[mpich2-commits] r7678 - in mpich2/trunk/src/util: mem param
goodell at mcs.anl.gov
Mon Jan 10 17:29:25 CST 2011
Author: goodell
Date: 2011-01-10 17:29:25 -0600 (Mon, 10 Jan 2011)
New Revision: 7678
Modified:
mpich2/trunk/src/util/mem/handlemem.c
mpich2/trunk/src/util/param/params.yml
Log:
add MPIR_PARAM_ABORT_ON_LEAKED_HANDLES to help applications detect handle leaks
This was a feature request from Quincey in order to improve the
effectiveness of the HDF5 test suite.
No reviewer.
Modified: mpich2/trunk/src/util/mem/handlemem.c
--- mpich2/trunk/src/util/mem/handlemem.c 2011-01-10 22:11:27 UTC (rev 7677)
+++ mpich2/trunk/src/util/mem/handlemem.c 2011-01-10 23:29:25 UTC (rev 7678)
@@ -552,6 +552,7 @@
MPIU_Object_alloc_t *objmem = (MPIU_Object_alloc_t *)objmem_ptr;
int i;
MPIU_Handle_common *ptr;
+ int leaked_handles = FALSE;
int directSize = objmem->direct_size;
char *direct = (char *)objmem->direct;
char *directEnd = (char *)direct + directSize * objmem->size - 1;
@@ -608,10 +609,12 @@
objmem->indirect_size );
if (nDirect != directSize) {
+ leaked_handles = TRUE;
printf( "In direct memory block for handle type %s, %d handles are still allocated\n", MPIR_ObjectName( objmem ), directSize - nDirect );
for (i=0; i<objmem->indirect_size; i++) {
if (nIndirect[i] != HANDLE_BLOCK_SIZE) {
printf( "In indirect memory block %d for handle type %s, %d handles are still allocated\n", i, MPIR_ObjectName( objmem ), HANDLE_BLOCK_SIZE - nIndirect[i] );
@@ -620,6 +623,13 @@
MPIU_Free( nIndirect );
+ if (leaked_handles && MPIR_PARAM_ABORT_ON_LEAKED_HANDLES) {
+ /* comm_world has been (or should have been) destroyed by this point,
+ * pass comm=NULL */
+ MPID_Abort(NULL, MPI_ERR_OTHER, 1, "ERROR: leaked handles detected, aborting");
+ MPIU_Assert(0);
return 0;
Modified: mpich2/trunk/src/util/param/params.yml
--- mpich2/trunk/src/util/param/params.yml 2011-01-10 22:11:27 UTC (rev 7677)
+++ mpich2/trunk/src/util/param/params.yml 2011-01-10 23:29:25 UTC (rev 7678)
@@ -24,6 +24,8 @@
description : intranode communication parameters
- name : developer
description : useful for developers working on MPICH2 itself
+ - name : memory
+ description : affects memory allocation and usage, including MPI object handles
- name : error_handling
description : parameters that control error handling behavior (stack traces, aborts, etc)
- name : debugger
@@ -273,6 +275,21 @@
If true, enables checkpointing support and returns an error if
checkpointing library cannot be initialized.
+ # memory parameters
+ - category : memory
+ name : ABORT_ON_LEAKED_HANDLES
+ type : boolean
+ default : false
+ description : >-
+ If true, MPI will call MPI_Abort at MPI_Finalize if any MPI object
+ handles have been leaked. For example, if MPI_Comm_dup is called
+ without calling a corresponding MPI_Comm_free. For uninteresting
+ reasons, enabling this option may prevent all known object leaks from
+ being reported. MPICH2 must have been configure with
+ "--enable-g=handlealloc" or better in order for this functionality to
+ work.
# Local Variables:
More information about the mpich2-commits
