[mpich2-commits] r7696 - mpich2/trunk/src/pm/hydra/utils/launch
balaji at mcs.anl.gov balaji at mcs.anl.gov
Wed Jan 12 06:21:11 CST 2011
Author: balaji
Date: 2011-01-12 06:21:11 -0600 (Wed, 12 Jan 2011)
New Revision: 7696
Modified:
   mpich2/trunk/src/pm/hydra/utils/launch/launch.c
Log:
Bug-fix: handle directories that have a space in them. The work-around
used is to chdir to the directory where the executable is located and
launch the program from there. Fixes ticket #1160.
Modified: mpich2/trunk/src/pm/hydra/utils/launch/launch.c
--- mpich2/trunk/src/pm/hydra/utils/launch/launch.c	2011-01-12 10:10:09 UTC (rev 7695)
+++ mpich2/trunk/src/pm/hydra/utils/launch/launch.c	2011-01-12 12:21:11 UTC (rev 7696)
@@ -11,7 +11,8 @@
                                int *in, int *out, int *err, int *pid,
                                struct HYDT_bind_cpuset_t cpuset)
-    int inpipe[2], outpipe[2], errpipe[2], tpid;
+    int inpipe[2], outpipe[2], errpipe[2], tpid, i, j, k, has_space, num_args, ret;
+    char *path = NULL, **args;
     HYD_status status = HYD_SUCCESS;
     HYDU_FUNC_ENTER();
@@ -61,7 +62,47 @@
         status = HYDT_bind_process(cpuset);
         HYDU_ERR_POP(status, "bind process failed\n");
-        if (execvp(client_arg[0], client_arg) < 0) {
+        status = HYDU_strdup_list(client_arg, &args);
+        HYDU_ERR_POP(status, "unable to dup argument list\n");
+        num_args = HYDU_strlist_lastidx(client_arg);
+        for (j = 0; j < num_args; j++) {
+            has_space = 0;
+            for (i = 0; args[j][i]; i++) {
+                if (args[j][i] == ' ') {
+                    has_space = 1;
+                    break;
+            if (has_space) {
+                /* executable string has space */
+                HYDU_FREE(args[j]);
+                if (j == 0) {
+                    path = HYDU_strdup(client_arg[j]);
+                    k = 0;
+                    for (i = 0; path[i]; i++)
+                        if (path[i] == '/')
+                            k = i + 1;
+                    path[k] = 0;
+                    if (path[0]) {
+                        ret = chdir(path);
+                        HYDU_ASSERT(!ret, status);
+                    args[j] = HYDU_strdup(&client_arg[j][k]);
+                else {
+                    HYDU_MALLOC(args[j], char *, strlen(client_arg[j]) + 3, status);
+                    MPL_snprintf(args[j], strlen(client_arg[j]) + 5, "'%s'", client_arg[j]);
+        if (execvp(args[0], args) < 0) {
             /* The child process should never get back to the proxy
              * code; if there is an error, just throw it here and
              * exit. */
More information about the mpich2-commits mailing list
