[mpich2-commits] r8062 - in mpich2/trunk/src/mpi: datatype topo
gropp at mcs.anl.gov
Sat Feb 26 10:47:10 CST 2011
Author: gropp
Date: 2011-02-26 10:47:10 -0600 (Sat, 26 Feb 2011)
New Revision: 8062
Modified:
mpich2/trunk/src/mpi/datatype/pack.c
mpich2/trunk/src/mpi/datatype/unpack.c
mpich2/trunk/src/mpi/topo/dist_gr_create.c
mpich2/trunk/src/mpi/topo/dist_gr_create_adj.c
Log:
Minor corrections to the comments that are used to produce the man pages
Modified: mpich2/trunk/src/mpi/datatype/pack.c
--- mpich2/trunk/src/mpi/datatype/pack.c 2011-02-26 05:02:31 UTC (rev 8061)
+++ mpich2/trunk/src/mpi/datatype/pack.c 2011-02-26 16:47:10 UTC (rev 8062)
@@ -112,15 +112,19 @@
MPI_Pack - Packs a datatype into contiguous memory
- Arguments:
-+ void *inbuf - input buffer
-. int incount - input count
-. MPI_Datatype datatype - datatype
-. void *outbuf - output buffer
-. int outcount - output count
-. int *position - position
-- MPI_Commm comm - communicator
+ Input Parameters:
++ inbuf - input buffer start (choice)
+. incount - number of input data items (non-negative integer)
+. datatype - datatype of each input data item (handle)
+. outcount - output buffer size, in bytes (non-negative integer)
+- comm - communicator for packed message (handle)
+ Output Parameter:
+. outbuf - output buffer start (choice)
+ Input/Output Parameter:
+. position - current position in buffer, in bytes (integer)
Notes (from the specifications):
The input value of position is the first location in the output buffer to be
@@ -135,6 +139,8 @@
.N Errors
.N MPI_SUCCESS
+.N MPI_ERR_ARG
+.N MPI_ERR_OTHER
int MPI_Pack(void *inbuf,
int incount,
Modified: mpich2/trunk/src/mpi/datatype/unpack.c
--- mpich2/trunk/src/mpi/datatype/unpack.c 2011-02-26 05:02:31 UTC (rev 8061)
+++ mpich2/trunk/src/mpi/datatype/unpack.c 2011-02-26 16:47:10 UTC (rev 8062)
@@ -108,7 +108,6 @@
Input Parameters:
. insize - size of input buffer, in bytes (integer)
-. position - current position in bytes (integer)
. outcount - number of items to be unpacked (integer)
. datatype - datatype of each output data item (handle)
@@ -116,6 +115,10 @@
Output Parameter:
+Inout/Output Parameter:
+. position - current position in bytes (integer)
.N ThreadSafe
.N Fortran
Modified: mpich2/trunk/src/mpi/topo/dist_gr_create.c
--- mpich2/trunk/src/mpi/topo/dist_gr_create.c 2011-02-26 05:02:31 UTC (rev 8061)
+++ mpich2/trunk/src/mpi/topo/dist_gr_create.c 2011-02-26 16:47:10 UTC (rev 8062)
@@ -38,11 +38,16 @@
Input Parameters:
+ comm_old - input communicator (handle)
-. n - number of source nodes for which this process specifies edges (non-negative integer)
-. sources - array containing the n source nodes for which this process specifies edges (array of non-negative integers)
-. degrees - array specifying the number of destinations for each source node in the source node array (array of non-negative integers)
-. destinations - destination nodes for the source nodes in the source node array (array of non-negative integers)
-. weights - weights for source to destination edges (array of non-negative integers)
+. n - number of source nodes for which this process specifies edges
+ (non-negative integer)
+. sources - array containing the n source nodes for which this process
+ specifies edges (array of non-negative integers)
+. degrees - array specifying the number of destinations for each source node
+ in the source node array (array of non-negative integers)
+. destinations - destination nodes for the source nodes in the source node
+ array (array of non-negative integers)
+. weights - weights for source to destination edges (array of non-negative
+ integers or MPI_UNWEIGHTED)
. info - hints on optimization and interpretation of weights (handle)
- reorder - the process may be reordered (true) or not (false) (logical)
@@ -55,6 +60,8 @@
.N Errors
.N MPI_SUCCESS
+.N MPI_ERR_ARG
+.N MPI_ERR_OTHER
int MPI_Dist_graph_create(MPI_Comm comm_old, int n, int sources[],
int degrees[], int destinations[], int weights[],
Modified: mpich2/trunk/src/mpi/topo/dist_gr_create_adj.c
--- mpich2/trunk/src/mpi/topo/dist_gr_create_adj.c 2011-02-26 05:02:31 UTC (rev 8061)
+++ mpich2/trunk/src/mpi/topo/dist_gr_create_adj.c 2011-02-26 16:47:10 UTC (rev 8062)
@@ -41,11 +41,12 @@
. sources - ranks of processes for which the calling process is a
destination (array of non-negative integers)
. sourceweights - weights of the edges into the calling
- process (array of non-negative integers)
+ process (array of non-negative integers or MPI_UNWEIGHTED)
. outdegree - size of destinations and destweights arrays (non-negative integer)
. destinations - ranks of processes for which the calling process is a
source (array of non-negative integers)
-. destweights - weights of the edges out of the calling process (array of non-negative integers)
+. destweights - weights of the edges out of the calling process
+ (array of non-negative integers or MPI_UNWEIGHTED)
- reorder - the ranks may be reordered (true) or not (false) (logical)
@@ -58,8 +59,8 @@
.N Errors
.N MPI_SUCCESS
-.N MPI_ERR_TOPOLOGY
.N MPI_ERR_ARG
+.N MPI_ERR_OTHER
int MPI_Dist_graph_create_adjacent(MPI_Comm comm_old,
int indegree, int sources[], int sourceweights[],
More information about the mpich2-commits
