[mpich2-commits] r7720 - mpich2/trunk/src/mpi/coll
buntinas at mcs.anl.gov
Thu Jan 13 13:38:44 CST 2011
Author: buntinas
Date: 2011-01-13 13:38:44 -0600 (Thu, 13 Jan 2011)
New Revision: 7720
Modified:
mpich2/trunk/src/mpi/coll/allgather.c
mpich2/trunk/src/mpi/coll/allgatherv.c
mpich2/trunk/src/mpi/coll/allreduce.c
mpich2/trunk/src/mpi/coll/alltoall.c
mpich2/trunk/src/mpi/coll/alltoallw.c
mpich2/trunk/src/mpi/coll/barrier.c
mpich2/trunk/src/mpi/coll/bcast.c
mpich2/trunk/src/mpi/coll/exscan.c
mpich2/trunk/src/mpi/coll/gather.c
mpich2/trunk/src/mpi/coll/gatherv.c
mpich2/trunk/src/mpi/coll/red_scat.c
mpich2/trunk/src/mpi/coll/red_scat_block.c
mpich2/trunk/src/mpi/coll/reduce.c
mpich2/trunk/src/mpi/coll/scan.c
mpich2/trunk/src/mpi/coll/scatter.c
mpich2/trunk/src/mpi/coll/scatterv.c
Log:
Fix collectives to not hang if the communicator contains a failed process. The collectives will not return an error immediately upon detecting a failure, rather they'll return the error at the end of the function and continue the communication pattern so that other processes waiting to receive messages will not hang. This means that, although the collective should complete at all processes, some processes will receive an error, and some processes may not get a valid result. Since some processes may not receive an error and still receive an invalid result, a separate mechanism is needed to confirm that the collective has completed correctly, such as MPI_Comm_validate of the MPI3 FT proposal.
Modified: mpich2/trunk/src/mpi/coll/allgather.c
--- mpich2/trunk/src/mpi/coll/allgather.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/allgather.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -83,11 +83,12 @@
MPI_Datatype recvtype,
MPID_Comm *comm_ptr )
- int comm_size, rank;
- int mpi_errno = MPI_SUCCESS;
+ int comm_size, rank;
+ int mpi_errno = MPI_SUCCESS;
+ int mpi_errno_ret = MPI_SUCCESS;
MPI_Aint recvtype_extent, tot_bytes;
MPI_Aint recvtype_true_extent, recvbuf_extent, recvtype_true_lb;
- int j, i, pof2, src, rem;
+ int j, i, pof2, src, rem;
void *tmp_buf = NULL;
int curr_cnt, dst, type_size, left, right, jnext;
MPI_Comm comm;
@@ -173,11 +174,13 @@
(comm_size-dst_tree_root)*recvcount,
recvtype, dst,
MPIR_ALLGATHER_TAG, comm, &status);
- if (mpi_errno) {
- MPIU_ERR_POP(mpi_errno);
- MPIR_Get_count_impl(&status, recvtype, &last_recv_cnt);
+ if (mpi_errno) {
+ /* for communication errors, just record the error but continue */
+ MPIU_ERR_SET(mpi_errno, MPI_ERR_OTHER, "**fail");
+ MPIU_ERR_ADD(mpi_errno_ret, mpi_errno);
+ last_recv_cnt = 0;
+ } else
+ MPIR_Get_count_impl(&status, recvtype, &last_recv_cnt);
curr_cnt += last_recv_cnt;
@@ -235,9 +238,11 @@
/* last_recv_cnt was set in the previous
receive. that's the amount of data to be
sent now. */
- if (mpi_errno) {
+ if (mpi_errno) {
/* recv only if this proc. doesn't have data and sender
has data */
@@ -251,10 +256,13 @@
comm, &status);
/* nprocs_completed is also equal to the
no. of processes whose data we don't have */
- if (mpi_errno) {
+ if (mpi_errno) {
+ } else
tmp_mask >>= 1;
@@ -331,11 +339,13 @@
tmp_buf_size - recv_offset,
MPI_BYTE, dst,
- if (mpi_errno) {
- MPIR_Get_count_impl(&status, MPI_BYTE, &last_recv_cnt);
+ if (mpi_errno) {
+ } else
+ MPIR_Get_count_impl(&status, MPI_BYTE, &last_recv_cnt);
@@ -382,8 +392,12 @@
mpi_errno = MPIC_Send(((char *)tmp_buf + offset),
last_recv_cnt, MPI_BYTE,
dst, MPIR_ALLGATHER_TAG,
- comm);
- if (mpi_errno) MPIU_ERR_POP(mpi_errno);
+ comm);
+ if (mpi_errno) {
sent now. */
@@ -398,10 +412,15 @@
MPI_BYTE, dst,
MPIR_ALLGATHER_TAG,
comm, &status);
+ if (mpi_errno) {
+ } else
tmp_mask >>= 1;
@@ -469,10 +488,11 @@
curr_cnt, recvtype,
src, MPIR_ALLGATHER_TAG, comm,
MPI_STATUS_IGNORE);
- if (mpi_errno) {
+ if (mpi_errno) {
curr_cnt *= 2;
pof2 *= 2;
@@ -490,9 +510,11 @@
rem * recvcount, recvtype,
MPI_STATUS_IGNORE);
- if (mpi_errno) {
+ if (mpi_errno) {
/* Rotate blocks in tmp_buf down by (rank) blocks and store
@@ -549,9 +571,11 @@
recvcount, recvtype, left,
MPI_STATUS_IGNORE);
- if (mpi_errno) {
+ if (mpi_errno) {
j = jnext;
jnext = (comm_size + jnext - 1) % comm_size;
@@ -560,8 +584,10 @@
fn_exit:
MPIU_CHKLMEM_FREEALL();
/* check if multiple threads are calling this collective function */
- MPIDU_ERR_CHECK_MULTIPLE_THREADS_EXIT( comm_ptr );
- return (mpi_errno);
+ MPIDU_ERR_CHECK_MULTIPLE_THREADS_EXIT( comm_ptr );
+ if (mpi_errno_ret)
+ mpi_errno = mpi_errno_ret;
+ return mpi_errno;
fn_fail:
goto fn_exit;
@@ -590,6 +616,7 @@
int rank, local_size, remote_size, mpi_errno = MPI_SUCCESS, root;
MPI_Aint true_extent, true_lb = 0, extent, send_extent;
void *tmp_buf=NULL;
MPID_Comm *newcomm_ptr = NULL;
@@ -624,9 +651,11 @@
if (sendcount != 0) {
mpi_errno = MPIR_Gather_impl(sendbuf, sendcount, sendtype, tmp_buf, sendcount,
sendtype, 0, newcomm_ptr);
- if (mpi_errno) {
+ if (mpi_errno) {
/* first broadcast from left to right group, then from right to
@@ -637,9 +666,11 @@
root = (rank == 0) ? MPI_ROOT : MPI_PROC_NULL;
mpi_errno = MPIR_Bcast_inter(tmp_buf, sendcount*local_size,
sendtype, root, comm_ptr);
- if (mpi_errno) {
+ if (mpi_errno) {
/* receive bcast from right */
@@ -647,9 +678,11 @@
root = 0;
mpi_errno = MPIR_Bcast_inter(recvbuf, recvcount*remote_size,
recvtype, root, comm_ptr);
- if (mpi_errno) {
+ if (mpi_errno) {
else {
@@ -658,9 +691,11 @@
root = 0;
- if (mpi_errno) {
+ if (mpi_errno) {
/* bcast to left */
@@ -668,14 +703,18 @@
- if (mpi_errno) {
+ if (mpi_errno) {
- fn_exit:
+ fn_exit:
return mpi_errno;
fn_fail:
Modified: mpich2/trunk/src/mpi/coll/allgatherv.c
