[mpich2-commits] r7700 - in mpich2/trunk/src/mpi/romio: . adio/ad_testfs adio/common
robl at mcs.anl.gov robl at mcs.anl.gov
Wed Jan 12 12:33:00 CST 2011
Author: robl
Date: 2011-01-12 12:33:00 -0600 (Wed, 12 Jan 2011)
New Revision: 7700
Modified:
   mpich2/trunk/src/mpi/romio/Makefile.in
   mpich2/trunk/src/mpi/romio/adio/ad_testfs/Makefile.in
   mpich2/trunk/src/mpi/romio/adio/common/Makefile.in
   mpich2/trunk/src/mpi/romio/configure.in
Log:
to address r965: --with-mpi now points to the installed location of an mpi
library.  if for some reason we need the MPI implementation, use
--with-mpi-impl (but it looks like that historical flag doesn't actually do
anything any longer
Modified: mpich2/trunk/src/mpi/romio/Makefile.in
--- mpich2/trunk/src/mpi/romio/Makefile.in	2011-01-12 18:22:30 UTC (rev 7699)
+++ mpich2/trunk/src/mpi/romio/Makefile.in	2011-01-12 18:33:00 UTC (rev 7700)
@@ -6,7 +6,6 @@
 LIBNAME     = @LIBNAME@
 NOF77       = @NOF77@
 NOPROFILE   = @NOPROFILE@
-MPI         = @MPI@
 PREFIX      = @prefix@
 srcdir      = @srcdir@
 BUILD_MPI_INFO = @BUILD_MPI_INFO@
Modified: mpich2/trunk/src/mpi/romio/adio/ad_testfs/Makefile.in
--- mpich2/trunk/src/mpi/romio/adio/ad_testfs/Makefile.in	2011-01-12 18:22:30 UTC (rev 7699)
+++ mpich2/trunk/src/mpi/romio/adio/ad_testfs/Makefile.in	2011-01-12 18:33:00 UTC (rev 7700)
@@ -2,7 +2,6 @@
 AR          = @AR@
 RANLIB      = @RANLIB@
 LIBNAME     = @LIBNAME@
-MPI         = @MPI@
 srcdir      = @srcdir@
 CC_SHL      = @CC_SHL@
 SHLIBNAME   = @SHLIBNAME@
Modified: mpich2/trunk/src/mpi/romio/adio/common/Makefile.in
--- mpich2/trunk/src/mpi/romio/adio/common/Makefile.in	2011-01-12 18:22:30 UTC (rev 7699)
+++ mpich2/trunk/src/mpi/romio/adio/common/Makefile.in	2011-01-12 18:33:00 UTC (rev 7700)
@@ -2,7 +2,6 @@
 AR          = @AR@
 RANLIB      = @RANLIB@
 LIBNAME     = @LIBNAME@
-MPI         = @MPI@
 srcdir      = @srcdir@
 CC_SHL      = @CC_SHL@
Modified: mpich2/trunk/src/mpi/romio/configure.in
--- mpich2/trunk/src/mpi/romio/configure.in	2011-01-12 18:22:30 UTC (rev 7699)
+++ mpich2/trunk/src/mpi/romio/configure.in	2011-01-12 18:33:00 UTC (rev 7700)
@@ -21,7 +21,7 @@
 NOF90=0
 ARCH=""
 arch_IRIX=""
-MPI=""
+MPI_IMPL=""
 MPI_INCLUDE_DIR=""
 ROMIO_INCLUDE=""
 TEST_LIBNAME=""
@@ -119,9 +119,12 @@
 --with-file-system=name - Build with support for the named file systems],,)
 AC_ARG_WITH(pvfs2,[
 --with-pvfs2=path - Path to installation of PVFS (version 2)],,)
-AC_ARG_WITH(mpi,[
---with-mpi=name - Specify MPI implementation to build ROMIO for],,)
+AC_ARG_WITH(mpi-impl,[
+--with-mpi-impl=name - Specify MPI implementation to build ROMIO for],,)
 dnl
+AC_ARG_WITH(mpi, [
+--with-mpi=path   - Path to instalation of MPI (headers, libs, etc)],,)
+dnl
 if test "$enable_f77" != "yes" ; then
    NOF77=1
 fi
@@ -252,10 +255,10 @@
     WITHIN_KNOWN_MPI_IMPL=no
 fi
 # check for valid MPI implementation
-if test -n "$MPI" ; then
+if test -n "$MPI_IMPL" ; then
    found=no
    for mpi in $known_mpi_impls ; do
-      if test "${MPI}_mpi" = "$mpi" ; then
+      if test "${MPI_IMPL}_mpi" = "$mpi" ; then
           found=yes
 	  break
       fi
@@ -265,6 +268,12 @@
    fi
 fi
+if test -n "${with_mpi}" ; then
+	MPI_INCLUDE_DIR="${with_mpi}"/include
+	MPI_LIB_DIR="${with_mpi}"/lib
+fi
 # check for valid MPI include directory if specified
 if test $WITHIN_KNOWN_MPI_IMPL = no ; then
    if test -n "$MPI_INCLUDE_DIR"; then
@@ -432,11 +441,11 @@
 # Here go the rest of the tests
 if test -n "$arch_solaris" || test -n "$arch_solaris86" ; then
-    if test -z "$MPI" ; then
-        MPI=mpich
+    if test -z "$MPI_IMPL" ; then
+        MPI_IMPL=mpich
         mpi_mpich=1
     fi
-    if test $MPI = "mpich" ; then
+    if test $MPI_IMPL = "mpich" ; then
         TEST_CC=mpicc
         TEST_F77=mpif77
     else
@@ -449,8 +458,8 @@
 if test -n "$arch_rs6000"; then
