[mpich2-commits] r7708 - mpich2/trunk/src/pm/hydra/pm/pmiserv
balaji at mcs.anl.gov
Thu Jan 13 05:09:17 CST 2011
Author: balaji
Date: 2011-01-13 05:09:17 -0600 (Thu, 13 Jan 2011)
New Revision: 7708
Modified:
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_pmi_v1.c
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_pmi_v2.c
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_cb.c
Log:
Cleanup the PMI FD activation. Now we preload PMI ranks when launching
processes. If we forked out the MPI processes (PMI_FD format), we
preload the PMI FDs as well. If we are using a PMI PORT, we wait for
the application to send a PMI initialization message before loading
the PMI FD.
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c 2011-01-13 11:09:07 UTC (rev 7707)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c 2011-01-13 11:09:17 UTC (rev 7708)
@@ -209,7 +209,7 @@
static HYD_status pmi_cb(int fd, HYD_event_t events, void *userp)
char *buf = NULL, *pmi_cmd = NULL, *args[HYD_NUM_TMP_STRINGS] = { 0 };
- int closed, repeat, sent, i = -1, linelen, pid;
+ int closed, repeat, sent, i = -1, linelen, pid = -1;
struct HYD_pmcd_hdr hdr;
struct HYD_pmcd_pmip_pmi_handle *h;
char ftb_event_payload[HYDT_FTB_MAX_PAYLOAD_DATA];
@@ -227,13 +227,12 @@
&linelen, &closed, 0);
HYDU_ERR_POP(status, "unable to read PMI command\n");
- /* If we used the PMI_FD format, try to find the PMI FD */
- if (!using_pmi_port) {
- for (i = 0; i < HYD_pmcd_pmip.local.proxy_process_count; i++)
- if (HYD_pmcd_pmip.downstream.pmi_fd[i] == fd)
- break;
- HYDU_ASSERT(i < HYD_pmcd_pmip.local.proxy_process_count, status);
- pid = i;
+ /* Try to find the PMI FD */
+ for (i = 0; i < HYD_pmcd_pmip.local.proxy_process_count; i++) {
+ if (HYD_pmcd_pmip.downstream.pmi_fd[i] == fd) {
+ pid = i;
+ break;
if (closed) {
@@ -242,8 +241,12 @@
* get closed socket event as we deregister this socket as
* soon as we get the finalize message. For non-PMI
* applications, this is harder to identify, so we just let
- * the user cleanup the processes on a failure. */
- if (using_pmi_port || HYD_pmcd_pmip.downstream.pmi_fd_active[pid]) {
+ * the user cleanup the processes on a failure.
+ * We check of we found the PMI FD, and if the FD is "PMI
+ * active" (which means that this is an MPI application).
+ if (pid != -1 && HYD_pmcd_pmip.downstream.pmi_fd_active[pid]) {
MPL_snprintf(ftb_event_payload, HYDT_FTB_MAX_PAYLOAD_DATA,
"pgid:%d rank:%d",
HYD_pmcd_pmip.local.pgid, HYD_pmcd_pmip.downstream.pmi_rank[pid]);
@@ -282,8 +285,11 @@
storage[storage_len] = 0;
- /* This is a PMI application */
+ /* We were able to read the PMI command correctly. If we were able
+ * to identify what PMI FD this is, activate it. If we were not
+ * able to identify the PMI FD, we will activate it when we get
+ * the PMI initialization command. */
+ if (pid != -1 && !HYD_pmcd_pmip.downstream.pmi_fd_active[pid])
HYD_pmcd_pmip.downstream.pmi_fd_active[pid] = 1;
do {
@@ -425,13 +431,12 @@
static HYD_status launch_procs(void)
