[mpich2-commits] r7651 - mpich2/trunk
balaji at mcs.anl.gov balaji at mcs.anl.gov
Mon Jan 3 06:58:56 CST 2011
Author: balaji
Date: 2011-01-03 06:58:56 -0600 (Mon, 03 Jan 2011)
New Revision: 7651
Modified:
   mpich2/trunk/README.vin
Log:
Cleanup the README to make somethings clearer:
1. Point out that C++, F77 and F90 support is optional and the users
can disable them.
2. Remove the recommendation for VPATH builds. While this is a
convenient option for system administrators or developers who maintain
multiple copies of MPICH2 builds, it is confusing for users.
3. Remove redundant description of configure options.
4. Remove the MPICH_INTERFACE_HOSTNAME environment variable from the
README, as in the default PM, we automatically pass it based on the
host list provided by the user.
5. Cleaned up several descriptions.
Modified: mpich2/trunk/README.vin
--- mpich2/trunk/README.vin	2010-12-31 03:32:53 UTC (rev 7650)
+++ mpich2/trunk/README.vin	2011-01-03 12:58:56 UTC (rev 7651)
@@ -26,62 +26,58 @@
 on bug fixes and new releases.
-I.    Getting Started
-II.   Alternate Configure Options
-III.  Compiler Flags
-IV.   Alternate Channels and Devices
-V.    Alternate Process Managers
-VI.   VPATH Builds
-VII.  Shared Libraries
-VIII. Other Features
-IX.   Checkpoint/Restart
-X.    Environment Variables
-XI.   Developer Builds
-XII.  Building ROMIO into MPICH2
-XIII. Testing the MPICH2 installation
-XIV.  Installing MPICH2 on windows
-XV.   Multiple Fortran compiler support.
+1.  Getting Started
+2.  Compiler Flags
+3.  Alternate Channels and Devices
+4.  Alternate Process Managers
+5.  Alternate Configure Options
+6.  Testing the MPICH2 installation
+7.  Checkpoint/Restart
+8.  Environment Variables
+9.  Developer Builds
+10. Installing MPICH2 on windows
+11. Multiple Fortran compiler support
-I. Getting Started
+1. Getting Started
 The following instructions take you through a sequence of steps to get
 the default configuration (ch3 device, nemesis channel (with TCP and
 shared memory), Hydra process management) of MPICH2 up and running.
-1.  You will need the following prerequisites.
+(a) You will need the following prerequisites.
-    - This tar file mpich2-%VERSION%.tar.gz
+    - REQUIRED: This tar file mpich2-%VERSION%.tar.gz
-    - A C compiler (gcc is sufficient)
+    - REQUIRED: A C compiler (gcc is sufficient)
-    - A Fortran compiler if Fortran applications are to be used
-      (g77 or gfortran is sufficient)
+    - OPTIONAL: A C++ compiler, if C++ applications are to be used
+      (g++, etc.). If you do not require support for C++ applications,
+      you can disable this support using the configure option
+      --disable-cxx (configuring MPICH2 is described in step 1(d)
+      below).
-    - A C++ compiler for the C++ MPI bindings (g++ is sufficient)
+    - OPTIONAL: A Fortran 77 compiler, if Fortran 77 applications are
+      to be used (gfortran, ifort, etc.). If you do not require
+      support for Fortran 77 applications, you can disable this
+      support using --disable-f77 (configuring MPICH2 is described in
+      step 1(d) below).
-    - If a Fortran 90 compiler is found, by default MPICH2 will
-      attempt to build a basic MPI module.  This module contains the
-      MPI routines that do not contain "choice" arguments; i.e., the module
-      does not contain any of the communication routines, such as
-      MPI_Send, that can take arguments of different type.  You may still
-      use those routines, however, the MPI module does not contain
-      interface specifications for them. If you have trouble with the
-      configuration step and do not need Fortran 90, configure with
-      --disable-fc .
+    - OPTIONAL: A Fortran 90 compiler, if Fortran 90 applications are
+      support for Fortran 90 applications, you can disable this
+      support using --disable-fc. Note that Fortran 77 support is a
+      prerequisite for Fortran 90 support (configuring MPICH2 is
+      described in step 1(d) below).
-    Configure will check for these prerequisites and try to work around
-    deficiencies if possible.  (If you don't have Fortran, you will
-    still be able to use MPICH2, just not with Fortran applications.)
     Also, you need to know what shell you are using since different shell
     has different command syntax. Command "echo $SHELL" prints out the
     current shell used by your terminal program.
-2.  Unpack the tar file and go to the top level directory:
+(b) Unpack the tar file and go to the top level directory:
       tar xzf mpich2-%VERSION%.tar.gz
       cd mpich2-%VERSION%
@@ -92,15 +88,14 @@
       tar xf mpich2-%VERSION%.tar
       cd mpich2-%VERSION%
-3.  Choose an installation directory, say /home/<USERNAME>/mpich2-install,
-    which is assumed to non-existent or empty. It will be most
-    convenient if this directory is shared by all of the machines
-    where you intend to run processes.  If not, you will have
-    to duplicate it on the other machines after installation.