--- mpich2/trunk/src/mpi/coll/allgatherv.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/allgatherv.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -79,7 +79,8 @@
MPI_Comm comm;
int comm_size, rank, j, i, left, right;
MPI_Status status;
MPI_Aint recvbuf_extent, recvtype_extent, recvtype_true_extent,
recvtype_true_lb;
@@ -191,11 +192,15 @@
total_count - recv_offset, recvtype, dst,
MPIR_ALLGATHERV_TAG,
comm, &status);
- /* for convenience, recv is posted for a bigger amount
- than will be sent */
+ if (mpi_errno) {
+ } else
+ /* for convenience, recv is posted for a bigger amount
+ than will be sent */
@@ -254,7 +259,11 @@
last_recv_cnt,
recvtype, dst,
MPIR_ALLGATHERV_TAG, comm);
+ if (mpi_errno) {
sent now. */
@@ -273,11 +282,15 @@
total_count - offset, recvtype,
dst, MPIR_ALLGATHERV_TAG,
comm, &status);
- bigger amount than will be sent */
+ if (mpi_errno) {
+ } else
+ bigger amount than will be sent */
tmp_mask >>= 1;
@@ -377,11 +390,15 @@
((char *)tmp_buf + recv_offset),
tmp_buf_size-recv_offset, MPI_BYTE, dst,
MPIR_ALLGATHERV_TAG, comm, &status);
+ if (mpi_errno) {
+ } else
@@ -432,7 +449,11 @@
comm);
+ if (mpi_errno) {
sent now. */
@@ -447,10 +468,15 @@
dst,
comm, &status);
+ if (mpi_errno) {
+ } else
tmp_mask >>= 1;
@@ -523,9 +549,13 @@
((char *)tmp_buf + curr_cnt*recvtype_extent),
total_count - curr_cnt, recvtype,
src, MPIR_ALLGATHERV_TAG, comm, &status);
- MPIR_Get_count_impl(&status, recvtype, &recv_cnt);
+ if (mpi_errno) {
+ recv_cnt = 0;
+ } else
+ MPIR_Get_count_impl(&status, recvtype, &recv_cnt);
curr_cnt += recv_cnt;
pof2 *= 2;
@@ -548,7 +578,11 @@
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
@@ -631,19 +665,31 @@
else if (!sendnow) { /* If there's no data to send, just do a recv call */
mpi_errno = MPIC_Recv(rbuf, recvnow, recvtype, left, MPIR_ALLGATHERV_TAG, comm, &status);
+ if (mpi_errno) {
torecv -= recvnow;
else if (!recvnow) { /* If there's no data to receive, just do a send call */
mpi_errno = MPIC_Send(sbuf, sendnow, recvtype, right, MPIR_ALLGATHERV_TAG, comm);
+ if (mpi_errno) {
tosend -= sendnow;
else { /* There's data to be sent and received */
mpi_errno = MPIC_Sendrecv(sbuf, sendnow, recvtype, right, MPIR_ALLGATHERV_TAG,
comm, &status);
+ if (mpi_errno) {
tosend -= sendnow;
torecv -= recvnow;
@@ -665,6 +711,8 @@
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -696,6 +744,7 @@
and then does an intracommunicator broadcast.
int remote_size, mpi_errno, root, rank;
MPI_Datatype newtype = MPI_DATATYPE_NULL;
@@ -710,13 +759,21 @@
mpi_errno = MPIR_Gatherv_impl(sendbuf, sendcount, sendtype, recvbuf,
recvcounts, displs, recvtype, root,
comm_ptr);
+ if (mpi_errno) {
/* gatherv to right group */
root = 0;
comm_ptr);
+ if (mpi_errno) {
else {
/* gatherv to left group */
@@ -724,13 +781,21 @@
comm_ptr);
+ if (mpi_errno) {
/* gatherv from left group */
comm_ptr);
+ if (mpi_errno) {
/* now do an intracommunicator broadcast within each group. we use
@@ -751,11 +816,17 @@
mpi_errno = MPIR_Bcast_intra(recvbuf, 1, newtype, 0, newcomm_ptr);
+ if (mpi_errno) {
MPIR_Type_free_impl(&newtype);
fn_exit:
return mpi_errno;
fn_fail:
/* --BEGIN ERROR HANDLING-- */
Modified: mpich2/trunk/src/mpi/coll/allreduce.c
--- mpich2/trunk/src/mpi/coll/allreduce.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/allreduce.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -131,7 +131,8 @@
int rc;
#endif
int comm_size, rank, type_size;
int mask, dst, is_commutative, pof2, newrank, rem, newdst, i,
send_idx, recv_idx, last_idx, send_cnt, recv_cnt, *cnts, *disps;
MPI_Aint true_extent, true_lb, extent;
@@ -174,10 +175,18 @@
allreduce is in recvbuf. Pass that as the sendbuf to reduce. */
mpi_errno = MPIR_Reduce_impl(recvbuf, NULL, count, datatype, op, 0, comm_ptr->node_comm);
+ if (mpi_errno) {
} else {
mpi_errno = MPIR_Reduce_impl(sendbuf, recvbuf, count, datatype, op, 0, comm_ptr->node_comm);
+ if (mpi_errno) {
} else {
/* only one process on the node. copy sendbuf to recvbuf */
@@ -190,13 +199,21 @@
/* now do an IN_PLACE allreduce among the local roots of all nodes */
if (comm_ptr->node_roots_comm != NULL) {
mpi_errno = allreduce_intra_or_coll_fn(MPI_IN_PLACE, recvbuf, count, datatype, op, comm_ptr->node_roots_comm);
+ if (mpi_errno) {
/* now broadcast the result among local processes */
if (comm_ptr->node_comm != NULL) {
mpi_errno = MPIR_Bcast_impl(recvbuf, count, datatype, 0, comm_ptr->node_comm);
+ if (mpi_errno) {
goto fn_exit;
@@ -215,17 +232,18 @@
do a reduce to 0 and then broadcast. */
mpi_errno = MPIR_Reduce_impl ( sendbuf, recvbuf, count, datatype,
op, 0, comm_ptr );
- /* FIXME: mpi_errno is error CODE, not necessarily the error
- class MPI_ERR_OP. In MPICH2, we can get the error class
- with
- errorclass = mpi_errno & ERROR_CLASS_MASK;
- if (mpi_errno == MPI_ERR_OP || mpi_errno == MPI_SUCCESS) {
- /* Allow MPI_ERR_OP since we can continue from this error */
- rc = MPIR_Bcast_impl( recvbuf, count, datatype, 0, comm_ptr );
- if (rc) mpi_errno = rc;
+ if (mpi_errno) {
+ mpi_errno = MPIR_Bcast_impl( recvbuf, count, datatype, 0, comm_ptr );
+ if (mpi_errno) {
else
#endif /* MPID_HAS_HETERO */
@@ -299,7 +317,11 @@
mpi_errno = MPIC_Send(recvbuf, count,
datatype, rank+1,
MPIR_ALLREDUCE_TAG, comm);
+ if (mpi_errno) {
/* temporarily set the rank to -1 so that this
process does not pariticipate in recursive
@@ -311,7 +333,11 @@
datatype, rank-1,
MPIR_ALLREDUCE_TAG, comm,
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
/* do the reduction on received data. since the
ordering is right, it doesn't matter whether
@@ -360,7 +386,11 @@
count, datatype, dst,
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
/* tmp_buf contains data received in this step.
