[mpich2-commits] r7657 - in mpich2/branches/release/mpich2-1.3.x: . confdb maint src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp src/mpl/src src/pm/hydra src/pm/hydra/examples src/pm/hydra/include src/pm/hydra/pm src/pm/hydra/tools src/pm/hydra/tools/bootstrap/external src/pm/hydra/tools/bootstrap/src src/pm/hydra/tools/bootstrap/utils src/pm/hydra/ui src/pm/hydra/utils
gropp at mcs.anl.gov
Tue Jan 4 08:16:50 CST 2011
Author: gropp
Date: 2011-01-04 08:16:50 -0600 (Tue, 04 Jan 2011)
New Revision: 7657
Modified:
mpich2/branches/release/mpich2-1.3.x/
mpich2/branches/release/mpich2-1.3.x/confdb/
mpich2/branches/release/mpich2-1.3.x/confdb/aclocal_mpi.m4
mpich2/branches/release/mpich2-1.3.x/maint/Version
mpich2/branches/release/mpich2-1.3.x/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c
mpich2/branches/release/mpich2-1.3.x/src/mpl/src/mplstr.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/Makefile.am
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/README
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/autogen.sh
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/configure.in
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/examples/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/hydra-doxygen.cfg.in
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/include/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/mpich2prereq
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/ui/
mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/utils/
mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf
Log:
Fixes for PAC_MPI macros required because of changes in the behavior of autoconf macros
Property changes on: mpich2/branches/release/mpich2-1.3.x
___________________________________________________________________
Modified: svn:mergeinfo
- /mpich2/branches/dev/ckpt:5050
/mpich2/branches/dev/ckpt2:5057-6537
/mpich2/branches/dev/ftb:5661-5730
/mpich2/branches/dev/lapi:5817
/mpich2/branches/dev/wintcp_async_progress:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2:5406
/mpich2/trunk:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt:5050
/mpich2/trunk:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/confdb
- /mpich2/branches/dev/ckpt2/confdb:5180,5182,5196,5198
/mpich2/branches/dev/ftb/confdb:5661-5730
/mpich2/branches/dev/lapi/confdb:5817
/mpich2/branches/dev/wintcp_async_progress/confdb:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/confdb:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/confdb:5406
/mpich2/trunk/confdb:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt2/confdb:5180,5182,5196,5198
/mpich2/trunk/confdb:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Modified: mpich2/branches/release/mpich2-1.3.x/confdb/aclocal_mpi.m4
--- mpich2/branches/release/mpich2-1.3.x/confdb/aclocal_mpi.m4 2011-01-04 09:09:06 UTC (rev 7656)
+++ mpich2/branches/release/mpich2-1.3.x/confdb/aclocal_mpi.m4 2011-01-04 14:16:50 UTC (rev 7657)
@@ -108,8 +108,12 @@
dnl PAC_LANG_PUSH_COMPILERS, PAC_LIB_MPI
dnl D*/
AC_DEFUN([PAC_ARG_MPI_TYPES],[
+# known types
PAC_ARG_MPI_KNOWN_TYPES
+# find compilers
+PAC_MPI_FIND_COMPILER_SCRIPTS
PAC_MPI_FIND_COMPILERS
+# check for MPI library
PAC_MPI_CHECK_MPI_LIB
dnl
@@ -152,7 +156,16 @@
ac_mpi_type="mpich"
fi
-AC_DEFUN([PAC_MPI_FIND_COMPILERS],[
+dnl
+dnl Because of autoconf insists on moving code to the beginning of
+dnl certain definitions, it is *not possible* to define a single command
+dnl that selects compilation scripts and also check for other options.
+dnl Thus, this needs to be divided into
+dnl MPI_FIND_COMPILER_SCRIPTS
+dnl which can fail (i.e., not find a script), and
+dnl MPI_FIND_COMPILERS
+dnl which runs the various PROC_xx for the compilers.