+(c) Choose an installation directory, say
+    /home/<USERNAME>/mpich2-install, which is assumed to non-existent
+    or empty. It will be most convenient if this directory is shared
+    by all of the machines where you intend to run processes. If not,
+    you will have to duplicate it on the other machines after
+    installation.
-4.  Configure MPICH2 specifying the installation directory (the steps
-    described here are called inpath build; we recommend user to do
-    a vpath build if possible, see further below):
+(d) Configure MPICH2 specifying the installation directory:
     for csh and tcsh:
@@ -111,15 +106,25 @@
       ./configure --prefix=/home/<USERNAME>/mpich2-install 2>&1 | tee c.txt
     Bourne-like shells, sh and bash, accept "2>&1 |".  Csh-like shell,
-    csh and tcsh, accept "|&".  File c.txt is used to store all messages
-    generated configure command and is useful for diagnosis if something
-    goes wrong.  Other configure options are described below.  You might
-    also prefer to do a VPATH build (see below).  Check the c.txt file
-    to make sure everything went well.  Problems should be self-explanatory,
-    but if not, please attach c.txt to your bug report.
+    csh and tcsh, accept "|&". If a failure occurs, the configure
+    command will display the error. Most errors are straight-forward
+    to follow. For example, if the configure command fails with:
-5.  Build MPICH2:
+       "No Fortran 77 compiler found. If you don't need to build any
+        Fortran programs, you can disable Fortran support using
+        --disable-f77 and --disable-fc. If you do want to build
+        Fortran programs, you need to install a Fortran compiler such
+        as gfortran or ifort before you can proceed."
+    ... it means that you don't have a Fortran compiler :-). You will
+    need to either install one, or disable Fortran support in MPICH2.
+    If you are unable to understand what went wrong, please go to step
+    1(i) below, for reporting the issue to the MPICH2 developers and
+    other users.
+(e) Build MPICH2:
     for csh and tcsh:
       make |& tee m.txt
@@ -129,8 +134,8 @@
       make 2>&1 | tee m.txt
     This step should succeed if there were no problems with the
-    preceding step.  Check file m.txt. If there were problems,
-    do a "make clean" and then run make again with V=1
+    preceding step. Check file m.txt. If there were problems, do a
+    "make clean" and then run make again with V=1.
       make V=1 |& tee m.txt       (for csh and tcsh)
@@ -138,9 +143,10 @@
       make V=1 2>&1 | tee m.txt   (for bash and sh)
-    and then attach m.txt and c.txt to your bug report.
+    Then go to step 1(i) below, for reporting the issue to the MPICH2
+    developers and other users.
-6.  Install the MPICH2 commands:
+(f) Install the MPICH2 commands:
     for csh and tcsh:
@@ -152,25 +158,12 @@
     This step collects all required executables and scripts in the bin
     subdirectory of the directory specified by the prefix argument to
-    configure.
+    configure.
-    (For users who want an install directory structure compliant to
-     GNU coding standards (i.e., documentation files go to
-     ${datarootdir}/doc/${PACKAGE}, architecture-independent
-     read-only files go to ${datadir}/${PACKAGE}), replace
-     "make install" by
+(g) Add the bin subdirectory of the installation directory to your
+    path in your startup script (.bashrc for bash, .cshrc for csh,
+    etc.):
-       make install PACKAGE=mpich2-<versrion>
-     and corresponding installcheck step should be
-       make installcheck PACKAGE=mpich2-<version>
-    Setting PACKAGE in "make install" or "installcheck" step is optional
-    and unnecessary for typical MPI users.)
-7.  Add the bin subdirectory of the installation directory to your path:
     for csh and tcsh:
       setenv PATH /home/<USERNAME>/mpich2-install/bin:$PATH
@@ -179,94 +172,102 @@
       PATH=/home/<USERNAME>/mpich2-install/bin:$PATH ; export PATH
-    Check that everything is in order at this point by doing
+    Check that everything is in order at this point by doing:
       which mpicc
       which mpiexec
-    All should refer to the commands in the bin subdirectory of your
-    install directory.  It is at this point that you will need to
-    duplicate this directory on your other machines if it is not
-    in a shared file system such as NFS.
+    These commands should display the path to your bin subdirectory of
+    your install directory.
-8.  MPICH2 uses an external process manager for scalable startup of
-    large MPI jobs.  The default process manager is called Hydra. More
-    details on interacting with Hydra can be found at
-    http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
+    IMPORTANT NOTE: The install directory has to be visible at exactly
+    the same path on all machines you want to run your applications
+    on. This is typically achieved by installing MPICH2 on a shared
+    NFS file-system. If you do not have a shared NFS directory, you
+    will need to manually copy the install directory to all machines
+    at exactly the same location.