recvbuf contains data accumulated so far */
@@ -456,7 +486,11 @@
recv_cnt, datatype, dst,
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
@@ -516,7 +550,11 @@
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
if (newrank > newdst) send_idx = recv_idx;
@@ -538,7 +576,11 @@
datatype, rank+1,
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
if (MPIU_THREADPRIV_FIELD(op_errno))
@@ -550,6 +592,8 @@
return (mpi_errno);
fn_fail:
@@ -580,6 +624,7 @@
broadcasts because it would require allocation of a temporary buffer.
int rank, mpi_errno, root;
rank = comm_ptr->rank;
@@ -591,26 +636,42 @@
mpi_errno = MPIR_Reduce_inter(sendbuf, recvbuf, count, datatype, op,
root, comm_ptr);
+ if (mpi_errno) {
/* reduce to rank 0 of right group */
root = 0;
root, comm_ptr);
+ if (mpi_errno) {
else {
/* reduce to rank 0 of left group */
root = 0;
root, comm_ptr);
+ if (mpi_errno) {
/* reduce from right group to rank 0 */
root, comm_ptr);
+ if (mpi_errno) {
/* Get the local intracommunicator */
@@ -620,9 +681,15 @@
newcomm_ptr = comm_ptr->local_comm;
mpi_errno = MPIR_Bcast_impl(recvbuf, count, datatype, 0, newcomm_ptr);
+ if (mpi_errno) {
fn_exit:
return mpi_errno;
fn_fail:
Modified: mpich2/trunk/src/mpi/coll/alltoall.c
--- mpich2/trunk/src/mpi/coll/alltoall.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/alltoall.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -88,6 +88,7 @@
MPI_Aint sendtype_extent, recvtype_extent;
int mpi_errno=MPI_SUCCESS, src, dst, rank, nbytes;
MPI_Status status;
int sendtype_size, pack_size, block, position, *displs, count;
@@ -138,7 +139,11 @@
j, MPIR_ALLTOALL_TAG,
comm, &status);
+ if (mpi_errno) {
else if (rank == j) {
/* same as above with i/j args reversed */
@@ -147,7 +152,11 @@
i, MPIR_ALLTOALL_TAG,
comm, &status);
+ if (mpi_errno) {
@@ -216,7 +225,11 @@
MPIR_ALLTOALL_TAG, recvbuf, 1, newtype,
src, MPIR_ALLTOALL_TAG, comm,
MPI_STATUS_IGNORE);
- if (mpi_errno) { MPIU_ERR_POP(mpi_errno); }
+ if (mpi_errno) {
@@ -302,11 +315,15 @@
sendbuf_extent*(comm_size-dst_tree_root),
sendtype, dst, MPIR_ALLTOALL_TAG,
comm, &status);
- /* in case of non-power-of-two nodes, less data may be
- received than specified */
- MPIR_Get_count_impl(&status, sendtype, &last_recv_cnt);
+ if (mpi_errno) {
+ } else
+ /* in case of non-power-of-two nodes, less data may be
+ received than specified */
+ MPIR_Get_count_impl(&status, sendtype, &last_recv_cnt);
@@ -351,7 +368,11 @@
last_recv_cnt, sendtype,
comm);
+ if (mpi_errno) {
has data */
@@ -364,8 +385,13 @@
sendtype,
comm, &status);
+ if (mpi_errno) {
+ } else
tmp_mask >>= 1;
@@ -430,7 +456,7 @@
recvcount, recvtype, dst,
&reqarray[i]);
+ if (mpi_errno) MPIU_ERR_POP(mpi_errno);
for ( i=0; i<ss; i++ ) {
@@ -440,7 +466,7 @@
sendcount, sendtype, dst,
&reqarray[i+ss]);
/* ... then wait for them to finish: */
@@ -452,7 +478,11 @@
for (j=0; j<2*ss; j++) {
if (starray[j].MPI_ERROR != MPI_SUCCESS) {
mpi_errno = starray[j].MPI_ERROR;
+ if (mpi_errno) {
@@ -502,7 +532,11 @@
src*recvcount*recvtype_extent),
recvcount, recvtype, src,
MPIR_ALLTOALL_TAG, comm, &status);
+ if (mpi_errno) {
@@ -510,7 +544,9 @@
+ return mpi_errno;
fn_fail:
if (newtype != MPI_DATATYPE_NULL)
@@ -544,7 +580,8 @@
int local_size, remote_size, max_size, i;
MPI_Status status;
int src, dst, rank;
char *sendaddr, *recvaddr;
@@ -590,13 +627,19 @@
MPIR_ALLTOALL_TAG, recvaddr,
+ if (mpi_errno) {
fn_exit:
+ return mpi_errno;
fn_fail:
goto fn_exit;
Modified: mpich2/trunk/src/mpi/coll/alltoallw.c
--- mpich2/trunk/src/mpi/coll/alltoallw.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/alltoallw.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -62,7 +62,8 @@
int comm_size, i, j;
MPI_Status status;
MPI_Status *starray;
MPI_Request *reqarray;
@@ -100,7 +101,11 @@
comm, &status);
+ if (mpi_errno) {
@@ -109,7 +114,11 @@
comm, &status);
+ if (mpi_errno) {
@@ -167,7 +176,11 @@
for (i=0; i<outstanding_requests; i++) {
if (starray[i].MPI_ERROR != MPI_SUCCESS) {
mpi_errno = starray[i].MPI_ERROR;
+ if (mpi_errno) {
@@ -193,7 +206,11 @@
((char *)recvbuf+rdispls[src]),
recvcnts[src], recvtypes[dst], src,
MPIR_ALLTOALLW_TAG, comm, &status);
+ if (mpi_errno) {
#endif
@@ -202,7 +219,9 @@
fn_exit:
+ return mpi_errno;
fn_fail:
goto fn_exit;
@@ -238,6 +257,7 @@
MPI_Status status;
int src, dst, rank, sendcount, recvcount;
@@ -284,13 +304,19 @@
dst, MPIR_ALLTOALLW_TAG, recvaddr,
+ if (mpi_errno) {
fn_exit:
+ return mpi_errno;
fn_fail:
goto fn_exit;
Modified: mpich2/trunk/src/mpi/coll/barrier.c
--- mpich2/trunk/src/mpi/coll/barrier.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/barrier.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -55,6 +55,7 @@
int MPIR_Barrier_intra( MPID_Comm *comm_ptr )
int size, rank, src, dst, mask, mpi_errno=MPI_SUCCESS;
MPI_Comm comm;
/* Only one collective operation per communicator can be active at any
@@ -76,13 +77,18 @@