+AC_DEFUN([PAC_MPI_FIND_COMPILER_SCRIPTS],[
# Set defaults
MPIRUN_NP="-np "
MPIEXEC_N="-n "
@@ -330,43 +343,15 @@
if test -z "$TESTF77" ; then TESTF77=${F77:=f77} ; fi
if test -z "$TESTCXX" ; then TESTCXX=${CXX:=CC} ; fi
if test -z "$TESTFC" ; then TESTFC=${FC:=f90} ; fi
- AC_CHECK_LIB(mpi,MPI_Init)
- if test "$ac_cv_lib_mpi_MPI_Init" = "yes" ; then
- MPILIBNAME="mpi"
- fi
+ # Must check for the MPI library in a separate macro - adding
+ # a test here will cause autoconf to prematurely define the
+ # C compiler
MPIRUN=mpirun
MPIBOOT=""
MPIUNBOOT=""
generic)
- # Find the compilers. Expect the compilers to be mpicc and mpif77
- # in $with_mpi/bin
- PAC_PROG_CC
- # We only look for the other compilers if there is no
- # disable for them
- if test "$enable_f77" != no -a "$enable_fortran" != no ; then
- AC_PROG_F77
- fi
- if test "$enable_cxx" != no ; then
- AC_PROG_CXX
- fi
- if test "$enable_f90" != no ; then
- PAC_PROG_FC
- fi
- # Set defaults for the TEST versions if not already set
- if test -z "$TESTCC" ; then
- TESTCC=${CC:=cc}
- fi
- if test -z "$TESTF77" ; then
- TESTF77=${F77:=f77}
- fi
- if test -z "$TESTCXX" ; then
- TESTCXX=${CXX:=CC}
- fi
- if test -z "$TESTFC" ; then
- TESTFC=${FC:=f90}
- fi
# in $with_mpi/bin or $with_mpi
if test "X$MPICC" = "X" ; then
if test -x "$with_mpi/bin/mpicc" ; then
@@ -413,9 +398,12 @@
# Use the default choices for the compilers
esac
+AC_DEFUN([PAC_MPI_FIND_COMPILERS],[
# Tell autoconf to determine properties of the compilers (these are the
# compilers for MPI programs)
-AC_PROG_CC
+PAC_PROG_CC
AC_PROG_F77
fi
@@ -431,10 +419,10 @@
dnl This uses the selected CC etc to check for include paths and libraries
AC_DEFUN([PAC_MPI_CHECK_MPI_LIB],[
case $ac_mpi_type in
- mpich)
+ mpich)
- mpichnt)
+ mpichnt)
dnl
dnl This isn't adequate, but it helps with using MPICH-NT/SDK.gcc
PAC_PUSH_FLAG([CFLAGS])
@@ -465,27 +453,27 @@
fi
- lammpi)
+ lammpi)
- ibmmpi)
+ ibmmpi)
- sgimpi)
+ sgimpi)
MPILIBNAME="mpi"
fi
- generic)
+ generic)
AC_SEARCH_LIBS(MPI_Init,mpi mpich2 mpich)
MPILIBNAME="mpi"
fi
esac
Property changes on: mpich2/branches/release/mpich2-1.3.x/maint/Version
- /mpich2/branches/dev/ckpt/maint/Version:5050
/mpich2/branches/dev/ckpt2/maint/Version:5057-6537
/mpich2/branches/dev/ftb/maint/Version:5661-5730
/mpich2/branches/dev/lapi/maint/Version:5817
/mpich2/branches/dev/wintcp_async_progress/maint/Version:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/maint/Version:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/maint/Version:5406
/mpich2/trunk/maint/Version:7422-7425,7429-7433,7435,7437-7438,7442-7447,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
/mpich2/trunk/src/pm/hydra/VERSION:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7447
+ /mpich2/branches/dev/ckpt/maint/Version:5050
/mpich2/trunk/maint/Version:7422-7425,7429-7433,7435,7437-7438,7442-7447,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c
- /mpich2/branches/dev/ckpt/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5050
/mpich2/branches/dev/ckpt2/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5057-6537
/mpich2/branches/dev/ftb/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5661-5730
/mpich2/branches/dev/lapi/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5817
/mpich2/branches/dev/win_rrvm/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:6416,6428
/mpich2/branches/dev/wintcp_async_progress/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5406
/mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5050
/mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpl/src/mplstr.c
- /mpich2/branches/dev/ckpt2/src/mpl/src/string/mplstr.c:5182,5196,5198
/mpich2/branches/dev/ftb/src/mpl/src/mplstr.c:5661-5730
/mpich2/branches/dev/lapi/src/mpl/src/mplstr.c:5817
/mpich2/branches/release/mpich2-1.1.1/src/mpl/src/string/mplstr.c:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpl/src/string/mplstr.c:5406
/mpich2/trunk/src/mpl/src/mplstr.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt2/src/mpl/src/string/mplstr.c:5182,5196,5198
/mpich2/trunk/src/mpl/src/mplstr.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra
- /mpich2/branches/dev/ckpt/src/pm/hydra:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra:5406
/mpich2/trunk/src/pm/hydra:7355-7359*,7366-7367*,7371-7402*,7406-7409*,7411-7416*,7419-7420*,7422-7425*,7429-7433*,7435*,7437-7438,7447-7448*,7462*,7470*,7473-7477*,7484-7485*,7488-7491*,7493-7502*,7504*,7507-7508*,7510-7517*,7519-7527*,7529-7530*,7532*,7536*,7538-7566*,7568*,7570*,7572*,7574*,7576*,7578*,7581*,7583*,7592*,7607-7622*,7624-7630*,7632-7635*,7637*,7639*,7641-7643*,7646-7649*,7651-7654*
+ /mpich2/branches/dev/ckpt/src/pm/hydra:5050
