[mpich2-commits] r7725 - mpich2/trunk/test/mpi/f77/datatype
chan at mcs.anl.gov
chan at mcs.anl.gov
Thu Jan 13 16:47:22 CST 2011
Author: chan
Date: 2011-01-13 16:47:22 -0600 (Thu, 13 Jan 2011)
New Revision: 7725
Modified:
mpich2/trunk/test/mpi/f77/datatype/allctypesf.f
Log:
applied patch for req#1094 so Fortran tests become consistent with C's datatype/typename.c when long long type isn't avaiable.
Modified: mpich2/trunk/test/mpi/f77/datatype/allctypesf.f
--- mpich2/trunk/test/mpi/f77/datatype/allctypesf.f 2011-01-13 22:43:00 UTC (rev 7724)
+++ mpich2/trunk/test/mpi/f77/datatype/allctypesf.f 2011-01-13 22:47:22 UTC (rev 7725)
@@ -2,9 +2,9 @@
include 'mpif.h'
integer atype, ierr
C
- call mpi_init(ierr)
+ call mtest_init(ierr)
call mpi_comm_set_errhandler( MPI_COMM_WORLD, MPI_ERRORS_RETURN,
- * ierr )
+ * ierr )
C
C Check that all Ctypes are available in Fortran (MPI 2.1, p 483, line 46)
C
@@ -21,13 +21,21 @@
call checkdtype( MPI_UNSIGNED_LONG, "MPI_UNSIGNED_LONG", ierr )
call checkdtype( MPI_FLOAT, "MPI_FLOAT", ierr )
call checkdtype( MPI_DOUBLE, "MPI_DOUBLE", ierr )
- call checkdtype( MPI_LONG_DOUBLE, "MPI_LONG_DOUBLE", ierr )
- call checkdtype2( MPI_LONG_LONG_INT, "MPI_LONG_LONG_INT",
- * "MPI_LONG_LONG", ierr )
- call checkdtype( MPI_UNSIGNED_LONG_LONG,
- * "MPI_UNSIGNED_LONG_LONG", ierr )
- call checkdtype2( MPI_LONG_LONG, "MPI_LONG_LONG",
- * "MPI_LONG_LONG_INT", ierr )
+ if (MPI_LONG_DOUBLE .ne. MPI_DATATYPE_NULL) then
+ call checkdtype( MPI_LONG_DOUBLE, "MPI_LONG_DOUBLE", ierr )
+ endif
+ if (MPI_LONG_LONG_INT .ne. MPI_DATATYPE_NULL) then
+ call checkdtype2( MPI_LONG_LONG_INT, "MPI_LONG_LONG_INT",
+ * "MPI_LONG_LONG", ierr )
+ endif
+ if (MPI_UNSIGNED_LONG_LONG .ne. MPI_DATATYPE_NULL) then
+ call checkdtype( MPI_UNSIGNED_LONG_LONG,
+ * "MPI_UNSIGNED_LONG_LONG", ierr )
+ endif
+ if (MPI_LONG_LONG .ne. MPI_DATATYPE_NULL) then
+ call checkdtype2( MPI_LONG_LONG, "MPI_LONG_LONG",
+ * "MPI_LONG_LONG_INT", ierr )
+ endif
call checkdtype( MPI_PACKED, "MPI_PACKED", ierr )
call checkdtype( MPI_LB, "MPI_LB", ierr )
call checkdtype( MPI_UB, "MPI_UB", ierr )
@@ -36,7 +44,10 @@
call checkdtype( MPI_LONG_INT, "MPI_LONG_INT", ierr )
call checkdtype( MPI_SHORT_INT, "MPI_SHORT_INT", ierr )
call checkdtype( MPI_2INT, "MPI_2INT", ierr )
- call checkdtype( MPI_LONG_DOUBLE_INT, "MPI_LONG_DOUBLE_INT",ierr)
+ if (MPI_LONG_DOUBLE_INT .ne. MPI_DATATYPE_NULL) then
+ call checkdtype( MPI_LONG_DOUBLE_INT, "MPI_LONG_DOUBLE_INT",
+ * ierr)
+ endif
C
C Check that all Ctypes are available in Fortran (MPI 2.2)
C Note that because of implicit declarations in Fortran, this
@@ -52,28 +63,25 @@
call checkdtype( MPI_UINT16_T, "MPI_UINT16_T", ierr )
call checkdtype( MPI_UINT32_T, "MPI_UINT32_T", ierr )
call checkdtype( MPI_UINT64_T, "MPI_UINT64_T", ierr )
-C other C99 types
+C other C99 types
call checkdtype( MPI_C_BOOL, "MPI_C_BOOL", ierr )
call checkdtype( MPI_C_FLOAT_COMPLEX, "MPI_C_FLOAT_COMPLEX",
- * ierr)
+ * ierr)
call checkdtype2( MPI_C_COMPLEX, "MPI_C_COMPLEX",
- * "MPI_C_FLOAT_COMPLEX", ierr )
+ * "MPI_C_FLOAT_COMPLEX", ierr )
call checkdtype( MPI_C_DOUBLE_COMPLEX, "MPI_C_DOUBLE_COMPLEX",
- * ierr )
- call checkdtype( MPI_C_LONG_DOUBLE_COMPLEX,
- * "MPI_C_LONG_DOUBLE_COMPLEX", ierr )
+ * ierr )
+ if (MPI_C_LONG_DOUBLE_COMPLEX .ne. MPI_DATATYPE_NULL) then
+ call checkdtype( MPI_C_LONG_DOUBLE_COMPLEX,
+ * "MPI_C_LONG_DOUBLE_COMPLEX", ierr )
+ endif
C address/offset types
call checkdtype( MPI_AINT, "MPI_AINT", ierr )
call checkdtype( MPI_OFFSET, "MPI_OFFSET", ierr )
endif
C
- if (ierr .eq. 0) then
- print *, " No Errors"
- else
- print *, " Found ", ierr, " errors"
- endif
+ call mtest_finalize( ierr )
call MPI_Finalize( ierr )
- stop
end
C
C Check name of datatype
More information about the mpich2-commits
