[mpich2-commits] r7710 - in mpich2/trunk/src/pm/hydra: pm/pmiserv tools/bootstrap/src ui/utils
balaji at mcs.anl.gov balaji at mcs.anl.gov
Thu Jan 13 05:09:56 CST 2011
Author: balaji
Date: 2011-01-13 05:09:56 -0600 (Thu, 13 Jan 2011)
New Revision: 7710
Modified:
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_cb.c
   mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_launch.c
   mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
Log:
White space cleanup.
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c	2011-01-13 11:09:42 UTC (rev 7709)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c	2011-01-13 11:09:56 UTC (rev 7710)
@@ -676,8 +676,7 @@
                                          &HYD_pmcd_pmip.downstream.in,
                                          &HYD_pmcd_pmip.downstream.out[process_id],
                                          &HYD_pmcd_pmip.downstream.err[process_id],
-                                         &HYD_pmcd_pmip.downstream.pid[process_id],
-                                         cpuset);
+                                         &HYD_pmcd_pmip.downstream.pid[process_id], cpuset);
             HYDU_ERR_POP(status, "create process returned error\n");
             HYDU_free_strlist(client_args);
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_cb.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_cb.c	2011-01-13 11:09:42 UTC (rev 7709)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_cb.c	2011-01-13 11:09:56 UTC (rev 7710)
@@ -144,12 +144,13 @@
         hdr.cmd = STDIN;
     else {
-        status = HYDU_sock_read(fd, &hdr, sizeof(hdr), &count, &closed, HYDU_SOCK_COMM_MSGWAIT);
+        status =
+            HYDU_sock_read(fd, &hdr, sizeof(hdr), &count, &closed, HYDU_SOCK_COMM_MSGWAIT);
         HYDU_ERR_POP(status, "unable to read command from proxy\n");
         HYDU_ASSERT(!closed, status);
-    if (hdr.cmd == PID_LIST) {      /* Got PIDs */
+    if (hdr.cmd == PID_LIST) {  /* Got PIDs */
         HYDU_MALLOC(proxy->pid, int *, proxy->proxy_process_count * sizeof(int), status);
         status = HYDU_sock_read(fd, (void *) proxy->pid,
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_launch.c
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_launch.c	2011-01-13 11:09:42 UTC (rev 7709)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_launch.c	2011-01-13 11:09:56 UTC (rev 7710)
@@ -7,8 +7,8 @@
 #include "hydra.h"
 #include "bsci.h"
-HYD_status HYDT_bsci_launch_procs(const char *base_path, char **args, struct HYD_node *node_list,
-                                  int *control_fd)
+HYD_status HYDT_bsci_launch_procs(const char *base_path, char **args,
+                                  struct HYD_node *node_list, int *control_fd)
     HYD_status status = HYD_SUCCESS;
Modified: mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
--- mpich2/trunk/src/pm/hydra/ui/utils/uiu.c	2011-01-13 11:09:42 UTC (rev 7709)
+++ mpich2/trunk/src/pm/hydra/ui/utils/uiu.c	2011-01-13 11:09:56 UTC (rev 7710)
@@ -171,11 +171,12 @@
     return;
-static HYD_status resolve_pattern_string(const char *pattern, char **str, int pgid, int proxy_id, int rank)
+static HYD_status resolve_pattern_string(const char *pattern, char **str, int pgid,
+                                         int proxy_id, int rank)
     int i, pos, tpos;
-    char *tmp[HYD_NUM_TMP_STRINGS] = {NULL};
+    char *tmp[HYD_NUM_TMP_STRINGS] = { NULL };
     struct HYD_pg *pg;
     struct HYD_proxy *proxy;
@@ -192,11 +193,11 @@
         HYDU_ASSERT(tpos < HYD_TMP_STRLEN, status);
         if (pattern[pos] != '%') {
             tmp[i][tpos++] = pattern[pos++];
-            if (pattern[pos-1] == '\0')
+            if (pattern[pos - 1] == '\0')
                 break;
         else {
-            ++pos; /* consume '%' */
+            ++pos;      /* consume '%' */
             if (pattern[pos] == '%') {
@@ -211,35 +212,37 @@
             tmp[i][0] = '\0';
             switch (pattern[pos]) {
-                case 'r':
-                    MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", rank);
-                    break;
-                case 'g':
-                    MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", pgid);
-                    break;
-                case 'p':
-                    MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", proxy_id);
-                    break;
-                case 'h':
-                    for (pg = &HYD_server_info.pg_list; pg; pg = pg->next)
-                        if (pg->pgid == pgid)
-                            break;
-                    HYDU_ASSERT(pg, status);
+            case 'r':
+                MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", rank);
+                break;
+            case 'g':
+                MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", pgid);
+                break;
+            case 'p':
+                MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%d", proxy_id);
+                break;
+            case 'h':
+                for (pg = &HYD_server_info.pg_list; pg; pg = pg->next)
+                    if (pg->pgid == pgid)
+                        break;
+                HYDU_ASSERT(pg, status);
-                    for (proxy = pg->proxy_list; proxy; proxy = proxy->next)
-                        if (proxy->proxy_id == proxy_id)
-                            break;
-                    HYDU_ASSERT(proxy, status);
-                    MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%s", proxy->node.hostname);
-                    break;
-                case '\0':
-                    HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "dangling '%%' at end of pattern\n");
-                default:
-                    HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "unrecognized pattern specifier ('%c')\n", pattern[pos]);
-                    break;
+                for (proxy = pg->proxy_list; proxy; proxy = proxy->next)
+                    if (proxy->proxy_id == proxy_id)
+                        break;
+                HYDU_ASSERT(proxy, status);
+                MPL_snprintf(tmp[i], HYD_TMP_STRLEN, "%s", proxy->node.hostname);
+                break;
+            case '\0':
+                HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR,
+                                    "dangling '%%' at end of pattern\n");
+            default:
+                                    "unrecognized pattern specifier ('%c')\n", pattern[pos]);
+                break;
-            ++pos; /* skip past fmt specifier */
+            ++pos;      /* skip past fmt specifier */
             ++i;
             tpos = 0;
@@ -313,13 +316,13 @@
     else {
         status = resolve_pattern_string(HYD_ui_info.prepend_pattern, &prepend, pgid, proxy_id,
-                                      rank);
+                                        rank);
         HYDU_ERR_POP(status, "error resolving pattern\n");
         mark = 0;
         for (i = 0; i < buflen; i++) {
             if (buf[i] == '\n' || i == buflen - 1) {
-                if (prepend[0] != '\0') { /* sock_write barfs on maxlen==0 */
+                if (prepend[0] != '\0') {       /* sock_write barfs on maxlen==0 */
                     status = HYDU_sock_write(fd, (const void *) prepend,
                                              strlen(prepend), &sent, &closed);
More information about the mpich2-commits mailing list