/mpich2/trunk/src/pm/hydra:7355-7359*,7366-7367*,7371-7402*,7406-7409*,7411-7416*,7419-7420*,7422-7425*,7429-7433*,7435*,7437-7438,7447-7448*,7462*,7470*,7473-7477*,7484-7485*,7488-7491*,7493-7502*,7504*,7507-7508*,7510-7517*,7519-7527*,7529-7530*,7532*,7536*,7538-7566*,7568*,7570*,7572*,7574*,7576*,7578*,7581*,7583*,7592*,7596*,7607-7622*,7624-7630*,7632-7635*,7637*,7639*,7641-7643*,7646-7649*,7651-7654*
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/Makefile.am
- /mpich2/branches/dev/ckpt/src/pm/hydra/Makefile.am:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/Makefile.am:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/Makefile.am:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/Makefile.am:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/Makefile.am:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/Makefile.am:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/Makefile.am:5406
/mpich2/trunk/src/pm/hydra/Makefile.am:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/src/pm/hydra/Makefile.am:5050
/mpich2/trunk/src/pm/hydra/Makefile.am:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/README
- /mpich2/branches/dev/ckpt/src/pm/hydra/README:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/README:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/README:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/README:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/README:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/README:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/README:5406
/mpich2/trunk/src/pm/hydra/README:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/src/pm/hydra/README:5050
/mpich2/trunk/src/pm/hydra/README:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/autogen.sh
- /mpich2/branches/dev/ckpt/src/pm/hydra/autogen.sh:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/autogen.sh:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/autogen.sh:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/autogen.sh:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/autogen.sh:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/autogen.sh:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/autogen.sh:5406
/mpich2/trunk/src/pm/hydra/autogen.sh:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/src/pm/hydra/autogen.sh:5050
/mpich2/trunk/src/pm/hydra/autogen.sh:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/configure.in
- /mpich2/branches/dev/ckpt/src/pm/hydra/configure.in:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/configure.in:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/configure.in:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/configure.in:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/configure.in:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/configure.in:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/configure.in:5406
/mpich2/trunk/src/pm/hydra/configure.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/src/pm/hydra/configure.in:5050
/mpich2/trunk/src/pm/hydra/configure.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/examples
- /mpich2/branches/dev/ckpt/src/pm/hydra/examples:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/examples:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/examples:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/examples:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/examples:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/examples:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/examples:5406
/mpich2/trunk/src/pm/hydra/examples:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/src/pm/hydra/examples:5050
/mpich2/trunk/src/pm/hydra/examples:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/hydra-doxygen.cfg.in
- /mpich2/branches/dev/ckpt/src/pm/hydra/hydra-doxygen.cfg.in:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/hydra-doxygen.cfg.in:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/hydra-doxygen.cfg.in:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/hydra-doxygen.cfg.in:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/hydra-doxygen.cfg.in:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/hydra-doxygen.cfg.in:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/hydra-doxygen.cfg.in:5406
/mpich2/trunk/src/pm/hydra/hydra-doxygen.cfg.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/src/pm/hydra/hydra-doxygen.cfg.in:5050
/mpich2/trunk/src/pm/hydra/hydra-doxygen.cfg.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/include
- /mpich2/branches/dev/ckpt/src/pm/hydra/include:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/include:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/include:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/include:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/include:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/include:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/include:5406