-        MPI=mpich
+        MPI_IMPL=mpich
         mpi_mpich=1
     fi
     AC_DEFINE(AIX,1,[Define for AIX])
@@ -467,8 +476,8 @@
     AR="xar cr$AR_LOCAL"
     RANLIB="xranlib"
     MPI_LIB="$MPI_LIB"
-        MPI=mpich
+        MPI_IMPL=mpich
         mpi_mpich=1
     fi
     if test -z "$FILE_SYSTEM" ; then
@@ -484,8 +493,8 @@
     fi
     # Find the CPP before the header check
     AC_PROG_CPP
-        MPI=mpich
+        MPI_IMPL=mpich
         mpi_mpich=1
     fi
 fi
@@ -493,8 +502,8 @@
 if test -n "$arch_SX4" ; then
     have_aio=no
     AC_DEFINE(SX4,1,[Define for NEC SX4])
-        MPI=mpich
+        MPI_IMPL=mpich
         mpi_mpich=1
     fi
@@ -510,34 +519,34 @@
 if test -n "$arch_hpux" || test -n "$arch_sppux" ; then
     have_aio=no
     RANLIB=":"
-    if test -z "$MPI"; then
+    if test -z "$MPI_IMPL"; then
         if test -f "/opt/mpi/include/mpi.h" ; then
             echo "assuming that you want to use ROMIO with HP MPI"
-            MPI=hp
+            MPI_IMPL=hp
         else
             echo "assuming that you want to use ROMIO with MPICH"
-            MPI=mpich
+            MPI_IMPL=mpich
         fi
     fi
         mpi_mpich=1
         MPI_LIB="$MPI_LIB -lV3"
         CC=${CC:-cc -Ae}
         F77=${FC:-f77 +U77}
     fi
-    if test $MPI = "hp" ; then
+    if test $MPI_IMPL = "hp" ; then
         mpi_hp=1
         CC=${CC:-mpicc -Ae}
         F77=${FC:-mpif77 +U77}
     fi
-    if test $MPI = "lam" && test "$FC" != ""; then
+    if test $MPI_IMPL = "lam" && test "$FC" != ""; then
         F77="$F77 +U77"
     fi
     FTESTDEFINE="external iargc, getarg"
     if test -n "$arch_hpux" ; then
         CFLAGS="$CFLAGS -D_LARGEFILE64_SOURCE"
         AC_DEFINE(HPUX,1,[Define for HPUX])
            F77=${FC:-mpif90 +U77}
         else
            F77=${FC:-f90 +U77}
@@ -558,8 +567,8 @@
 fi
 if test -n "$arch_alpha" || test -n "$arch_ALPHA" ; then
-        MPI=mpich
+        MPI_IMPL=mpich
         mpi_mpich=1
     fi
@@ -576,8 +585,8 @@
     have_aio=no
     RANLIB=":"
     AC_DEFINE(CRAY,1,[Define if Cray])
-    if test -z "$MPI" || test -n "$mpi_sgi" ; then
-        MPI=cray
+    if test -z "$MPI_IMPL" || test -n "$mpi_sgi" ; then
+        MPI_IMPL=cray
         mpi_cray=1
         mpi_sgi=""
 # above is to disable configure tests specific to SGI MPI
@@ -633,21 +642,21 @@
             AC_MSG_ERROR([SGI\'s MPI does not work with IRIX 5.x])
         fi
    elif test $osversion = 6 ; then
 	    if test "$FROM_MPICH2" = "yes" ; then
 	        # Building with MPICH2.  Distinguish from MPICH-1
-		MPI=mpich2
+		MPI_IMPL=mpich2
 		mpi_mpich2=1
             elif test -f "/usr/include/mpi.h" ; then
                 # removed use of escaped single quotes in messages
 		# because they confuse Emacs, making it hard to
 		# read the files (with emacs :) )
                 AC_MSG_WARN([assuming that you want to use ROMIO with the SGI MPI])
-                MPI=sgi
+                MPI_IMPL=sgi
                 mpi_sgi=1
             else
 	        AC_MSG_WARN([assuming that you want to use ROMIO with MPICH])
-                MPI=mpich
+                MPI_IMPL=mpich
                 mpi_mpich=1
             fi
 	fi
@@ -1953,9 +1962,9 @@
 done
 EXTRA_SRC_DIRS=""
 GLUE_DIR=""
-if test "$FROM_MPICH2" = yes -o "${MPI}_mpi" = "mpich2_mpi"; then
+if test "$FROM_MPICH2" = yes -o "${MPI_IMPL}_mpi" = "mpich2_mpi"; then
     GLUE_DIR="mpi-io/glue/mpich2"
-elif test "$FROM_MPICH" = yes -o "${MPI}_mpi" = "mpich_mpi"; then
+elif test "$FROM_MPICH" = yes -o "${MPI_IMPL}_mpi" = "mpich_mpi"; then
     GLUE_DIR="mpi-io/glue/mpich1"
 else
     GLUE_DIR="mpi-io/glue/default"
@@ -2026,7 +2035,6 @@
 AC_SUBST(USER_FFLAGS)
 AC_SUBST(MIPS)
 AC_SUBST(BITS)
-AC_SUBST(MPI)
 AC_SUBST(AR)
 AC_SUBST(AR_FLAGS)
 AC_SUBST(RANLIB)
More information about the mpich2-commits mailing list