-    To start a job on your local machine, you can use:
+(h) MPICH2 uses a process manager for starting MPI applications. The
+    process manager provides the "mpiexec" executable, together with
+    other utility executables. MPICH2 comes packaged with multiple
+    process managers; the default is called Hydra.
-      mpiexec -n <number> ./examples/cpi
-9. Test that you can run a multi-node job:
-      mpiexec -f machinefile -n <number> ./examples/cpi
-10. Now we will run an MPI job, using the mpiexec command as specified
-    in the MPI-2 standard.  There are some examples in the install
+    Now we will run an MPI job, using the mpiexec command as specified
+    in the MPI-2 standard. There are some examples in the install
     directory, which you have already put in your path, as well as in
-    the directory mpich2-%VERSION%/examples.  One of them is the
-    classic cpi example, which computes the value of pi by numerical
+    the directory mpich2-%VERSION%/examples. One of them is the
+    classic CPI example, which computes the value of pi by numerical
     integration in parallel.
-      mpiexec -f machinefile -n 5 ./examples/cpi
+    To run the CPI example with 'n' processes on your local machine,
+    you can use:
-    The cpi example will tell you which hosts it is running on.
+      mpiexec -n <number> ./examples/cpi
-    For additional mpiexec options, do:
+    Test that you can run an 'n' process CPI job on multiple nodes:
-      mpiexec --help
+      mpiexec -f machinefile -n <number> ./examples/cpi
-If you have completed all of the above steps, you have successfully
-installed MPICH2 and run an MPI example.
+    The 'machinefile' is of the form:
-More details on arguments to mpiexec are given in the User's Guide in
-the doc subdirectory. Also in the User's Guide you will find help on
-debugging. MPICH2 has support for the TotalView debugger, as well as
-some other approaches described there.
+      host1
+      host2:2
+      host3:4   # Random comments
+      host4:1
+    'host1', 'host2', 'host3' and 'host4' are the hostnames of the
+    machines you want to run the job on. The ':2', ':4', ':1' segments
+    depict the number of processes you want to run on each node. If
+    nothing is specified, ':1' is assumed.
+    More details on interacting with Hydra can be found at
+    http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
-The above steps utilized the MPICH2 defaults, which included choosing
-TCP and shared memory for communication (via the "nemesis" channel)
-and the Hydra process manager. Other alternatives are available.  You
-can find out about configuration alternatives with
+If you have completed all of the above steps, you have successfully
+installed MPICH2 and run an MPI example.
-   ./configure --help
+(i) If you run into any errors configuring, building or running
+MPICH2, please send the below files to mpich-discuss at mcs.anl.gov.
+PLEASE COMPRESS BEFORE SENDING, AS THE FILES CAN BE LARGE. Note that,
+depending on which step the build failed, some of the files might not
+exist.
-in the mpich2 directory.  The alternatives described below are
-configured by adding arguments to the configure step.
+    mpich2-%VERSION%/c.txt (generated in step 1(d) above)
+    mpich2-%VERSION%/m.txt (generated in step 1(e) above)
+    mpich2-%VERSION%/mi.txt (generated in step 1(f) above)
+    mpich2-%VERSION%/config.log (generated in step 1(d) above)
+    mpich2-%VERSION%/src/openpa/config.log (generated in step 1(d) above)
+More details on arguments to mpiexec are given in the User's Guide in
+the doc subdirectory.
+2. Compiler Flags
 MPICH2 allows several sets of compiler flags to be used. The first
 three sets are configure-time options for MPICH2, while the fourth is
 only relevant when compiling applications with mpicc and friends.
-1. CFLAGS, CPPFLAGS, CXXFLAGS, FFLAGS, FCFLAGS, LDFLAGS and LIBS
+(a) CFLAGS, CPPFLAGS, CXXFLAGS, FFLAGS, FCFLAGS, LDFLAGS and LIBS
 (abbreviated as xFLAGS): Setting these flags would result in the
 MPICH2 library being compiled/linked with these flags and the flags
 internally being used in mpicc and friends.
-2. MPICH2LIB_CFLAGS, MPICH2LIB_CPPFLAGS, MPICH2LIB_CXXFLAGS,
+(b) MPICH2LIB_CFLAGS, MPICH2LIB_CPPFLAGS, MPICH2LIB_CXXFLAGS,
 MPICH2LIB_FFLAGS, MPICH2LIB_FCFLAGS, MPICH2LIB_LDFLAGS and
 MPICH2LIB_LIBS (abbreviated as MPICH2LIB_xFLAGS): Setting these flags
 would result in the MPICH2 library being compiled/linked with these
 flags. However, these flags will *not* be used by mpicc and friends.