MPIR_BARRIER_TAG, NULL, 0, MPI_BYTE,
src, MPIR_BARRIER_TAG, comm,
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
mask <<= 1;
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -128,6 +134,7 @@
int MPIR_Barrier_inter( MPID_Comm *comm_ptr )
int rank, mpi_errno = MPI_SUCCESS, root;
int i = 0;
@@ -143,7 +150,11 @@
/* do a barrier on the local intracommunicator */
mpi_errno = MPIR_Barrier_intra(newcomm_ptr);
+ if (mpi_errno) {
/* rank 0 on each group does an intercommunicator broadcast to the
remote group to indicate that all processes in the local group
@@ -156,23 +167,41 @@
/* bcast to right*/
mpi_errno = MPIR_Bcast_inter(&i, 1, MPI_BYTE, root, comm_ptr);
+ if (mpi_errno) {
root = 0;
+ if (mpi_errno) {
else {
/* receive bcast from left */
root = 0;
+ if (mpi_errno) {
/* bcast to left */
+ if (mpi_errno) {
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -217,6 +246,7 @@
int MPIR_Barrier_impl(MPID_Comm *comm_ptr)
if (comm_ptr->coll_fns != NULL && comm_ptr->coll_fns->Barrier != NULL)
@@ -233,13 +263,21 @@
mpi_errno = MPIR_Barrier_or_coll_fn(comm_ptr->node_comm);
+ if (mpi_errno) {
/* do the barrier across roots of all nodes */
mpi_errno = MPIR_Barrier_or_coll_fn(comm_ptr->node_roots_comm);
+ if (mpi_errno) {
/* release the local processes on each node with a 1-byte broadcast
@@ -248,7 +286,11 @@
int i=0;
mpi_errno = MPIR_Bcast_impl(&i, 1, MPI_BYTE, 0, comm_ptr->node_comm);
+ if (mpi_errno) {
else {
@@ -268,6 +310,8 @@
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
Modified: mpich2/trunk/src/mpi/coll/bcast.c
--- mpich2/trunk/src/mpi/coll/bcast.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/bcast.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -58,7 +58,8 @@
int rank, comm_size, src, dst;
int relative_rank, mask;
int nbytes=0;
int type_size, is_contig, is_homogeneous;
int position;
@@ -154,7 +155,11 @@
else
mpi_errno = MPIC_Recv(buffer,count,datatype,src,
MPIR_BCAST_TAG,comm,MPI_STATUS_IGNORE);
+ if (mpi_errno) {
break;
mask <<= 1;
@@ -184,7 +189,11 @@
else
mpi_errno = MPIC_Send(buffer,count,datatype,dst,
MPIR_BCAST_TAG,comm);
+ if (mpi_errno) {
mask >>= 1;
@@ -203,6 +212,8 @@
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -236,7 +247,8 @@
MPI_Status status;
int scatter_size, curr_size, recv_size = 0, send_size;
MPI_Comm comm;
@@ -283,10 +295,14 @@
relative_rank*scatter_size),
recv_size, MPI_BYTE, src,
MPIR_BCAST_TAG, comm, &status);
- /* query actual size of data received */
- MPIR_Get_count_impl(&status, MPI_BYTE, &curr_size);
+ if (mpi_errno) {
+ curr_size = 0;
+ } else
+ /* query actual size of data received */
+ MPIR_Get_count_impl(&status, MPI_BYTE, &curr_size);
break;
@@ -314,7 +330,11 @@
scatter_size*(relative_rank+mask)),
send_size, MPI_BYTE, dst,
MPIR_BCAST_TAG, comm);
+ if (mpi_errno) {
curr_size -= send_size;
@@ -323,6 +343,8 @@
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -363,6 +385,7 @@
int rank, comm_size, dst;
int scatter_size, nbytes=0, curr_size, recv_size = 0;
int type_size, j, k, i, tmp_mask, is_contig, is_homogeneous;
int relative_dst, dst_tree_root, my_tree_root, send_offset;
@@ -436,7 +459,11 @@
mpi_errno = scatter_for_bcast(buffer, count, datatype, root, comm_ptr,
nbytes, tmp_buf, is_contig, is_homogeneous);
+ if (mpi_errno) {
/* medium size allgather and pof2 comm_size. use recurive doubling. */
@@ -470,9 +497,13 @@
(nbytes-recv_offset < 0 ? 0 : nbytes-recv_offset),
MPI_BYTE, dst, MPIR_BCAST_TAG, comm, &status);
- MPIR_Get_count_impl(&status, MPI_BYTE, &recv_size);
+ if (mpi_errno) {
+ recv_size = 0;
+ } else
+ MPIR_Get_count_impl(&status, MPI_BYTE, &recv_size);
curr_size += recv_size;
@@ -540,7 +571,11 @@
/* recv_size was set in the previous
sent now. */
+ if (mpi_errno) {
has data */
@@ -556,9 +591,13 @@
comm, &status);
/* nprocs_completed is also equal to the no. of processes
+ if (mpi_errno) {
+ recv_size = 0;
+ } else
/* printf("Rank %d, recv from %d, offset %d, size %d\n", rank, dst, offset, recv_size);
fflush(stdout);*/
@@ -586,6 +625,8 @@
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -621,6 +662,7 @@
int rank, comm_size;
int relative_rank;
int scatter_size, nbytes;
int type_size, j, i, is_contig, is_homogeneous;
int position;
@@ -690,7 +732,11 @@
+ if (mpi_errno) {
/* long-message allgather or medium-size but non-power-of-two. use ring algorithm. */
@@ -727,7 +773,11 @@
recvcnts[(jnext-root+comm_size)%comm_size],
MPI_BYTE, left,
MPIR_BCAST_TAG, comm, MPI_STATUS_IGNORE);
+ if (mpi_errno) {
j = jnext;
@@ -746,6 +796,8 @@
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -769,7 +821,11 @@
mpi_errno_ = bcast_fn_(buffer_, count_, datatype_, root_, comm_ptr_); \
- if (mpi_errno_) MPIU_ERR_POP(mpi_errno_); \
+ if (mpi_errno) { \
+ /* for communication errors, just record the error but continue */ \
+ MPIU_ERR_SET(mpi_errno, MPI_ERR_OTHER, "**fail"); \
+ MPIU_ERR_ADD(mpi_errno_ret, mpi_errno); \
