[mpich2-commits] r8055 - mpich2/trunk/test/mpi
balaji at mcs.anl.gov
Fri Feb 25 20:46:46 CST 2011
Author: balaji
Date: 2011-02-25 20:46:46 -0600 (Fri, 25 Feb 2011)
New Revision: 8055
Modified:
mpich2/trunk/test/mpi/runtests.in
Log:
Update the MPICH2 test suite to handle Hydra's new error outputs.
Modified: mpich2/trunk/test/mpi/runtests.in
--- mpich2/trunk/test/mpi/runtests.in 2011-02-26 02:46:42 UTC (rev 8054)
+++ mpich2/trunk/test/mpi/runtests.in 2011-02-26 02:46:46 UTC (rev 8055)
@@ -632,7 +632,7 @@
$inline .= $_;
# ANY output is an error. We have the following output
# exception for the Hydra process manager.
- if (/\[mpiexec at .*\] ONE OF THE PROCESSES TERMINATED BADLY: CLEANING UP/) { next; }
+ if (/=*/) { last; }
if (! /^\s*$/) {
print STDERR "Unexpected output in $programname: $_";
if (!$found_error) {
@@ -677,7 +677,7 @@
if (/signaled with Interrupt/) { next; }
# Allow 'job ending due to env var MPIEXEC_TIMEOUT' (mpd)
if (/job ending due to env var MPIEXEC_TIMEOUT/) { next; }
- # Allow 'EXIT STRING: Terminated \(signal 15\)' (hydra)
+ # Allow 'APPLICATION TIMED OUT' (hydra)
if (/\[mpiexec at .*\] APPLICATION TIMED OUT/) { last; }
# ANY output is an error (other than timeout)
if (! /^\s*$/) {
More information about the mpich2-commits
