[mpich2-commits] r7684 - in mpich2/trunk/src/mpi/romio/adio: common include
goodell at mcs.anl.gov
Tue Jan 11 12:30:35 CST 2011
Author: goodell
Date: 2011-01-11 12:30:35 -0600 (Tue, 11 Jan 2011)
New Revision: 7684
Modified:
mpich2/trunk/src/mpi/romio/adio/common/ad_end.c
mpich2/trunk/src/mpi/romio/adio/common/cb_config_list.c
mpich2/trunk/src/mpi/romio/adio/include/adio_extern.h
Log:
fix the cb_config_list keyval usage in ROMIO
In the old code it was possible that ROMIO freed the keyval multiple
times, rather than just once. This was fine in MPICH2, which is robust
in the face of such behavior, but caused problems for ROMIO over Open
MPI. We now utilize the MPI-2.2 LIFO ordering for attribute destruction
in order to free the keyval exactly once.
Reported by Pascal Deveze and related to ticket #222.
Reviewed by robl at .
Modified: mpich2/trunk/src/mpi/romio/adio/common/ad_end.c
--- mpich2/trunk/src/mpi/romio/adio/common/ad_end.c 2011-01-11 17:35:45 UTC (rev 7683)
+++ mpich2/trunk/src/mpi/romio/adio/common/ad_end.c 2011-01-11 18:30:35 UTC (rev 7684)
@@ -75,6 +75,13 @@
ADIOI_UNREFERENCED_ARG(extra_state);
MPI_Keyval_free(&keyval);
+ /* The end call will be called after all possible uses of this keyval, even
+ * if a file was opened with MPI_COMM_SELF. Note, this assumes LIFO
+ * MPI_COMM_SELF attribute destruction behavior mandated by MPI-2.2. */
+ if (ADIOI_cb_config_list_keyval != MPI_KEYVAL_INVALID)
+ MPI_Keyval_free(&ADIOI_cb_config_list_keyval);
ADIO_End(&error_code);
return error_code;
Modified: mpich2/trunk/src/mpi/romio/adio/common/cb_config_list.c
--- mpich2/trunk/src/mpi/romio/adio/common/cb_config_list.c 2011-01-11 17:35:45 UTC (rev 7683)
+++ mpich2/trunk/src/mpi/romio/adio/common/cb_config_list.c 2011-01-11 18:30:35 UTC (rev 7684)
@@ -35,7 +35,7 @@
#undef CB_CONFIG_LIST_DEBUG
/* a couple of globals keep things simple */
-static int cb_config_list_keyval = MPI_KEYVAL_INVALID;
+int ADIOI_cb_config_list_keyval = MPI_KEYVAL_INVALID;
static char *yylval;
static char *token_ptr;
@@ -111,23 +111,16 @@
ADIO_cb_name_array array = NULL;
int alloc_size;
- if (cb_config_list_keyval == MPI_KEYVAL_INVALID) {
+ if (ADIOI_cb_config_list_keyval == MPI_KEYVAL_INVALID) {
+ /* cleaned up by ADIOI_End_call */
MPI_Keyval_create((MPI_Copy_function *) ADIOI_cb_copy_name_array,
(MPI_Delete_function *) ADIOI_cb_delete_name_array,
- &cb_config_list_keyval, NULL);
- /* Need a hook so we can cleanup in Finalize */
- MPI_Attr_put(MPI_COMM_SELF, cb_config_list_keyval, NULL);
+ &ADIOI_cb_config_list_keyval, NULL);
else {
- MPI_Attr_get(comm, cb_config_list_keyval, (void *) &array, &found);
- /* see above: we put a cb_config_list_keyval with NULL array on
- * COMM_SELF so we can clean it up on exit. So it's not enough
- * to find the keyval. we also need a non-null array (every mpi
- * program will have at least one element in the array --
- * itself. Not doing this confuses the shared file ponters
- * routines. I know it is ugly but I can't figure out a better
- * way... if we find the e*/
- if (found && (array != NULL)) {
+ MPI_Attr_get(comm, ADIOI_cb_config_list_keyval, (void *) &array, &found);
+ if (found) {
+ ADIOI_Assert(array != NULL);
*arrayp = array;
return 0;
@@ -240,8 +233,8 @@
* it next time an open is performed on this same comm, and on the
* dupcomm, so we can use it in I/O operations.
- MPI_Attr_put(comm, cb_config_list_keyval, array);
- MPI_Attr_put(dupcomm, cb_config_list_keyval, array);
+ MPI_Attr_put(comm, ADIOI_cb_config_list_keyval, array);
+ MPI_Attr_put(dupcomm, ADIOI_cb_config_list_keyval, array);
*arrayp = array;
return 0;
@@ -405,8 +398,7 @@
ADIOI_UNREFERENCED_ARG(extra);
array = (ADIO_cb_name_array) attr_val;
- if (array == NULL)
- goto fn_exit;
array->refct--;
if (array->refct <= 0) {
@@ -421,8 +413,6 @@
if (array->names != NULL) ADIOI_Free(array->names);
ADIOI_Free(array);
-fn_exit:
- MPI_Keyval_free(&keyval);
return MPI_SUCCESS;
Modified: mpich2/trunk/src/mpi/romio/adio/include/adio_extern.h
--- mpich2/trunk/src/mpi/romio/adio/include/adio_extern.h 2011-01-11 17:35:45 UTC (rev 7683)
+++ mpich2/trunk/src/mpi/romio/adio/include/adio_extern.h 2011-01-11 18:30:35 UTC (rev 7684)
@@ -27,3 +27,5 @@
extern MPI_Info ADIOI_syshints;
extern MPI_Op ADIO_same_amode;
+extern int ADIOI_cb_config_list_keyval;
More information about the mpich2-commits