} while (0)
/* FIXME This function uses some heuristsics based off of some testing on a
@@ -786,6 +842,7 @@
int type_size, is_homogeneous;
int nbytes=0;
@@ -828,7 +885,11 @@
mpi_errno = MPIC_Recv(buffer,count,datatype,MPIU_Get_intranode_rank(comm_ptr, root),
MPIR_BCAST_TAG,comm_ptr->node_comm->handle,MPI_STATUS_IGNORE);
+ if (mpi_errno) {
/* perform the internode broadcast */
@@ -905,11 +966,17 @@
algorithm that (at least approximately) minimized internode
communication. */
mpi_errno = MPIR_Bcast_scatter_ring_allgather(buffer, count, datatype, root, comm_ptr);
+ if (mpi_errno) {
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -971,6 +1038,7 @@
int comm_size;
int nbytes=0;
@@ -987,7 +1055,11 @@
#if defined(USE_SMP_COLLECTIVES)
if (MPIR_Comm_is_node_aware(comm_ptr)) {
mpi_errno = MPIR_SMP_Bcast(buffer, count, datatype, root, comm_ptr);
+ if (mpi_errno) {
goto fn_exit;
#endif
@@ -1018,14 +1090,22 @@
if ((nbytes < MPIR_PARAM_BCAST_SHORT_MSG_SIZE) || (comm_size < MPIR_PARAM_BCAST_MIN_PROCS))
mpi_errno = MPIR_Bcast_binomial(buffer, count, datatype, root, comm_ptr);
+ if (mpi_errno) {
else /* (nbytes >= MPIR_PARAM_BCAST_SHORT_MSG_SIZE) && (comm_size >= MPIR_PARAM_BCAST_MIN_PROCS) */
if ((nbytes < MPIR_PARAM_BCAST_LONG_MSG_SIZE) && (MPIU_is_pof2(comm_size, NULL)))
mpi_errno = MPIR_Bcast_scatter_doubling_allgather(buffer, count, datatype, root, comm_ptr);
+ if (mpi_errno) {
else /* (nbytes >= MPIR_PARAM_BCAST_LONG_MSG_SIZE) || !(comm_size_is_pof2) */
@@ -1033,7 +1113,11 @@
topologically aware communicator. Doing inter/intra-node
communication phases breaks the pipelining of the algorithm. */
+ if (mpi_errno) {
@@ -1043,6 +1127,8 @@
MPID_MPI_FUNC_EXIT(MPID_STATE_MPIR_BCAST);
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -1067,6 +1153,7 @@
int rank, mpi_errno;
MPI_Status status;
MPI_Comm comm;
@@ -1087,7 +1174,11 @@
MPIDU_ERR_CHECK_MULTIPLE_THREADS_ENTER( comm_ptr );
mpi_errno = MPIC_Send(buffer, count, datatype, 0,
+ if (mpi_errno) {
else
@@ -1100,7 +1191,11 @@
mpi_errno = MPIC_Recv(buffer, count, datatype, root,
+ if (mpi_errno) {
@@ -1112,11 +1207,17 @@
/* now do the usual broadcast on this intracommunicator
with rank 0 as root. */
mpi_errno = MPIR_Bcast_intra(buffer, count, datatype, 0, newcomm_ptr);
+ if (mpi_errno) {
fn_fail:
MPID_MPI_FUNC_EXIT(MPID_STATE_MPIR_BCAST_INTER);
return mpi_errno;
Modified: mpich2/trunk/src/mpi/coll/exscan.c
--- mpich2/trunk/src/mpi/coll/exscan.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/exscan.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -106,7 +106,8 @@
MPI_Status status;
int mask, dst, is_commutative, flag;
void *partial_scan, *tmp_buf;
@@ -187,7 +188,11 @@
MPIR_EXSCAN_TAG, comm,
&status);
+ if (mpi_errno) {
if (rank > dst) {
call_uop(tmp_buf, partial_scan, count, datatype);
@@ -237,7 +242,9 @@
fn_exit:
+ return mpi_errno;
fn_fail:
goto fn_exit;
Modified: mpich2/trunk/src/mpi/coll/gather.c
--- mpich2/trunk/src/mpi/coll/gather.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/gather.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -61,7 +61,8 @@
int curr_cnt=0, relative_rank, nbytes, is_homogeneous;
int mask, sendtype_size, recvtype_size, src, dst, relative_src;
int recvblks;
@@ -194,7 +195,11 @@
recvblks * recvcnt, recvtype, src,
MPIR_GATHER_TAG, comm,
&status);
+ if (mpi_errno) {
else if (nbytes < MPIR_PARAM_GATHER_VSMALL_MSG_SIZE) {
mpi_errno = MPIC_Recv(tmp_buf, recvblks * nbytes, MPI_BYTE,
@@ -218,8 +223,9 @@
mpi_errno = MPIC_Recv(recvbuf, 1, tmp_type, src,
MPIR_GATHER_TAG, comm, &status);
if (mpi_errno) {
- MPIR_Type_free_impl(&tmp_type);
@@ -243,7 +249,11 @@
recvblks * nbytes, MPI_BYTE, src,
&status);
+ if (mpi_errno) {
curr_cnt += (recvblks * nbytes);
@@ -258,12 +268,20 @@
/* leaf nodes send directly from sendbuf */
mpi_errno = MPIC_Send(sendbuf, sendcnt, sendtype, dst,
MPIR_GATHER_TAG, comm);
+ if (mpi_errno) {
mpi_errno = MPIC_Send(tmp_buf, curr_cnt, MPI_BYTE, dst,
+ if (mpi_errno) {
else {
blocks[0] = sendcnt;
@@ -282,8 +300,9 @@
mpi_errno = MPIC_Send(MPI_BOTTOM, 1, tmp_type, dst,
if (mpi_errno) {
@@ -352,10 +371,15 @@
tmp_buf_size-curr_cnt, MPI_BYTE, src,
&status);
- /* the recv size is larger than what may be sent in
- some cases. query amount of data actually received */
+ if (mpi_errno) {
+ recv_size = 0;
+ } else
+ /* the recv size is larger than what may be sent in
+ some cases. query amount of data actually received */
curr_cnt += recv_size;
@@ -365,7 +389,11 @@
dst = (dst + root) % comm_size;
+ if (mpi_errno) {
break;
mask <<= 1;
@@ -404,6 +432,8 @@
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -438,6 +468,7 @@
int rank, local_size, remote_size, mpi_errno=MPI_SUCCESS;
int i, nbytes, sendtype_size, recvtype_size;
MPI_Status status;
MPI_Aint extent, true_extent, true_lb = 0;
@@ -478,8 +509,11 @@
mpi_errno = MPIC_Recv(recvbuf, recvcnt*remote_size,