-3. MPICH2_MAKE_CFLAGS: Setting these flags would result in MPICH2's
+(c) MPICH2_MAKE_CFLAGS: Setting these flags would result in MPICH2's
 configure tests to not use these flags, but the makefile's to use
 them. This is a temporary hack for certain cases that advanced
-developers might be interested in which break existing configure tests
-(e.g., -Werror) and are not recommended for regular users.
+developers might be interested in, but which break existing configure
+tests (e.g., -Werror). These are NOT recommended for regular users.
-4. MPICH2_MPICC_FLAGS, MPICH2_MPICPP_FLAGS, MPICH2_MPICXX_FLAGS,
+(d) MPICH2_MPICC_FLAGS, MPICH2_MPICPP_FLAGS, MPICH2_MPICXX_FLAGS,
 MPICH2_MPIF77_FLAGS, MPICH2_MPIFC_FLAGS, MPICH2_LDFLAGS and
 MPICH2_LIBS (abbreviated as MPICH2_MPIX_FLAGS): These flags do *not*
 affect the compilation of the MPICH2 library itself, but will be
@@ -328,7 +329,8 @@
 Example 1:
-  ./configure --disable-fast MPICH2LIB_CFLAGS=-O3 MPICH2LIB_FFLAGS=-O3 MPICH2LIB_CXXFLAGS=-O3 MPICH2LIB_FCFLAGS=-O3
+  ./configure --disable-fast MPICH2LIB_CFLAGS=-O3 MPICH2LIB_FFLAGS=-O3 \
+        MPICH2LIB_CXXFLAGS=-O3 MPICH2LIB_FCFLAGS=-O3
 This will cause the MPICH2 libraries to be built with -O3, and -O3
 will *not* be included in the mpicc and other MPI wrapper script.
@@ -356,8 +358,8 @@
 The communication mechanisms in MPICH2 are called "devices". MPICH2
 supports several internal devices including ch3 (default), dcmfd (for
@@ -438,7 +440,6 @@
 using this for Nemesis may limit the number of processes that can be
 started on a single node.
 sock channel
 sock is the traditional TCP sockets based communication channel. It
@@ -526,14 +527,15 @@
   AR=${DRIVER_PATH}/gnu-linux/bin/powerpc-bgp-linux-ar \
   LD=${DRIVER_PATH}/gnu-linux/bin/powerpc-bgp-linux-ld \
   MSGLAYER_INCLUDE="-I${DRIVER_PATH}/comm/include" \
-  MSGLAYER_LIB="-L${DRIVER_PATH}/comm/lib -ldcmfcoll.cnk -ldcmf.cnk -lpthread -lrt -L$DRIVER_PATH/runtime/SPI -lSPI.cna" \
+  MSGLAYER_LIB="-L${DRIVER_PATH}/comm/lib -ldcmfcoll.cnk -ldcmf.cnk -lpthread -lrt \
+      -L$DRIVER_PATH/runtime/SPI -lSPI.cna" \
   ./configure --with-device=dcmfd:BGP --with-pmi=no --with-pm=no --with-file-system=bgl \
   	      --enable-timer-type=device --with-cross=src/mpid/dcmfd/cross \
 	      --host=powerpc-bgp-linux --target=powerpc-bgp-linux --build=powerpc64-linux-gnu
 hydra
@@ -552,20 +554,19 @@
 smpd
-SMPD is a process management system for both Microsoft Windows and UNIX.
-SMPD is capable of starting a job where some processes are running on
-Windows and others are running on a variant of UNIX.  For more
-information, please see mpich2-%VERSION%/src/pm/smpd/README.
+SMPD is a process manager for interoperability between Microsoft
+Windows and UNIX, where some processes are running on Windows and
+others are running on a variant of UNIX. For more information, please
+see mpich2-%VERSION%/src/pm/smpd/README.
 gforker
-gforker is a process manager that creates processes on a single machine,
-by having mpiexec directly fork and exec them.  This mechanism is
-particularly appropriate for shared-memory multiprocessors (SMPs) where
-you want to create all the processes on the same machine.  gforker is
-also useful for debugging, where running all the processes on a single
-machine is often convenient.
+gforker is a process manager that creates processes on a single
+machine, by having mpiexec directly fork and exec them. gforker is
+mostly meant as a research platform and for debugging purposes, as it
+is only meant for single-node systems.
