[mpich2-commits] r7687 - in mpich2/trunk/src/mpid/ch3: channels/nemesis/include channels/nemesis/nemesis/include channels/nemesis/src channels/sctp/include channels/sock/include include
buntinas at mcs.anl.gov
Tue Jan 11 17:28:13 CST 2011
Author: buntinas
Date: 2011-01-11 17:28:13 -0600 (Tue, 11 Jan 2011)
New Revision: 7687
Modified:
mpich2/trunk/src/mpid/ch3/channels/nemesis/include/mpidi_ch3_post.h
mpich2/trunk/src/mpid/ch3/channels/nemesis/include/mpidi_ch3_pre.h
mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/include/mpid_nem_inline.h
mpich2/trunk/src/mpid/ch3/channels/nemesis/src/ch3_progress.c
mpich2/trunk/src/mpid/ch3/channels/sctp/include/mpidi_ch3_pre.h
mpich2/trunk/src/mpid/ch3/channels/sock/include/mpidi_ch3_pre.h
mpich2/trunk/src/mpid/ch3/include/mpidpost.h
Log:
Changed global completion count to use atomics rather than locks. This will allow us to update the completion count asynchronously from other threads or interrupt contexts
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/include/mpidi_ch3_post.h
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/include/mpidi_ch3_post.h 2011-01-11 20:04:11 UTC (rev 7686)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/include/mpidi_ch3_post.h 2011-01-11 23:28:13 UTC (rev 7687)
@@ -10,12 +10,8 @@
/* #define MPIDI_CH3_EAGER_MAX_MSG_SIZE (1500 - sizeof(MPIDI_CH3_Pkt_t)) */
#define MPIDI_CH3_EAGER_MAX_MSG_SIZE (128*1024)
-#define MPIDI_CH3_Progress_start(progress_state_) \
-do { \
- MPIU_THREAD_CS_ENTER(COMPLETION,); \
- (progress_state_)->ch.completion_count = MPIDI_CH3I_progress_completion_count; \
- MPIU_THREAD_CS_EXIT(COMPLETION,); \
-} while (0)
+#define MPIDI_CH3_Progress_start(progress_state_) \
+ (progress_state_)->ch.completion_count = OPA_load_int(&MPIDI_CH3I_progress_completion_count);
#define MPIDI_CH3_Progress_end(progress_state_)
enum {
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/include/mpidi_ch3_pre.h
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/include/mpidi_ch3_pre.h 2011-01-11 20:04:11 UTC (rev 7686)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/include/mpidi_ch3_pre.h 2011-01-11 23:28:13 UTC (rev 7687)
@@ -14,6 +14,7 @@
#include <winsock2.h>
#include <windows.h>
#endif
+#include "opa_primitives.h"
/*#define MPID_USE_SEQUENCE_NUMBERS*/
/*#define HAVE_CH3_PRE_INIT*/
@@ -130,5 +131,14 @@
#define MPIDI_CH3_PROGRESS_STATE_DECL MPIDI_CH3I_Progress_state ch;
+extern OPA_int_t MPIDI_CH3I_progress_completion_count;
+#define MPIDI_CH3I_INCR_PROGRESS_COMPLETION_COUNT do { \
+ OPA_write_barrier(); \
+ OPA_incr_int(&MPIDI_CH3I_progress_completion_count); \
+ MPIU_DBG_MSG_D(CH3_PROGRESS,VERBOSE, \
+ "just incremented MPIDI_CH3I_progress_completion_count=%d", \
+ OPA_load_int(&MPIDI_CH3I_progress_completion_count)); \
+ } while(0)
#endif /* !defined(MPICH_MPIDI_CH3_PRE_H_INCLUDED) */
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/include/mpid_nem_inline.h
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/include/mpid_nem_inline.h 2011-01-11 20:04:11 UTC (rev 7686)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/include/mpid_nem_inline.h 2011-01-11 23:28:13 UTC (rev 7687)
@@ -866,7 +866,7 @@
MPID_nem_mpich2_blocking_recv(MPID_nem_cell_ptr_t *cell, int *in_fbox)
int mpi_errno = MPI_SUCCESS;
- unsigned completions = MPIDI_CH3I_progress_completion_count;
+ unsigned completions = OPA_load_int(&MPIDI_CH3I_progress_completion_count);
#ifndef ENABLE_NO_YIELD
int pollcount = 0;
#endif
@@ -905,8 +905,8 @@
mpi_errno = MPID_nem_network_poll(TRUE /* blocking */);
if (mpi_errno) MPIU_ERR_POP (mpi_errno);
- if (completions != MPIDI_CH3I_progress_completion_count || MPID_nem_local_lmt_pending || MPIDI_CH3I_active_send[CH3_NORMAL_QUEUE]
- || MPIDI_CH3I_SendQ_head(CH3_NORMAL_QUEUE))
+ if (completions != OPA_load_int(&MPIDI_CH3I_progress_completion_count) || MPID_nem_local_lmt_pending
+ || MPIDI_CH3I_active_send[CH3_NORMAL_QUEUE] || MPIDI_CH3I_SendQ_head(CH3_NORMAL_QUEUE))
*cell = NULL;
*in_fbox = 0;
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/src/ch3_progress.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/src/ch3_progress.c 2011-01-11 20:04:11 UTC (rev 7686)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/src/ch3_progress.c 2011-01-11 23:28:13 UTC (rev 7687)
@@ -33,11 +33,7 @@
extern MPID_Request ** const MPID_Recvq_unexpected_tail_ptr;
#endif
-/* MT any races on this var reported by DRD/helgrind/TSan are probably bugs.