recvtype, 0, MPIR_GATHER_TAG, comm,
&status);
+ if (mpi_errno) {
else
@@ -513,14 +547,22 @@
mpi_errno = MPIR_Gather_impl(sendbuf, sendcnt, sendtype,
tmp_buf, sendcnt, sendtype, 0,
newcomm_ptr);
+ if (mpi_errno) {
if (rank == 0)
mpi_errno = MPIC_Send(tmp_buf, sendcnt*local_size,
sendtype, root,
+ if (mpi_errno) {
@@ -538,20 +580,30 @@
mpi_errno = MPIC_Recv(((char *)recvbuf+recvcnt*i*extent),
recvcnt, recvtype, i,
+ if (mpi_errno) {
else
mpi_errno = MPIC_Send(sendbuf,sendcnt,sendtype,root,
MPIR_GATHER_TAG,comm);
+ if (mpi_errno) {
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
Modified: mpich2/trunk/src/mpi/coll/gatherv.c
--- mpich2/trunk/src/mpi/coll/gatherv.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/gatherv.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -61,6 +61,7 @@
MPI_Comm comm;
MPI_Aint extent;
int i, reqs;
@@ -120,7 +121,11 @@
for (i = 0; i < reqs; i++) {
+ if (mpi_errno) {
@@ -143,12 +148,20 @@
if (comm_size >= min_procs) {
mpi_errno = MPIC_Ssend(sendbuf, sendcnt, sendtype, root,
MPIR_GATHERV_TAG, comm);
+ if (mpi_errno) {
else {
mpi_errno = MPIC_Send(sendbuf, sendcnt, sendtype, root,
+ if (mpi_errno) {
@@ -158,6 +171,8 @@
return mpi_errno;
fn_fail:
goto fn_exit;
Modified: mpich2/trunk/src/mpi/coll/red_scat.c
--- mpich2/trunk/src/mpi/coll/red_scat.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/red_scat.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -83,6 +83,7 @@
int comm_size = comm_ptr->local_size;
int rank = comm_ptr->rank;
int pof2;
@@ -191,7 +192,11 @@
incoming_data + recv_offset*true_extent,
size, datatype, peer, MPIR_REDUCE_SCATTER_TAG,
+ if (mpi_errno) {
/* always perform the reduction at recv_offset, the data at send_offset
is now our peer's responsibility */
if (rank > peer) {
@@ -222,6 +227,8 @@
recvbuf, size, datatype);
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -292,7 +299,8 @@
MPI_Aint extent, true_extent, true_lb;
int *disps;
void *tmp_recvbuf, *tmp_results;
int type_size, dis[2], blklens[2], total_count, nbytes, src, dst;
int mask, dst_tree_root, my_tree_root, j, k;
int *newcnts, *newdisps, rem, newdst, send_idx, recv_idx,
@@ -408,7 +416,11 @@
mpi_errno = MPIC_Send(tmp_results, total_count,
datatype, rank+1,
MPIR_REDUCE_SCATTER_TAG, comm);
+ if (mpi_errno) {
@@ -420,7 +432,11 @@
datatype, rank-1,
MPIR_REDUCE_SCATTER_TAG, comm,
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
@@ -519,7 +535,11 @@
dst, MPIR_REDUCE_SCATTER_TAG,
comm);
+ if (mpi_errno) {
/* tmp_recvbuf contains data received in this step.
tmp_results contains data accumulated so far */
@@ -567,7 +587,11 @@
disps[rank-1]*extent, recvcnts[rank-1],
datatype, rank-1,
+ if (mpi_errno) {
else { /* even */
@@ -576,7 +600,11 @@
datatype, rank+1,
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
@@ -621,7 +649,11 @@
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
if (is_commutative || (src < rank)) {
if (sendbuf != MPI_IN_PLACE) {
@@ -818,7 +850,11 @@
MPI_STATUS_IGNORE);
received = 1;
+ if (mpi_errno) {
/* if some processes in this process's subtree in this step
@@ -871,7 +907,11 @@
received = 1;
+ if (mpi_errno) {
tmp_mask >>= 1;
k--;
@@ -959,7 +999,9 @@
mpi_errno = MPIU_THREADPRIV_FIELD(op_errno);
+ return mpi_errno;
fn_fail:
goto fn_exit;
@@ -986,6 +1028,7 @@
int rank, mpi_errno, root, local_size, total_count, i;
MPI_Aint true_extent, true_lb = 0, extent;
void *tmp_buf=NULL;
int *disps=NULL;
@@ -1026,26 +1069,42 @@
mpi_errno = MPIR_Reduce_inter(sendbuf, tmp_buf, total_count, datatype, op,
root, comm_ptr);
+ if (mpi_errno) {
root = 0;
root, comm_ptr);
+ if (mpi_errno) {
else {
root = 0;
root, comm_ptr);
+ if (mpi_errno) {
root, comm_ptr);
+ if (mpi_errno) {
@@ -1058,10 +1117,16 @@
mpi_errno = MPIR_Scatterv(tmp_buf, recvcnts, disps, datatype, recvbuf,
recvcnts[rank], datatype, 0, newcomm_ptr);
+ if (mpi_errno) {
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -1073,7 +1138,7 @@
implementations of reduce_scatter. In all other cases
MPIR_Reduce_Scatter_impl should be used. */
#undef FUNCNAME
-#define FUNCNAME MPIR_Reduce_scatter_impl
+#define FUNCNAME MPIR_Reduce_scatter
#undef FCNAME
#define FCNAME MPIU_QUOTE(FUNCNAME)
int MPIR_Reduce_scatter(void *sendbuf, void *recvbuf, int *recvcnts,
Modified: mpich2/trunk/src/mpi/coll/red_scat_block.c
--- mpich2/trunk/src/mpi/coll/red_scat_block.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/red_scat_block.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -89,6 +89,7 @@
int pof2;
@@ -193,7 +194,11 @@
size, datatype, peer, MPIR_REDUCE_SCATTER_BLOCK_TAG,
+ if (mpi_errno) {
if (rank > peer) {
@@ -226,6 +231,8 @@
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -296,7 +303,8 @@
int *disps;
@@ -411,7 +419,11 @@
datatype, rank+1,
MPIR_REDUCE_SCATTER_BLOCK_TAG, comm);
+ if (mpi_errno) {
@@ -423,7 +435,11 @@
datatype, rank-1,
MPIR_REDUCE_SCATTER_BLOCK_TAG, comm,