 slurm
 SLURM is an external process manager not distributed with
@@ -575,144 +576,136 @@
-VI. VPATH Builds
-MPICH2 supports building MPICH in a different directory tree than the
-one where the MPICH2 source is installed. This often allows faster
-building, as the sources can be placed in a shared filesystem and the
-builds done in a local (and hence usually much faster) filesystem.  To
-make this clear, the following example assumes that the sources are
-placed in /home/me/mpich2-<VERSION>, the build is done in
-/tmp/me/mpich2, and the installed version goes into
-/usr/local/mpich2-<VERSION>:
-  shell$ cd /home/me
-  shell$ tar xzf mpich2-<VERSION>.tar.gz
-  shell$ cd /tmp/me
+MPICH2 has a number of other features. If you are exploring MPICH2 as
+part of a development project, you might want to tweak the MPICH2
+build with the following configure options. A complete list of
+configuration options can be found using:
-  shell$ mkdir mpich2
-  shell$ cd mpich2
-  shell$ /home/me/mpich2-<VERSION>/configure --prefix=/usr/local/mpich2-<VERSION>
-  shell$ make
-  shell$ make install
+   ./configure --help
+However, for your convenience, we list a few important options here:
-Shared libraries are currently only supported for gcc (and gcc-like
-compilers) on Linux and Mac and for cc on Solaris. To have shared
-libraries created when MPICH2 is built, specify the following when
-MPICH2 is configured:
-    configure --enable-shared
-For users who wish to manually control the linker parameters, this can
-be done using:
-    configure --enable-sharedlibs=gcc         (on Linux)
-    configure --enable-sharedlibs=osx-gcc     (on Mac OS X)
-    configure --enable-sharedlibs=solaris-cc  (on Solaris)
-MPICH2 has a number of other features. If you are exploring MPICH2 as
-part of a development project the following configure options are
-important:
 Performance Options:
  --enable-fast - Turns off error checking and collection of internal
                  timing information
  --enable-timing=no - Turns off just the collection of internal timing
-                 information
+                      information
  --enable-ndebug - Turns on NDEBUG, which disables asserts. This is a
-		subset of the optimizations provided by enable-fast,
-		but is useful in environments where the user wishes
-		to retain the debug symbols, e.g., this can be combined
-		with the --enable-g option.
+                   subset of the optimizations provided by
+                   enable-fast, but is useful in environments where
+                   the user wishes to retain the debug symbols, e.g.,
+                   this can be combined with the --enable-g option.
 MPI Features:
-  --enable-romio - Build the ROMIO implementation of MPI-IO.  This is
-                 the default
+  --enable-romio - Build the ROMIO implementation of MPI-IO (enabled
+                   by default).
   --with-file-system - When used with --enable-romio, specifies
-                 filesystems ROMIO should support.  See README.romio.
+                       filesystems ROMIO should support. They can be
+                       specified by passing them in a '+'-delimited
+                       list: (e.g.,
+                       --with-file-system="pvfs+nfs+ufs").
+                       If you have installed version 2 of the PVFS
+                       file system, you can use the
+                       '--with-pvfs2=<prefix>' configure option to
+                       specify where libraries, headers, and utilities
+                       have been installed. If you have added the pvfs
+                       utilities to your PATH, then ROMIO will detect
+                       this and build support for PVFS automatically.
   --enable-threads - Build MPICH2 with support for multi-threaded
-                 applications. Only the sock and nemesis channels support
-                 MPI_THREAD_MULTIPLE.
+                     applications. Only the sock and nemesis channels
+                     support MPI_THREAD_MULTIPLE.
   --with-thread-package - When used with --enable-threads, this option
-                 specifies the thread package to use.  This option
-                 defaults to "posix".  At the moment, only POSIX
-                 threads are supported on UNIX platforms.  We plan to
-                 support Solaris threads in the future.
+                          specifies the thread package to use.  This
+                          option defaults to "posix".  At the moment,
+                          only POSIX threads are supported on UNIX
+                          platforms.  We plan to support Solaris
+                          threads in the future.
 Language bindings:
-  --enable-f77 - Build the Fortran 77 bindings.  This is the default.
-                 It has been tested with the Fortran parts of the Intel
-                 test suite.
+  --enable-f77 - Build the Fortran 77 bindings (enabled by default).
-  --enable-fc  - Build the Fortran 90 bindings.  This is on by default.
+  --enable-fc - Build the Fortran 90 bindings (enabled by default).
-  --enable-cxx - Build the C++ bindings.  This has been tested with the
-                 Notre Dame C++ test suite and some additional tests.
+  --enable-cxx - Build the C++ bindings (enabled by default).
+Shared library support:
+  --enable-shared - Enable shared library support. Shared libraries
+                    are currently only supported for gcc (and gcc-like
+                    compilers) on Linux and Mac and for cc on
+                    Solaris. To have shared libraries created when
+                    MPICH2 is built, specify the following when MPICH2
+                    is configured:
+  For users who wish to manually control the linker parameters, this
+  can be done using:
+  --enable-sharedlibs=gcc         (on Linux)
+  --enable-sharedlibs=osx-gcc     (on Mac OS X)
+  --enable-sharedlibs=solaris-cc  (on Solaris)
 Cross compilation:
   --with-cross=filename - Provide values for the tests that required
-                 running a program, such as the tests that configure
-                 uses to determine the sizes of the basic types.  This
-                 should be a fine in Bourne shell format containing
-                 variable assignment of the form
+                          running a program, such as the tests that
+                          configure uses to determine the sizes of the
+                          basic types.  This should be a fine in
+                          Bourne shell format containing variable
+                          assignment of the form
-                     CROSS_SIZEOF_INT=2
+                          CROSS_SIZEOF_INT=2
-                 for all of the CROSS_xxx variables.  A list will be
-                 provided in later releases; for now, look at the
-                 configure.in files.  This has not been completely
-                 tested.