- * This var is protected by the COMPLETION critical section in non-global mode. */
-/* FIXME volatile is probably unnecessary, access is arbitrated entirely by
- * mutex, but the decl is shared among channels */
-volatile unsigned int MPIDI_CH3I_progress_completion_count = 0;
+OPA_int_t MPIDI_CH3I_progress_completion_count = OPA_INT_T_INITIALIZER(0);
/* NEMESIS MULTITHREADING: Extra Data Structures Added */
#ifdef MPICH_IS_THREADED
@@ -448,19 +444,20 @@
/* in the case of progress_wait, bail out if anything completed (CC-1) */
if (is_blocking) {
- int made_progress = FALSE;
- if (progress_state->ch.completion_count != MPIDI_CH3I_progress_completion_count) {
- made_progress = TRUE;
+ int completion_count = OPA_load_int(&MPIDI_CH3I_progress_completion_count);
+ if (progress_state->ch.completion_count != completion_count) {
+ /* Read barrier to make sure no reads get values before the
+ completion counter was incremented */
+ OPA_read_barrier();
/* reset for the next iteration */
- progress_state->ch.completion_count = MPIDI_CH3I_progress_completion_count;
+ progress_state->ch.completion_count = completion_count;
+ break;
- if (made_progress) break;
while (is_blocking);
MPIU_THREAD_CHECK_BEGIN;
@@ -498,15 +495,9 @@
while (1)
- /* we also currently hold the MPIDCOMM CS */
- if (completion_count != MPIDI_CH3I_progress_completion_count ||
+ if (completion_count != OPA_load_int(&MPIDI_CH3I_progress_completion_count) ||
MPIDI_CH3I_progress_blocked != TRUE)
break;
MPID_Thread_cond_wait(&MPIDI_CH3I_progress_completion_cond, &MPIR_ThreadInfo.global_mutex/*MPIDCOMM*/);
Modified: mpich2/trunk/src/mpid/ch3/channels/sctp/include/mpidi_ch3_pre.h
--- mpich2/trunk/src/mpid/ch3/channels/sctp/include/mpidi_ch3_pre.h 2011-01-11 20:04:11 UTC (rev 7686)
+++ mpich2/trunk/src/mpid/ch3/channels/sctp/include/mpidi_ch3_pre.h 2011-01-11 23:28:13 UTC (rev 7687)
@@ -229,4 +229,9 @@
+/* This variable is used in the definitions of the MPID_Progress_xxx macros,
+ and must be available to the routines in src/mpi */
+extern volatile unsigned int MPIDI_CH3I_progress_completion_count;
Modified: mpich2/trunk/src/mpid/ch3/channels/sock/include/mpidi_ch3_pre.h
--- mpich2/trunk/src/mpid/ch3/channels/sock/include/mpidi_ch3_pre.h 2011-01-11 20:04:11 UTC (rev 7686)
+++ mpich2/trunk/src/mpid/ch3/channels/sock/include/mpidi_ch3_pre.h 2011-01-11 23:28:13 UTC (rev 7687)
@@ -58,6 +58,11 @@
/* MPICH_IS_THREADED isn't defined yet (handled by mpiimplthread.h) */
#if (MPICH_THREAD_LEVEL == MPI_THREAD_MULTIPLE)
#define MPIDI_CH3I_PROGRESS_WAKEUP \
Modified: mpich2/trunk/src/mpid/ch3/include/mpidpost.h
--- mpich2/trunk/src/mpid/ch3/include/mpidpost.h 2011-01-11 20:04:11 UTC (rev 7686)
+++ mpich2/trunk/src/mpid/ch3/include/mpidpost.h 2011-01-11 23:28:13 UTC (rev 7687)
@@ -159,10 +159,6 @@
void MPIDI_CH3U_Request_destroy(MPID_Request * req);
-/* This variable is used in the definitions of the MPID_Progress_xxx macros,
- and must be available to the routines in src/mpi */
-extern volatile unsigned int MPIDI_CH3I_progress_completion_count;
/* Include definitions from the channel which require items defined by this
file (mpidimpl.h) or the file it includes
(mpiimpl.h). */
More information about the mpich2-commits