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
@@ -522,7 +538,11 @@
dst, MPIR_REDUCE_SCATTER_BLOCK_TAG,
comm);
+ if (mpi_errno) {
@@ -573,7 +593,11 @@
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
@@ -616,7 +640,11 @@
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
@@ -803,7 +831,11 @@
MPI_STATUS_IGNORE);
received = 1;
+ if (mpi_errno) {
@@ -845,7 +877,11 @@
mpi_errno = MPIC_Send(tmp_recvbuf, 1, recvtype,
comm);
+ if (mpi_errno) {
has data */
@@ -856,7 +892,11 @@
received = 1;
+ if (mpi_errno) {
tmp_mask >>= 1;
k--;
@@ -944,7 +984,9 @@
+ return mpi_errno;
fn_fail:
goto fn_exit;
@@ -971,6 +1013,7 @@
int rank, mpi_errno, root, local_size, total_count;
void *tmp_buf=NULL;
@@ -1001,26 +1044,42 @@
root, comm_ptr);
+ if (mpi_errno) {
root = 0;
root, comm_ptr);
+ if (mpi_errno) {
else {
root = 0;
root, comm_ptr);
+ if (mpi_errno) {
root, comm_ptr);
+ if (mpi_errno) {
@@ -1031,10 +1090,16 @@
mpi_errno = MPIR_Scatter_impl(tmp_buf, recvcount, datatype, recvbuf,
recvcount, datatype, 0, newcomm_ptr);
+ if (mpi_errno) {
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
Modified: mpich2/trunk/src/mpi/coll/reduce.c
--- mpich2/trunk/src/mpi/coll/reduce.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/reduce.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -41,6 +41,7 @@
MPI_Status status;
int comm_size, rank, is_commutative, type_size;
int mask, relrank, source, lroot;
@@ -168,7 +169,11 @@
source = (source + lroot) % comm_size;
mpi_errno = MPIC_Recv (tmp_buf, count, datatype, source,
MPIR_REDUCE_TAG, comm, &status);
+ if (mpi_errno) {
/* The sender is above us, so the received buffer must be
the second argument (in the noncommutative case). */
@@ -203,7 +208,11 @@
source = ((relrank & (~ mask)) + lroot) % comm_size;
mpi_errno = MPIC_Send( recvbuf, count, datatype,
source, MPIR_REDUCE_TAG, comm );
+ if (mpi_errno) {
break;
mask <<= 1;
@@ -221,7 +230,11 @@
mpi_errno = MPIC_Recv ( recvbuf, count, datatype, 0,
+ if (mpi_errno) {
/* FIXME does this need to be checked after each uop invocation for
@@ -235,6 +248,8 @@
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -281,6 +296,7 @@
int comm_size, rank, is_commutative, type_size, pof2, rem, newrank;
int mask, *cnts, *disps, i, j, send_idx=0;
int recv_idx, last_idx=0, newdst;
@@ -389,7 +405,11 @@
datatype, rank-1,
MPIR_REDUCE_TAG, comm);
+ if (mpi_errno) {
@@ -401,7 +421,11 @@
datatype, rank+1,
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
/* do the reduction on received data. */
/* This algorithm is used only for predefined ops
@@ -480,7 +504,11 @@
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
@@ -534,7 +562,11 @@
mpi_errno = MPIC_Recv(recvbuf, cnts[0], datatype,
0, MPIR_REDUCE_TAG, comm,
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
newrank = 0;
send_idx = 0;
last_idx = 2;
@@ -542,7 +574,11 @@
else if (newrank == 0) { /* send */
mpi_errno = MPIC_Send(recvbuf, cnts[0], datatype,
root, MPIR_REDUCE_TAG, comm);
+ if (mpi_errno) {
newrank = -1;
newroot = 0;
@@ -611,7 +647,11 @@
send_cnt, datatype,
dst, MPIR_REDUCE_TAG,
comm);
+ if (mpi_errno) {
break;
else {
@@ -623,7 +663,11 @@
MPI_STATUS_IGNORE);
+ if (mpi_errno) {
@@ -644,6 +688,8 @@
fn_exit:
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -720,6 +766,7 @@
int comm_size, is_commutative, type_size, pof2;
MPID_Op *op_ptr;
@@ -762,7 +809,11 @@
MPIU_Get_intranode_rank(comm_ptr, root) == -1) {
mpi_errno = MPIR_Reduce_impl(sendbuf, tmp_buf, count, datatype,
- if (mpi_errno) goto fn_fail;
+ if (mpi_errno) {
/* do the internode reduce to the root's node */
@@ -774,7 +825,11 @@
mpi_errno = MPIR_Reduce_impl(buf, NULL, count, datatype,
op, MPIU_Get_internode_rank(comm_ptr, root),
+ if (mpi_errno) {
else { /* I am on root's node. I have not participated in the earlier reduce. */
if (comm_ptr->rank != root) {
@@ -784,7 +839,11 @@
+ if (mpi_errno) {
/* point sendbuf at tmp_buf to make final intranode reduce easy */
sendbuf = tmp_buf;
@@ -795,7 +854,11 @@
+ if (mpi_errno) {
/* set sendbuf to MPI_IN_PLACE to make final intranode reduce easy. */
sendbuf = MPI_IN_PLACE;
@@ -810,7 +873,11 @@
op, MPIU_Get_intranode_rank(comm_ptr, root),
+ if (mpi_errno) {
goto fn_exit;
@@ -842,12 +909,20 @@
(HANDLE_GET_KIND(op) == HANDLE_KIND_BUILTIN) && (count >= pof2)) {
/* do a reduce-scatter followed by gather to root. */
mpi_errno = MPIR_Reduce_redscat_gather(sendbuf, recvbuf, count, datatype, op, root, comm_ptr);
+ if (mpi_errno) {
else {
/* use a binomial tree algorithm */
mpi_errno = MPIR_Reduce_binomial(sendbuf, recvbuf, count, datatype, op, root, comm_ptr);
+ if (mpi_errno) {
@@ -857,6 +932,8 @@
#endif
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -886,6 +963,7 @@
MPI_Status status;
void *tmp_buf=NULL;
@@ -906,7 +984,11 @@
/* root receives data from rank 0 on remote group */
mpi_errno = MPIC_Recv(recvbuf, count, datatype, 0,
+ if (mpi_errno) {
else {