+                          for all of the CROSS_xxx variables.
 Error checking and reporting:
-  --enable-error-checking=level - Control the amount of error checking.
-                 Currently, only "no" and "all" is supported; all is the
-                 default.
+  --enable-error-checking=level - Control the amount of error
+                                  checking. Currently, only "no" and
+                                  "all" is supported; all is the
+                                  default.
   --enable-error-messages=level - Control the aount of detail in error
-                 messages.  By default, MPICH2 provides
-                 instance-specific error messages; but, with this
-                 option, MPICH2 can be configured to provide less
-                 detailed messages.  This may be desirable on small
-                 systems, such as clusters built from game consoles or
-                 high-density massively parallel systems.  This is still
-                 under active development.
+                                  messages. By default, MPICH2
+                                  provides instance-specific error
+                                  messages; but, with this option,
+                                  MPICH2 can be configured to provide
+                                  less detailed messages.  This may be
+                                  desirable on small systems, such as
+                                  clusters built from game consoles or
+                                  high-density massively parallel
+                                  systems.  This is still under active
+                                  development.
 Compilation options for development:
   --enable-g=value - Controls the amount of debugging information
-                 collected by the code.  The most useful choice here is
-                 dbg, which compiles with -g.
+                     collected by the code.  The most useful choice
+                     here is dbg, which compiles with -g.
   --enable-coverage - An experimental option that enables GNU coverage
-                 analysis.
+                      analysis.
   --with-logging=name - Select a logging library for recording the
-                 timings of the internal routines.  We have used this to
-                 understand the performance of the internals of MPICH2.
-                 More information on the logging options, capabilities
-                 and usage can be found in doc/logging/logging.pdf.
+                        timings of the internal routines.  We have
+                        used this to understand the performance of the
+                        internals of MPICH2.  More information on the
+                        logging options, capabilities and usage can be
+                        found in doc/logging/logging.pdf.
-  --enable-timer-type=name -  Select the timer to use for MPI_Wtime
-                 and internal timestamps.  name may be one of:
+  --enable-timer-type=name - Select the timer to use for MPI_Wtime and
+                             internal timestamps.  name may be one of:
                      gethrtime        - Solaris timer (Solaris systems
                                         only)
                      clock_gettime    - Posix timer (where available)
@@ -730,26 +723,37 @@
+To test MPICH2, we package the MPICH2 test suite in the MPICH2
+distribution. You can run the test suite using:
+     make testing
+The results summary will be placed in test/summary.xml
 MPICH2 supports checkpointing and restart fault-tolerance using BLCR.
 Configuration
+First, you need to have BLCR version 0.8.2 or later installed on your
+machine.  If it's installed in the default system location, add the
+following two options to your configure command:
-First, you need to have BLCR version 0.8.2 installed on your machine.
-If it's installed in the default system location, add the following
-two options to your configure command:
   --enable-checkpointing
   --with-hydra-ckpointlib=blcr
 If BLCR is not installed in the default system location, you'll need
-to tell MPICH2's configure where to find it.  You might also need to
+to tell MPICH2's configure where to find it. You might also need to
 set the LD_LIBRARY_PATH environment variable so that BLCR's shared
 libraries can be found.  In this case add the following options to
-your configure comment:
+your configure command:
@@ -760,34 +764,34 @@
 installed (whatever was specified in --prefix when BLCR was
 configured).
+After it's configured compile as usual (e.g., make; make install).
 Note, checkpointing is only supported with the Hydra process manager.
-(Hyrda will configured by default, unless you choose something else
-with the --with-pm= configure option.)
-After it's configured compile as usual (e.g., make; make install).
-Running an Application
+Verifying Checkpointing Support
+Make sure MPICH2 is correctly configured with BLCR. You can do this
+using:
-Hydra provides checkpoint/restart capability.  Currently, only BLCR is
-being experimented with.  You can pick these through the mpiexec
-option -ckpointlib to specify the checkpointing library to use and
--ckpoint-prefix to specify the prefix of the file to write the
-checkpoint image to:
+  mpiexec -info
-  mpiexec -ckpointlib blcr -ckpoint-prefix /tmp/app.ckpoint -f hosts \
-  -n 4 ./app
+This should display 'BLCR' under 'Checkpointing libraries available'.
-While the application is running, the user can request for a
-checkpoint at any time by sending a SIGUSR1 signal to mpiexec.
