args, NULL, NULL, &private.stdout_fd,
+ status = HYDU_create_process(args, NULL, NULL, &private.stdout_fd,
&private.stderr_fd, &private.app_pid, cpuset);
HYDU_ERR_POP(status, "unable to create process\n");
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_launch.c
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_launch.c 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_launch.c 2011-01-14 16:16:54 UTC (rev 7729)
@@ -7,14 +7,13 @@
#include "hydra.h"
#include "bsci.h"
HYDU_FUNC_ENTER();
- status = HYDT_bsci_fns.launch_procs(base_path, args, node_list, control_fd);
+ status = HYDT_bsci_fns.launch_procs(args, node_list, control_fd);
HYDU_ERR_POP(status, "launcher returned error while launching processes\n");
fn_exit:
Modified: mpich2/trunk/src/pm/hydra/utils/launch/launch.c
--- mpich2/trunk/src/pm/hydra/utils/launch/launch.c 2011-01-13 23:30:20 UTC (rev 7728)
+++ mpich2/trunk/src/pm/hydra/utils/launch/launch.c 2011-01-14 16:16:54 UTC (rev 7729)
@@ -7,11 +7,11 @@
#include "hydra.h"
#include "bind.h"
- int inpipe[2], outpipe[2], errpipe[2], tpid, ret;
+ int inpipe[2], outpipe[2], errpipe[2], tpid;
HYDU_FUNC_ENTER();
@@ -61,11 +61,6 @@
status = HYDT_bind_process(cpuset);
HYDU_ERR_POP(status, "bind process failed\n");
- if (base_path) {
- ret = chdir(base_path);
- HYDU_ASSERT(!ret, status);
if (execvp(client_arg[0], client_arg) < 0) {
/* The child process should never get back to the proxy
* code; if there is an error, just throw it here and
More information about the mpich2-commits