/* remote group. Rank 0 allocates temporary buffer, does
@@ -939,19 +1021,29 @@
/* now do a local reduce on this intracommunicator */
mpi_errno = MPIR_Reduce_intra(sendbuf, tmp_buf, count, datatype,
op, 0, newcomm_ptr);
+ if (mpi_errno) {
if (rank == 0)
mpi_errno = MPIC_Send(tmp_buf, count, datatype, root,
+ if (mpi_errno) {
fn_exit:
return mpi_errno;
fn_fail:
Modified: mpich2/trunk/src/mpi/coll/scan.c
--- mpich2/trunk/src/mpi/coll/scan.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/scan.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -75,7 +75,8 @@
MPI_Status status;
int mask, dst, is_commutative;
@@ -171,7 +172,11 @@
MPIR_SCAN_TAG, comm,
&status);
+ if (mpi_errno) {
if (rank > dst) {
#ifdef HAVE_CXX_BINDING
@@ -228,7 +233,9 @@
+ return mpi_errno;
fn_fail:
goto fn_exit;
@@ -252,6 +259,7 @@
MPIU_CHKLMEM_DECL(3);
MPIU_THREADPRIV_DECL;
@@ -303,7 +311,11 @@
mpi_errno = MPIR_Scan_impl(sendbuf, recvbuf, count, datatype,
op, comm_ptr->node_comm);
+ if (mpi_errno) {
else if (sendbuf != MPI_IN_PLACE)
@@ -321,7 +333,11 @@
mpi_errno = MPIC_Recv(localfulldata, count, datatype,
comm_ptr->node_comm->local_size - 1, MPIR_SCAN_TAG,
comm_ptr->node_comm->handle, &status);
+ if (mpi_errno) {
else if (comm_ptr->node_roots_comm == NULL &&
comm_ptr->node_comm != NULL &&
@@ -329,7 +345,11 @@
mpi_errno = MPIC_Send(recvbuf, count, datatype,
0, MPIR_SCAN_TAG, comm_ptr->node_comm->handle);
+ if (mpi_errno) {
else if (comm_ptr->node_roots_comm != NULL)
@@ -344,7 +364,11 @@
mpi_errno = MPIR_Scan_impl(localfulldata, prefulldata, count, datatype,
+ if (mpi_errno) {
if (MPIU_Get_internode_rank(comm_ptr, rank) !=
comm_ptr->node_roots_comm->local_size-1)
@@ -352,7 +376,11 @@
mpi_errno = MPIC_Send(prefulldata, count, datatype,
MPIU_Get_internode_rank(comm_ptr, rank) + 1,
MPIR_SCAN_TAG, comm_ptr->node_roots_comm->handle);
- if(mpi_errno) MPIU_ERR_POP(mpi_errno);
+ if (mpi_errno) {
if (MPIU_Get_internode_rank(comm_ptr, rank) != 0)
@@ -361,7 +389,11 @@
MPIR_SCAN_TAG, comm_ptr->node_roots_comm->handle,
&status);
noneed = 0;
+ if (mpi_errno) {
@@ -373,7 +405,11 @@
mpi_errno = MPIR_Bcast_impl(&noneed, 1, MPI_INT, 0, comm_ptr->node_comm);
+ if (mpi_errno) {
if (noneed == 0) {
@@ -382,7 +418,11 @@
#endif
mpi_errno = MPIR_Bcast_impl(tempbuf, count, datatype, 0, comm_ptr->node_comm);
+ if (mpi_errno) {
/* do reduce on tempbuf and recvbuf, finish scan. */
@@ -420,6 +460,8 @@
fn_exit:
return mpi_errno;
fn_fail:
Modified: mpich2/trunk/src/mpi/coll/scatter.c
--- mpich2/trunk/src/mpi/coll/scatter.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/scatter.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -68,6 +68,7 @@
int tmp_buf_size = 0;
void *tmp_buf=NULL;
MPI_Comm comm;
MPIU_CHKLMEM_DECL(4);
@@ -171,16 +172,24 @@
mpi_errno = MPIC_Recv(recvbuf, recvcnt, recvtype,
src, MPIR_SCATTER_TAG, comm,
&status);
+ if (mpi_errno) {
else {
mpi_errno = MPIC_Recv(tmp_buf, tmp_buf_size, MPI_BYTE, src,
MPIR_SCATTER_TAG, comm, &status);
- MPIR_Get_count_impl(&status, MPI_BYTE, &curr_cnt);
+ if (mpi_errno) {
+ curr_cnt = 0;
+ } else
+ MPIR_Get_count_impl(&status, MPI_BYTE, &curr_cnt);
break;
@@ -218,7 +227,11 @@
MPI_BYTE, dst,
MPIR_SCATTER_TAG, comm);
+ if (mpi_errno) {
curr_cnt -= send_subtree_cnt;
mask >>= 1;
@@ -319,10 +332,15 @@
+ if (mpi_errno) {
+ curr_cnt = 0;
+ } else
break;
mask <<= 1;
@@ -344,7 +362,11 @@
mpi_errno = MPIC_Send (((char *)tmp_buf + nbytes*mask),
send_subtree_cnt, MPI_BYTE, dst,
+ if (mpi_errno) {
mask >>= 1;
@@ -364,6 +386,8 @@
return mpi_errno;
fn_fail:
goto fn_exit;
@@ -396,6 +420,7 @@
MPI_Status status;
@@ -429,7 +454,11 @@
/* root sends all data to rank 0 on remote group and returns */
mpi_errno = MPIC_Send(sendbuf, sendcnt*remote_size,
sendtype, 0, MPIR_SCATTER_TAG, comm);
+ if (mpi_errno) {
goto fn_exit;
else {
@@ -454,7 +483,11 @@
mpi_errno = MPIC_Recv(tmp_buf, recvcnt*local_size,
recvtype, root,
+ if (mpi_errno) {
@@ -467,7 +500,11 @@
mpi_errno = MPIR_Scatter_impl(tmp_buf, recvcnt, recvtype,
recvbuf, recvcnt, recvtype, 0,
newcomm_ptr);
+ if (mpi_errno) {
else {
@@ -478,13 +515,21 @@
mpi_errno = MPIC_Send(((char *)sendbuf+sendcnt*i*extent),
sendcnt, sendtype, i,
+ if (mpi_errno) {
else {
mpi_errno = MPIC_Recv(recvbuf,recvcnt,recvtype,root,
MPIR_SCATTER_TAG,comm,&status);
+ if (mpi_errno) {
@@ -492,6 +537,8 @@
return mpi_errno;
fn_fail:
goto fn_exit;
Modified: mpich2/trunk/src/mpi/coll/scatterv.c
--- mpich2/trunk/src/mpi/coll/scatterv.c 2011-01-13 19:28:01 UTC (rev 7719)
+++ mpich2/trunk/src/mpi/coll/scatterv.c 2011-01-13 19:38:44 UTC (rev 7720)
@@ -60,6 +60,7 @@
int rank, comm_size, mpi_errno = MPI_SUCCESS;
MPI_Comm comm;
MPI_Aint extent;
int i, reqs;
+ if (mpi_errno) {
@@ -131,7 +136,11 @@
if (recvcnt) {
MPIR_SCATTERV_TAG,comm,MPI_STATUS_IGNORE);
+ if (mpi_errno) {
@@ -140,6 +149,8 @@
return mpi_errno;
fn_fail:
goto fn_exit;
More information about the mpich2-commits