-You can also automatically checkpoint the application at regular
-intervals using the mpiexec option -ckpoint-interval (seconds):
+Checkpointing the Application
+There are two ways to cause the application to checkpoint. You can ask
+mpiexec to periodically checkpoint the application using the mpiexec
+option -ckpoint-interval (seconds):
   mpiexec -ckpointlib blcr -ckpoint-prefix /tmp/app.ckpoint \
-  -ckpoint-interval 3600 -f hosts -n 4 ./app
+      -ckpoint-interval 3600 -f hosts -n 4 ./app
-The checkpoint/restart parameters can be controlled with the
+Alternatively, you can also manually force checkpointing by sending a
+SIGUSR1 signal to mpiexec.
+The checkpoint/restart parameters can also be controlled with the
 environment variables HYDRA_CKPOINTLIB, HYDRA_CKPOINT_PREFIX and
 HYDRA_CKPOINT_INTERVAL.
@@ -803,7 +807,7 @@
 MPICH2 provides several environment variables that have different
@@ -818,47 +822,6 @@
-  MPICH_INTERFACE_HOSTNAME - Network interface to use for
-         communication. By default MPICH2 picks the network interface
-         representing the hostname (gotten by gethostbyname). Consider
-         the following example:
-% /sbin/ifconfig
-eth0      Link encap:Ethernet  HWaddr 00:14:5E:57:C4:FA
-          inet addr:192.148.3.182  Bcast:192.148.248.255  Mask:255.255.255.0
-          inet6 addr: fe80::214:5eff:fe57:c4fa/64 Scope:Link
-          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
-          RX packets:989925894 errors:0 dropped:7186 overruns:0 frame:0
-          TX packets:1480277023 errors:0 dropped:0 overruns:0 carrier:0
-          collisions:0 txqueuelen:1000
-          RX bytes:441568994866 (411.2 GiB)  TX bytes:1864173370054 (1.6 TiB)
-          Interrupt:185 Memory:e2000000-e2012100
-myri0     Link encap:Ethernet  HWaddr 00:14:5E:57:C4:F8
-          inet addr:10.21.3.182  Bcast:10.21.255.255  Mask:255.255.0.0
-          inet6 addr: fe80::214:5eff:fe57:c4f8/64 Scope:Link
-          RX packets:3068986439 errors:0 dropped:7841 overruns:0 frame:0
-          TX packets:2288060450 errors:0 dropped:0 overruns:0 carrier:0
-          RX bytes:3598751494497 (3.2 TiB)  TX bytes:1744058613150 (1.5 TiB)
-          Interrupt:185 Memory:e4000000-e4012100
-In the above case the 192.148.x.x IP series refers to the standard
-Ethernet (or Gigabit Ethernet) network, AND the 10.21.x.x series
-refers to Myrinet.
-To run over the Myrinet network use:
-% mpiexec -np 1 -env MPICH_INTERFACE_HOSTNAME 10.21.3.182 ./foo
-  MPICH_INTERFACE_HOSTNAME_R%d - Network interface to use for rank %d.
   MPICH_PORT_RANGE - Port range to use for MPICH2 internal TCP
          connections. This is useful when some of the host ports are
          blocked by a firewall. For example, setting MPICH_PORT_RANGE
@@ -878,8 +841,8 @@
 For MPICH2 developers who want to directly work on the svn, there are
 a few additional steps involved (people using the release tarballs do
 not have to follow these steps). Details about these steps can be
@@ -888,64 +851,34 @@
-By default, ROMIO, an implementation of the I/O portion of MPI-2 will
-be built as a part of MPICH2. The file systems to be built can be
-speicified by passing them in a '+'-delimited list to the
---with-file-system configure option. For example:
+10. Installing MPICH2 on Windows
-  --with-file-system="pvfs+nfs+ufs"
-If you have installed version 2 of the PVFS file system, you can use
-the '--with-pvfs2=<prefix>' configure option to specify where
-libraries, headers, and utilities have been installed. If you have
-added the pvfs utilities to your PATH, then ROMIO will detect this and
-build support for PVFS automatically.
-To test MPICH2, use the following options after installing mpich2.
-These will assume that mpich2 is installed into /usr/local/mpich2.
-1. MPICH2 test suite:
-   shell$ make testing
-The results summary will be placed in test/summary.xml
-XIV. Installing MPICH2 on Windows
 Here are the instructions for setting up MPICH2 on a Windows machine:
-0) Install:
+(a) Install:
     Microsoft Developer Studio 2003 or later
     Intel Fortran 8.0 or later
     cygwin
 	choose the dos file format option
 	install perl and cvs
-1) Checkout mpich2:
+(b) Checkout mpich2:
     Bring up a command prompt.