/mpich2/trunk/src/pm/hydra/include:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/src/pm/hydra/include:5050
/mpich2/trunk/src/pm/hydra/include:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/mpich2prereq
- /mpich2/branches/dev/ckpt/src/pm/hydra/mpich2prereq:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/mpich2prereq:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/mpich2prereq:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/mpich2prereq:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/mpich2prereq:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/mpich2prereq:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/mpich2prereq:5406
/mpich2/trunk/src/pm/hydra/mpich2prereq:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/src/pm/hydra/mpich2prereq:5050
/mpich2/trunk/src/pm/hydra/mpich2prereq:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm
- /mpich2/branches/dev/ckpt/src/pm/hydra/pm:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/pm:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/pm:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/pm:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/pm:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/pm:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/pm:5406
/mpich2/trunk/src/pm/hydra/pm:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/src/pm/hydra/pm:5050
/mpich2/trunk/src/pm/hydra/pm:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools
- /mpich2/branches/dev/ckpt/src/pm/hydra/tools:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/tools:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/tools:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/tools:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/tools:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/tools:5406
/mpich2/trunk/src/pm/hydra/tools:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/src/pm/hydra/tools:5050
/mpich2/trunk/src/pm/hydra/tools:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c
- /mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/slurm/slurm_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/slurm/slurm_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/slurm/slurm_query_proxy_id.c:5661-5730
/mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c
- /mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:5661-5730
/mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c
- /mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:5661-5730
/mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/ui
- /mpich2/branches/dev/ckpt/src/pm/hydra/ui:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/ui:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/ui:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/ui:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/ui:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/ui:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/ui:5406
/mpich2/trunk/src/pm/hydra/ui:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/src/pm/hydra/ui:5050
/mpich2/trunk/src/pm/hydra/ui:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/utils
- /mpich2/branches/dev/ckpt/src/pm/hydra/utils:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/utils:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/utils:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/utils:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/utils:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/utils:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/utils:5406
/mpich2/trunk/src/pm/hydra/utils:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/src/pm/hydra/utils:5050
/mpich2/trunk/src/pm/hydra/utils:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
Property changes on: mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf
- /mpich2/branches/dev/ckpt/winconfigure.wsf:5050
/mpich2/branches/dev/ckpt2/winconfigure.wsf:5057-6537
/mpich2/branches/dev/ftb/winconfigure.wsf:5661-5730
/mpich2/branches/dev/lapi/winconfigure.wsf:5817
/mpich2/branches/dev/win_rrvm/winconfigure.wsf:6404,6407-6408,6420,6422-6423
/mpich2/branches/dev/wintcp_async_progress/winconfigure.wsf:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/winconfigure.wsf:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/winconfigure.wsf:5406
/mpich2/trunk/winconfigure.wsf:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
+ /mpich2/branches/dev/ckpt/winconfigure.wsf:5050
/mpich2/trunk/winconfigure.wsf:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7504,7507-7508,7510-7517,7519-7527,7529-7530,7532,7536,7538-7566,7568,7570,7572,7574,7576,7578,7581,7583,7592,7596,7607-7622,7624-7630,7632-7635,7637,7639,7641-7643,7646-7649,7651-7654
More information about the mpich2-commits