- int i, j, arg, process_id, pmi_rank;
+ int i, j, arg, process_id;
char *str, *envstr, *list, *pmi_port;
char *client_args[HYD_NUM_TMP_STRINGS];
struct HYD_env *env, *force_env = NULL;
struct HYD_exec *exec;
- int *pmi_ranks;
int sent, closed, pmi_fds[2] = { HYD_FD_UNSET, HYD_FD_UNSET };
struct HYDT_bind_cpuset_t cpuset;
@@ -443,15 +448,6 @@
for (exec = HYD_pmcd_pmip.exec_list; exec; exec = exec->next)
HYD_pmcd_pmip.local.proxy_process_count += exec->proc_count;
- HYDU_MALLOC(pmi_ranks, int *, HYD_pmcd_pmip.local.proxy_process_count * sizeof(int),
- status);
- for (i = 0; i < HYD_pmcd_pmip.local.proxy_process_count; i++) {
- pmi_ranks[i] =
- HYDU_local_to_global_id(i, HYD_pmcd_pmip.start_pid,
- HYD_pmcd_pmip.local.proxy_core_count,
- HYD_pmcd_pmip.system_global.global_core_count);
HYDU_MALLOC(HYD_pmcd_pmip.downstream.out, int *,
HYD_pmcd_pmip.local.proxy_process_count * sizeof(int), status);
HYDU_MALLOC(HYD_pmcd_pmip.downstream.err, int *,
@@ -467,17 +463,29 @@
HYDU_MALLOC(HYD_pmcd_pmip.downstream.pmi_fd_active, int *,
- /* Initialize the PMI_FD and PMI FD active state */
+ /* Initialize the PMI_FD and PMI FD active state, and exit status */
- HYD_pmcd_pmip.downstream.pmi_rank[i] = -1;
+ /* The exit status is populated when the processes terminate */
+ HYD_pmcd_pmip.downstream.exit_status[i] = -1;
+ /* If we use PMI_FD, the pmi_fd and pmi_fd_active arrays will
+ * be filled out in this function. But if we are using
+ * PMI_PORT, we will fill them out later when the processes
+ * send the PMI initialization message. Note that non-MPI
+ * processes are never "PMI active" when we use the PMI
+ * PORT. */
HYD_pmcd_pmip.downstream.pmi_fd[i] = HYD_FD_UNSET;
HYD_pmcd_pmip.downstream.pmi_fd_active[i] = 0;
+ if (HYD_pmcd_pmip.system_global.pmi_rank == -1)
+ HYD_pmcd_pmip.downstream.pmi_rank[i] =
+ HYDU_local_to_global_id(i, HYD_pmcd_pmip.start_pid,
+ HYD_pmcd_pmip.local.proxy_core_count,
+ HYD_pmcd_pmip.system_global.global_core_count);
+ else
+ HYD_pmcd_pmip.downstream.pmi_rank[i] = HYD_pmcd_pmip.system_global.pmi_rank;
- /* Initialize the exit status */
- HYD_pmcd_pmip.downstream.exit_status[i] = -1;
status = HYDT_bind_init(HYD_pmcd_pmip.local.local_binding ?
HYD_pmcd_pmip.local.local_binding :
HYD_pmcd_pmip.user_global.binding,
@@ -512,8 +520,9 @@
[HYD_pmcd_pmip.local.proxy_process_count - 1]);
status = HYDT_ckpoint_restart(HYD_pmcd_pmip.local.pgid, HYD_pmcd_pmip.local.id,
env, HYD_pmcd_pmip.local.proxy_process_count,
- pmi_ranks,
- pmi_ranks[0] ? NULL : &HYD_pmcd_pmip.downstream.in,
+ HYD_pmcd_pmip.downstream.pmi_rank,
+ HYD_pmcd_pmip.downstream.pmi_rank[0] ? NULL :
+ &HYD_pmcd_pmip.downstream.in,
HYD_pmcd_pmip.downstream.pid);
@@ -610,36 +619,22 @@
HYDU_strerror(errno));
for (i = 0; i < exec->proc_count; i++) {
+ if (using_pmi_port) {
+ /* If we are using the PMI_PORT format */
- if (HYD_pmcd_pmip.system_global.pmi_rank == -1)
- pmi_rank = HYDU_local_to_global_id(process_id,
- HYD_pmcd_pmip.start_pid,
- HYD_pmcd_pmip.