     (replace "yourname" with your MCS login name):
     svn co https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk mpich2
-2) Generate *.h.in
+(c) Generate *.h.in
     Bring up a cygwin bash shell.
     cd mpich2
     maint/updatefiles
     exit
-3) Execute winconfigure.wsf
+(d) Execute winconfigure.wsf
-4) Open Developer Studio
+(e) Open Developer Studio
     open mpich2\mpich2.sln
     build the ch3sockDebug mpich2 solution
@@ -961,31 +894,31 @@
     build the sfortDebug mpich2 solution
     build the sfortRelease mpich2 solution
-5) Open a command prompt
+(f) Open a command prompt
     cd to mpich2\maint
     execute "makegcclibs.bat"
-6) Open another Developer Studio instance
+(g) Open another Developer Studio instance
     open mpich2\examples\examples.sln
     build the Release target of the cpi project
-7) Return to Developer Studio with the mpich2 solution
+(h) Return to Developer Studio with the mpich2 solution
     set the version numbers in the Installer project
     build the Installer mpich2 solution
-8) Test and distribute mpich2\maint\ReleaseMSI\mpich2.msi
+(i) Test and distribute mpich2\maint\ReleaseMSI\mpich2.msi
     mpich2.msi can be renamed, eg mpich2-1.1.msi
-9) To install the launcher:
+(j) To install the launcher:
     Copy smpd.exe to a local directory on all the nodes.
     Log on to each node as an administrator and execute "smpd.exe -install"
-10) Compile and run an MPI application:
+(k) Compile and run an MPI application:
     Compile an mpi application.  Use mpi.h from mpich2\src\include\win32
     and mpi.lib in mpich2\lib
@@ -997,36 +930,37 @@
-XIV. Multiple Fortran compiler support
 If the C compiler that is used to build MPICH2 libraries supports both
-multiple weak symbols and multiple aliases of common symbols, the Fortran 77
-binding can support multiple Fortran compilers.  The multiple weak symbols
-support allow MPICH2 to provide different name mangling scheme (of
-subroutine names) required by differen Fortran compilers.  The multiple
-aliases of common symbols support enables MPICH2 to equal different common
-block symbols of the MPI Fortran constant, e.g. MPI_IN_PLACE,
-MPI_STATUS_IGNORE...  So they are understood by different Fortran compilers.
+multiple weak symbols and multiple aliases of common symbols, the
+Fortran 77 binding can support multiple Fortran compilers. The
+multiple weak symbols support allow MPICH2 to provide different name
+mangling scheme (of subroutine names) required by differen Fortran
+compilers. The multiple aliases of common symbols support enables
+MPICH2 to equal different common block symbols of the MPI Fortran
+constant, e.g. MPI_IN_PLACE, MPI_STATUS_IGNORE. So they are understood
+by different Fortran compilers.
-Since the support of multiple aliases of common symbols is new/experimental,
-users can disable the feature by using configure option --disable-multi-aliases
-if it causes any undesirable effect, e.g. linker warnings of different sizes
-of common symbols, MPIFCMB* (the warning should be harmless).
+Since the support of multiple aliases of common symbols is
+new/experimental, users can disable the feature by using configure
+option --disable-multi-aliases if it causes any undesirable effect,
+e.g. linker warnings of different sizes of common symbols, MPIFCMB*
+(the warning should be harmless).
-We have only tested this support on a limited set of platforms/compilers.
-On linux, if the C compiler that builds MPICH2 is either gcc or icc,
-the above support will be enabled by configure.  At the time of this
-writing, pgcc does not seem to have this multiple aliases of common symbols,
-so configure will detect the deficiency and disable the feature automatically.
-The tested Fortran compiler includes GNU Forran compilers(gfortan, g77),
-Intel Fortran compiler(ifort), Portland Group Fortran compilers(pgf77, pgf90),
-Absoft Fortran compilers (af77, af90), and IBM XL fortran compiler(xlf).
-What this mean is that if mpich2 is built by gcc/gfortran, the resulting
-mpich2 library can be used to link a Fortran program compiled/linked by
-another fortran compiler, say pgf77, say through mpif77 -f77=pgf77.
-As long as the Fortran program is linked without any errors by
-one of these compilers, the program shall be running fine.
-Ref: http://trac.mcs.anl.gov/projects/mpich2/ticket/502.
+We have only tested this support on a limited set of
+platforms/compilers.  On linux, if the C compiler that builds MPICH2
+is either gcc or icc, the above support will be enabled by configure.
+At the time of this writing, pgcc does not seem to have this multiple
+aliases of common symbols, so configure will detect the deficiency and
+disable the feature automatically.  The tested Fortran compiler
+includes GNU Forran compilers(gfortan, g77), Intel Fortran
+compiler(ifort), Portland Group Fortran compilers(pgf77, pgf90),
+Absoft Fortran compilers (af77, af90), and IBM XL fortran
+compiler(xlf).  What this mean is that if mpich2 is built by
+gcc/gfortran, the resulting mpich2 library can be used to link a
+Fortran program compiled/linked by another fortran compiler, say
+pgf77, say through mpif77 -f77=pgf77.  As long as the Fortran program
+is linked without any errors by one of these compilers, the program
+shall be running fine.
More information about the mpich2-commits mailing list