- system_global.global_core_count);
- else
- pmi_rank = HYD_pmcd_pmip.system_global.pmi_rank;
- HYD_pmcd_pmip.downstream.pmi_rank[process_id] = pmi_rank;
- if (HYD_pmcd_pmip.system_global.pmi_port ||
- HYD_pmcd_pmip.user_global.ckpoint_prefix) {
- /* If a global PMI_PORT is provided, or this is a
- * checkpointing case, use PMI_PORT format */
/* PMI_PORT */
status = HYDU_append_env_to_list("PMI_PORT", pmi_port, &force_env);
HYDU_ERR_POP(status, "unable to add env to list\n");
/* PMI_ID */
- str = HYDU_int_to_str(pmi_rank);
+ str = HYDU_int_to_str(HYD_pmcd_pmip.downstream.pmi_rank[process_id]);
status = HYDU_append_env_to_list("PMI_ID", str, &force_env);
HYDU_FREE(str);
else {
/* PMI_RANK */
status = HYDU_append_env_to_list("PMI_RANK", str, &force_env);
HYDU_FREE(str);
@@ -677,7 +672,8 @@
HYDT_bind_pid_to_cpuset(process_id, &cpuset);
status = HYDU_create_process(client_args, force_env,
- pmi_rank ? NULL : &HYD_pmcd_pmip.downstream.in,
+ HYD_pmcd_pmip.downstream.pmi_rank[process_id] ? NULL :
&HYD_pmcd_pmip.downstream.out[process_id],
&HYD_pmcd_pmip.downstream.err[process_id],
&HYD_pmcd_pmip.downstream.pid[process_id],
@@ -726,8 +722,6 @@
HYDU_ERR_POP(status, "unable to register fd\n");
fn_exit:
- if (pmi_ranks)
- HYDU_FREE(pmi_ranks);
HYDU_FUNC_EXIT();
return status;
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_pmi_v1.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_pmi_v1.c 2011-01-13 11:09:07 UTC (rev 7707)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_pmi_v1.c 2011-01-13 11:09:17 UTC (rev 7708)
@@ -139,22 +139,14 @@
id = atoi(val);
/* Store the PMI_ID to fd mapping */
if (HYD_pmcd_pmip.downstream.pmi_rank[i] == id) {
HYD_pmcd_pmip.downstream.pmi_fd[i] = fd;
+ HYD_pmcd_pmip.downstream.pmi_fd_active[i] = 1;
break;
- /* The rank has not been previously stored */
- if (i == HYD_pmcd_pmip.local.proxy_process_count) {
- if (HYD_pmcd_pmip.downstream.pmi_rank[i] == -1)
- break;
- HYD_pmcd_pmip.downstream.pmi_rank[i] = id;
- HYD_pmcd_pmip.downstream.pmi_fd[i] = fd;
+ HYDU_ASSERT(i < HYD_pmcd_pmip.local.proxy_process_count, status);
i = 0;
tmp[i++] = HYDU_strdup("cmd=initack\ncmd=set size=");
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_pmi_v2.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_pmi_v2.c 2011-01-13 11:09:07 UTC (rev 7707)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_pmi_v2.c 2011-01-13 11:09:17 UTC (rev 7708)
@@ -165,9 +165,14 @@
id = atoi(rank_str);
/* Store the PMI_RANK to fd mapping */
- if (HYD_pmcd_pmip.downstream.pmi_rank[i] == id)
+ if (HYD_pmcd_pmip.downstream.pmi_rank[i] == id) {
+ break;
i = 0;
/* FIXME: allow for multiple ranks per PMI ID */
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_cb.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_cb.c 2011-01-13 11:09:07 UTC (rev 7707)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_cb.c 2011-01-13 11:09:17 UTC (rev 7708)
@@ -140,6 +140,7 @@
proxy = (struct HYD_proxy *) userp;
if (fd == STDIN_FILENO) {
+ HYD_pmcd_init_header(&hdr);
hdr.cmd = STDIN;
else {
More information about the mpich2-commits
